08-28-2022, 01:59 PM | #1 |
Rep 728
Is the R8 worth the extra $250 over the R7?
I am a newbie to radar detectors. I am not going to be doing a lot of integration or apps or anything like that.
I want something to hang under the rear view mirror and tell me if radar is up the road. I don’t want to buy power user features if I am not going to use them (and I am probably not). The most I will do is use it along with Waze on CarPlay. Based on that is the R8 worth $250 over the R7. I am seeing the R7 for $479 and a $25 discount, while the R8 is $699.
BMW M3 Competition xDrive, Dravit Grey over Tartufo
09-05-2022, 04:34 AM | #2 |
Rep 353
Well, it is the latest and greatest. Besides what is improved internally, the mute/dim button is on the front of the R8 instead of on top on the R7. It's not the end of the world, but if you're using a blendmount under your mirror it is an inconvenience to have to pull down the front of the detector to reach the buttons on top.
2022 Aventurine Red M4 Comp X-Drive
09-05-2022, 09:33 AM | #3 | |
Rep 728
The mute memory button is on the left side (which I used a lot the first several days…) and takes squeezing both sides of the detector between thumb and index finger. Not a huge deal. Once programmed I am not sure I will ever touch the buttons on top. It seems like that is more of a stationary use, and not while driving. I did get the specific Blend Mount for the R7 and it is awesome. Great fit and a very low profile mount in relation to the mirror.
09-05-2022, 10:13 AM | #4 |
Rep 353
Yeah, I forgot the side vs top button arrangement. I’m loving my R8 and the Blendmount and mirror tap are excellent. I wasn’t sure about tackling the mirror tap on my own. I’m glad I gave it a try. Even though it took me longer than others, thanks to numerous YouTube videos and forum members I got it done.
09-05-2022, 10:58 AM | #5 | |
Rep 728
I routed the cable through the center split, under the detector hanger, and across the top of the detector. Doing it that way the power cord is almost hidden. I have seen some cords hanging down from the side of the mirror trim cap and the center routine is a lot cleaner install.
09-05-2022, 04:52 PM | #6 |
Rep 619
Sorry, can't help to decide between R7 vs R8.
But I thought this might be useful in your consideration. I have an R7 with a remote. I mounted the remote on the top of the steering column in front of the dash cluster. It's super convenient that I can hit the mute button easily without fumbling trying to press a button on the radar unit. As an added bonus, the LEDs are right in front of my line of sight. |
09-05-2022, 11:11 PM | #7 | |
Rep 728
https://www.amazon.com/Uniden-RDA-HD.../dp/B07BBVC7JQ
09-05-2022, 11:14 PM | #8 | |
Rep 353
09-05-2022, 11:51 PM | #9 | ||
Rep 619
09-05-2022, 11:55 PM | #10 | ||
Rep 619
I ran the cables under the dash, tapped the power from the cigarette lighter from the center console and tucked the radar cable along the weather stripping on the A-pillar. It virtually looks "stock". |
Chubbiejones891.00 |
09-06-2022, 06:55 AM | #11 |
Rep 353
I think if I had the R7 I might give that a go? As of now I'm very pleased with my current setup.
09-06-2022, 07:02 AM | #12 |
Rep 728
The mute button on the side does not irritate me enough to go through all that. It certainly didn’t irritate me enough to spend another $250 on the R8.
