01-16-2022, 08:13 AM | #1 |
Rep 22
JB4 on Racetracks - OBD conflict with TrackAddict
Hey all,
Before installing a JB4 on my M3 comp, I was using the TrackAddict app to capture videos with car data. So I was able to create videos with track map and car data overlays. As you all know, TrackAddict uses a OBD connector to read the car data in real-time during my sessions. The problem with JB4 is that it requires to be connected to the OBD port at all time in order to work properly and give the best results. So.... now I have a dilemma: If I use JB4 as intended, I cannot have the OBD reader connected at the same time. If I disconnect the JB4 from the OBD port, it'll performance poorly and be stuck on map 1, I believe. Anyone ran into this and can provide some advise? Cheers! gec |
01-16-2022, 11:57 AM | #3 |
Beware of cheap bait!
705
Rep 712
You really don't want to use an OBD splitter with JB4. Can cause big issues.
BMWRacer5232519.00 |
01-16-2022, 12:19 PM | #4 |
Rep 22
01-16-2022, 03:21 PM | #5 |
Rep 1,773
Seems like JP4 needs exclusive access to the OBD port.
https://f30.bimmerpost.com/forums/sh....php?t=1357744 |
02-19-2022, 10:26 AM | #6 |
Rep 22
Update on this challenge:
I purchased this OBD splitter (Amazon: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1) Make sure JB4 is connected first and on extension #1. Everything works well! Both JB4 Mobile and TrackAddict apps are working well, and you can switch JB4 maps and then record sessions using TrackAddict! Only caveat is that once you set the map you want, avoid switching back and forth between apps as that will kill your session in TrackAddict. Cheers! gec PS - JB4 map 3 and 5 (with the right mixture of E85) are making the xDrive M3 an absolute beast, which is amazing to say about a car that is already a freaking monster. Map 5 results with much more boost, and maybe slightly less smooth comparing to map 3. Both maps are pure joy! Just match the right map to your circumstances and driving style. Last edited by gec929; 02-19-2022 at 10:38 AM.. |
02-19-2022, 11:58 AM | #7 |
Rep 190,103
