      04-04-2023, 01:43 PM   #1
Shaneartistry
Drives: BMW X5
question for 6MT drivers and clutch wear
Picked up my 6MT G80 recently. I’ve had a few manuals in the past and have always blipped the throttle before slowly releasing the clutch in 1st and reverse.
I realized on the G80 if you let out the clutch slowly in 1st and reverse on level ground, the vehicle will pull without stalling.
Which method is best for the vehicle?
      04-04-2023, 02:16 PM   #2
davidmct-M3
Drives: BMW 440i with MPSSK
When i had manuals for nearly 40 years I didn’t blop the throttle as you’d just spin up the clutch plate which would then slow via friction as the clutch was released. I used to put a little throttle (to avoid any stall) as the clutch started to bite then adjust throttle as necessary for speed needed.
Different strokes for different folks 🙂
2011ninja3399.00
      04-04-2023, 02:39 PM   #3
Chad11491
Drives: 21 IOMG M3 6MT
I've never blipped the throttle in first or reverse to get moving in any car, I've always smoothly engaged the clutch.
2011ninja3399.00
      04-04-2023, 02:40 PM   #4
Info@mad-us.com
Info@mad-us.com's Avatar
1924
Drives: bmw
These new cars have a pretty good antistall. I would let the clutch grab slightly before applying any throttle.
- Click Here
Performance Parts For Your Bmw At Crazy Low Prices!
Email: info@mad-us.com
2011ninja3399.00
      04-04-2023, 05:58 PM   #5
fanofbmwe46
Drives: M3
On all my prior bmw manuals I’d blip it just a bit a millisecond before letting out clutch to grab point. Never needed a clutch replaced. Even after 100k miles driving and this tactic
      04-04-2023, 06:40 PM   #6
Asindhidude
Drives: G80 6MT. Brooklyn/Fiona
Same. In routine driving, usually just let out the clutch slowly. No need for throttle.
2011ninja3399.00
      04-04-2023, 08:10 PM   #7
weingarm
weingarm's Avatar
857
Drives: M3
No throttle blip necessary in 1st or reverse. Never had any problems doing it this way.
2023 M3: Isle of Man Green
2021 X7 40i: Phytonic Blue
2011ninja3399.00
      04-04-2023, 08:57 PM   #8
bhmax16
Drives: '22 M4, '23 CX-50
I've never "blipped" the throttle in any manual vehicle and I've been driving manuals exclusively for the past 22 years. Apply throttle normally and smoothly engage clutch. This is anecdotal, but I have had a 2007 328xi for the past 12 years as my beater and it's still on the original clutch at 153k miles.
Past: '97 Nissan Maxima, '95 Jaguar XJ6, '03 Yamaha R6, '08 Ducati 848, '14 Ducati 899, '07 BMW 328xi
2011ninja3399.00
PLF693767.50
      04-04-2023, 09:12 PM   #9
Higgy_CSL
Higgy_CSL's Avatar
Drives: 23 M4 CSL/ 23 M2 / 24 X5 M60
2023 BMW M4 CSL  [9.33]
2023 BMW M2  [10.00]
2024 BMW X5 M60  [10.00]
I don’t have any good comments to your question, however I will let you know that if you are worried about clutch wear just an FYI… clutch is not covered under warranty as it is considered a wear item. You must purchase an extended maintenance package for coverage. If you are interested in an extended maintenance package PM me as I will give you a good deal and it’s a no brainer as long as you don’t add a bunch of power adding mods.
      04-05-2023, 08:02 AM   #10
Shaneartistry
Drives: BMW X5
All good. I figured clutch isn’t covered. I don’t keep my vehicles long enough to worry about extended warranties. I was just curious to hear how others engage the clutch.
      04-05-2023, 03:45 PM   #11
MichaelB1969
Drives: 2023 G80 Base SSG/Fiona
What he said. I've driven a manual for ~30 years and never "blipped" the throttle upon takeoff. Sure, I blip it for heel and toe downshifts, but never to get the car moving from a start.
Normally I let off the clutch until it gets close to it's catch point, then from there I let off the clutch more smoothly while applying enough throttle to ensure a smooth takeoff.
When done right, you shouldn't feel like you are "riding" the clutch at all. Nor should you feel like you've had to apply excessive throttle (which would then require you to ride the clutch to ensure a smooth takeoff).
