04-12-2023, 07:54 AM | #45 |
Mad Linux Guru On The Loose
1122
Rep 5,399
Drives: 2008 335i Sedan, 2023 M3
For all of you who are experiencing idle stumbles, try Stabil ethanol stabilizer. Get the Marine one as its a higher concentration. Use 1oz per 10 gallons of fuel.
I have been using this additive in my N54 for over 8 years now and I've not needed to replace a single fuel injector in my N54 anymore. It truly works amazing. Prior to that, I was replacing one or two fuel injectors every spring. |
04-12-2023, 11:30 AM | #46 | |
Rep 509
04-21-2023, 04:39 PM | #47 | |
Rep 1,636
2023 M4 with 3000 miles and I have the same issue since new. The car is 100% stock.
MarkyB65676.50 |
04-21-2023, 04:45 PM | #48 | |
Rep 509
My long crank issue went away oddly enough. When the engine is warm instead of long cranks, sometimes it’ll start with a stumble, if that makes sense. I don’t know if I had a bad batch of fuel or what with the long cranks. I’ve always used 93 octane. I still have weird rpm jitters when the engine is cold and at times feel like the vehicle will stall when I put it in N coming up to a stop — almost like the rpm dips a little too low. I’m planning on using some sea foam to see if it helps. |
04-21-2023, 04:51 PM | #49 | |
Rep 1,636
Automatic. The long crank is very random at all temp cold or hot. The bouncy idle all the times but sometimes feels worse as if the car will stall.
04-22-2023, 08:18 AM | #50 |
1122
Rep 5,399
04-22-2023, 05:29 PM | #52 |
1122
Rep 5,399
04-30-2023, 09:12 AM | #53 |
Rep 1,636
The car is back from the dealer and as I expected they could not find any faults. They blamed the digital RPM indicator sensitivity for the bouncy idle which I respectfully disagreed because I feel it sometimes while stopping at red lights. The long crank didn’t happen in the last 2 weeks but still it is definitely longer than any M car I have ever owned. It seems to me sometimes as if the car is not recognizing that the key is inside
04-30-2023, 06:19 PM | #54 |
2130
Rep 3,368
Resting idle fluctuation on a s58 is completely normal, even after it's fully warmed up. Cooling system is extremely efficient and dme is doing it's best to keep the car warmed up at idle. My F97 has been doing this since new...especially noticable when filling the car up and it's sitting there idling in sport mode.
M4_ZMT597.00 |
08-24-2023, 03:12 PM | #55 |
Rep 446
Drives: '24 X3M Comp
Idle quality is crap, especially on cold starts when the oil hasn't reached nominal temp. You can hear/feel shudders or knocking occasionally which almost sounds like a misfire. Once car is warm and the gauge is sitting just under 1k RPM, no issues.
2024 F97 ///X3M COMP [AW/SO] Active Autowerke EL Mid Pipe + Axle-back | H&R Sport Springs |
09-04-2023, 04:36 PM | #57 |
Rep 145
Doesn’t feel rough, but see little fluctuations warm or cold at idle. Have had for over a year. Noticed the same thing on the F90 I had before. Always assumed normal.
09-04-2023, 04:48 PM | #58 |
BMWnation
425
Rep 514
These newer generation cars are much more sensitive given the tech/sensors monitoring a lot of parameters.
Have you all checked for codes? You would be surprise to see the car does throw codes, but it does not throw a CEL. it’s a bit weird. Check for codes and LMK what you find… |
09-04-2023, 10:09 PM | #59 |
1122
Rep 5,399
01-14-2024, 11:49 AM | #60 |
salty cowboys fan
6179
Rep 3,418
After a couple years and ~10k miles of perfectly smooth idling, I am loathe to report that my baby has started to shudder and have the RPMs jump. I’m inclined to think it’s not normal seeing as how it just started. No codes or anything, and runs fine under load, but def feels like a miss at idle. Might try swapping plugs soon. Usually run an E55 tune, but still doing it with a tank of (crappy) California 91.
01-14-2024, 02:48 PM | #61 |
Rep 940
Those of you with wonky idle, do you drive your car hard often (like redline it a couple of gears) or do you just drive around all civilized? Also, platinum plugs, especially ones geared towards a colder range due to a boosted engine, can foul up a little if you don’t ever just ring it out every once in a while. Iridiums will not be as susceptible to this issue if you change to them. (Not sure it stocks are plat or irid.) Additionally, DI engines will also form much more deposits on the intake valves if they don’t have secondary injectors on the intake plenum, when you constantly baby the engine. That too will lead to a slightly lumpy idle. If you’ve been babying it for a long time, go for a few harder drives for the next couple of hundred miles and see how things change after.
01-20-2024, 03:37 PM | #62 | |
salty cowboys fan
6179
Rep 3,418
Ready to have some ethanol back in the tank now, this thing feels sloooow
somer972.00 |
01-20-2024, 10:38 PM | #63 |
1122
Rep 5,399
Stabil won't fix idle issues. Stabil prevents degradation of ethanol blended fuels and thus acts ss a preventative measure, not a repair. I just wanted to make sure that's clearly understood.
yousefnjr6178.50 |
01-20-2024, 10:41 PM | #64 | |
Rep 2,166
rough idle when cold = race car The car is already smooth enough, so I'm OK with an uneven idle with a cold start, complete with some strange noises. Mine has been doing it from Day One, but it's never affected the drivability. |
01-20-2024, 10:54 PM | #65 |
2020 Z4 M40i - 2022 M4C Convt
3129
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
20,000+ miles good idle so far.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
02-02-2024, 04:47 PM | #66 |
Rep 26
Wanted to chime in here for any future readers. I had a F80 with the previous gen S55 and had that idle all the time. Drove it for 30k+ miles and never had issues. Now with my current G82 on the S58, it still runs like that.
I just chopped it up to BMW M quality! It is totally normal as well from what I can tell. Could just be because of a low RPM idle to reduce emissions, who knows.
2017 BMW M3 F80. AWE Exhaust w/ VRSF Downpipes and intakes.
