02-22-2021, 03:03 PM | #23 |
The Tanzanian
1317
Rep 1,508
Drives: BMW M3, Audi RS6, Mini Cooper
I know we can nitpick and lament a lot that we are hearing but these videos just keep reminding me how much I love this product (the M3 and M4). It is crystal clear that they care about it (and our experience of it) so much despite also having to work within certain business constraints.
2023 F56 MINI Cooper SE Midnight Black II on Carbon Black 2021 C8 Audi RS6 Avant Mythos Black on Black/Grey 2016 F80 BMW M3 Black Sapphire Metallic on Silverstone |
02-22-2021, 03:04 PM | #24 |
Rep 4,709
You asked for a BMW color, and they suggested a Porsche color?
02-22-2021, 03:33 PM | #25 | |
Rep 97
02-22-2021, 08:23 PM | #26 |
General
21117
Rep 20,741
Drives: 2021 911 turbo
I think that was one of the better videos. It shows that good effort was made to stiffen the G8X chassis so that suspension tuning can be optimized.
As far as chassis stiffening, I don't see it as a meaningful upgrade compared to the F8X though. When they specify that they improved something, it is not clearly stated over which baseline. I interpret that it is over the base G2X series and not necessarily over the F8X. However, if the G2X chassis is stiffer than the F3X chassis, they do have a better starting point. The picture below illustrates the F8X stiffening elements. From what I observe, the F8X has re-enforcing between the strut tower and A-pillars at the top of the structure, which the G8X does not seem to have. It could be the reason they added structural elements that connect the front subframe with the side frame rail at the bottom of the structure on the G8X (that the F8X does not have). They also mention that the steel was the best material for the front structure due to the limited space (not enough room for a CF structure), so I doubt we will see a lightweight structure even on a CS or CSL version unless the under-hood area is significantly revamped. They do specify that the rear subframe is rigidly mounted to the uni-body of the G8X, just like on the F8X, which is a good thing. As depicted below, the F8X also has connecting elements between the rear subframe and the side frame rails. As for the suspension, it looks like an evolution of was found on the F8X. The F8X also had bespoke elements made of aluminum.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 02-22-2021 at 08:42 PM.. |
02-22-2021, 08:47 PM | #27 |
9052
Rep 7,621
They REALLY need to do these in landscape instead of portrait. I know the theory is that people are watching on their phone, but I'd much rather turn my phone sideways to see more
02-22-2021, 09:04 PM | #28 |
Rep 5,110
The head of driving dynamics development appears to be driving on a closed course at 10 and 2. Uh huh.
frankiebones5299.00 |
02-22-2021, 10:37 PM | #29 | |
Rep 1,584
02-23-2021, 05:10 AM | #31 | |
Rep 3,056
SMB M3 CS (gone) YMB F80 6MT (gone) |
02-23-2021, 08:19 AM | #32 | |
Rep 168
It may be too stiff for daily use. If its anything like the current X3M competition then expect a stiff punishing ride, even on comfort mode. |
02-23-2021, 08:42 AM | #33 | |
Rep 233
Chassis stiffening makes ride SMOOTHER, not stiffer, just FYI. |
SYT_Shadow11479.50 |
02-23-2021, 10:43 AM | #35 | |
Rep 3,056
02-23-2021, 11:14 AM | #37 |
Rep 4,392
Drives: 2022 F97 X3M Comp LCI
all this mentioning of “stiffening” and now im nursing a semi.
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
PABrian149.50 |
02-23-2021, 11:42 AM | #38 |
Rep 855
I always thought BMW used a system from Sachs (since the e9x generation).
02-23-2021, 12:19 PM | #39 |
General
21117
Rep 20,741
Funny. I tend to use objective technical observations to form an opinion, not emotions. So half full or half empty, to me there is still the same amount in the glass...
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 02-23-2021 at 01:54 PM.. |
JTO245274.50 frankiebones5299.00 |
02-23-2021, 12:21 PM | #40 |
General
21117
Rep 20,741
Agreed. Most likely because the base G2x chassis is stiffer than the base F3X chassis and not necessarily because there is more/better bracing in the G8X. Just the fact that the G2X is larger than the F3X makes it stiffer in bending and torsion.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 02-23-2021 at 12:37 PM.. |
02-23-2021, 01:53 PM | #41 | |
Rep 3,056
02-23-2021, 02:03 PM | #42 |
General
21117
Rep 20,741
15% Hmmm...
Interestingly, IIRC, the G20 was quoted to be 25% stiffer than the F30...
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 02-23-2021 at 03:01 PM.. |
02-23-2021, 03:29 PM | #43 |
Rep 781
02-23-2021, 05:24 PM | #44 |
///M Powered for Life
11480
Rep 10,328
In the end it's pretty irrelevant if the difference between one generation's regular 3 series to the M3's rigidity gap is larger or smaller. What matters the most when comparing dynamics between two M3 generations is how rigid they are vs each other.
The G8X M3 is, as expected, significantly more rigid than the F8X generation. I mean seriously people, the hate is strong with the people who doubt this was an evident conclusion.
