04-10-2024, 05:28 AM | #1 |
Rep 715
Battery Management Error
I recently did the update for my 24 g80 comp and the next day after it was finished I went to start car and got " battery management error" I keep it on a trickle charger usually so the battery was definitely not drained. Im assuming it has something to do with the update and the car not turning off fully. Thanks
04-10-2024, 09:05 AM | #4 |
Rep 1,311
Drives: 2024 BMW M4 Base
I get that when I leave my radar detector on via a mirror tap. I just turn off my radar detector prior to turning the car off.
Do you have any accessories that require power or just since the update? |
04-10-2024, 09:23 AM | #5 |
Rep 715
No accessories and battery had a full charge prior to the car doing the OTA update.. probably just a glitch but just wanted to see if anyone had a similar experience.
04-10-2024, 09:25 AM | #6 |
Rep 874
Most likely a glitch. Take the car out for a spin and the error should go away on the next startup.
Speed & Tech Motoring
23585 Overland Drive, Unit 178 Sterling, VA 20166 (Headquarters) 23541 Pebble Run Place, Unit 140 Sterling, VA 20166 (Satellite shop) |
