09-12-2023, 06:01 PM | #133 | |
Rep 477
Twin organic, dampener and basic flywheel. It comes with a tob(low setting) and hardware. No alignment tool if you’re tackling it yourself. |
mattssi880.50 |
09-12-2023, 06:24 PM | #134 |
Rep 1,367
Yeah, that's awesome.
2021 ///M3
2019 X3 |
09-18-2023, 01:36 PM | #135 | ||
Rep 236
I hit PTB up to ask a few question on the material options, they came back w
09-18-2023, 02:23 PM | #136 | |
Rep 22
10-28-2023, 10:46 AM | #139 |
Rep 236
11-01-2023, 02:10 PM | #141 |
Rep 236
The suspense! Anyone else go organic/sinter and have some feedback vs stock? If it's a minimal difference I think most people would be interested in having the buffer. Mostly wondering, on DDs with modest targets, is organic/organic best for streetability.
11-02-2023, 05:03 AM | #142 |
Rep 22
Sorry about that, got busy and forgot!
I love it. Compared to stock the clutch pedal is a little heavier(which I prefer and the stock clutch pedal in my ‘17 m240i is still heavier), maybe 10-20% enough to be noticeable, but not so much that I would hesitate to drive it daily and in traffic. Starting from a stop requires a bit more finesse due to the grabby nature of the ceramic disk, but wasn’t a problem for me since I’ve had harder clutches in my old Evo. I’m currently on BM3 stage 2 ots and the clutch doesn’t break a sweat launches, clutch kicks, rolling antilag it doesn’t matter. There is some extra noise transmitted into the cabin now, but I don’t know if that is the clutch or the short shifter w/ solid shifter bushings I had installed at the same time. With that said I definitely recommend the clutch to anyone that wants to push the car. I plan on going custom flex fuel tune next summer and have full confidence it will hold all the power I can throw at it especially on stock turbos. |
11-02-2023, 08:58 AM | #143 | |
i can haz horsepowr ??
3851
Rep 1,938
I’m at 1k miles on my PTB clutch and am enjoying it. I went with standard pressure plate and organic/sinter. I’ll be testing its limits next year as winter draws near in the northeast. For those that are considering it - it’s a no brainer. Just let the clutch break in for about 400-500 miles and take off any clutch stop you have (or decrease the number of washers) and you’ll enjoy not slipping. I found the engagement right after installation with all the washers on the BMS clutch stop made for far too little travel, so taking out two made a big difference.
Dakar Yellow G80 M3
mathys202.50 |
11-08-2023, 12:57 PM | #144 | |
Rep 134
This is good to hear seeing as its the config I went with. I'm hoping mine will ship any day now. I placed my order knocking on two weeks ago. |
11-20-2023, 05:28 PM | #145 | |
Rep 570
Turns out the clutch got worn to a point where it really started to piss me off, so I reordered the same configuration. Lol. Will post my feedback once it arrives and I have it installed. |
11-21-2023, 02:08 PM | #146 | |
Rep 134
Tall Tom Cruise1006.00 |
11-21-2023, 02:10 PM | #147 |
Rep 134
Side note, anyone know of an alignment tool that will work with this platform? I'd planned on doing it myself at a buddy's shop, but wasn't sure if any ole universal alignment tool would do the job.
12-20-2023, 09:27 PM | #148 | |
Rep 35
How is the CM clutch holding up, I saw they have some new pressure plate on the unit, did you get the black pressure plate or the white? |
mattssi880.50 |
12-26-2023, 11:52 AM | #149 |
Rep 15
10K mile update on the PTB-R dual disc clutch: I’ve abused the living hell out of this clutch and it still performs flawlessly! Looking forward to the next 10K. #advocatehere
Link: https://www.ptb-shop.de/g80clutch.html |
NicolasB809.50 |
12-26-2023, 02:24 PM | #150 | |
Not my first rodeo
810
Rep 481
12-26-2023, 04:40 PM | #151 | |
Rep 15
The only con I have is about the chatter, but chatter is to be expected having a dual disc. It’s not that bad, but it is noticeable. |
NicolasB809.50 |
12-28-2023, 11:29 AM | #152 |
Rep 134
I just wanted add my 2 cents now that my clutch has been installed and is working. I do a lot of dig racing so I opted for the O/S/P config. The instructions that came with my box referenced the standard pressure plate option, and there are some differences.
First, the upgraded pressure plate is not equipped with a SAC system, so the whole press and spring adjustment step does not apply. Second, the instructions tell you to install the throw out bearing on the "low" setting. If you do this with the upgraded plate, it will not disengage and you will overextend your slave cylinder--ask me how I know. The clutch stack is shorter with the upgraded plate, because it is nice and flat. Install your throw out bearing on the "high" setting marked with a diamond. Hopefully this saves anyone else from all of the trial and error I've had to go through. |
NicolasB809.50 |
12-29-2023, 04:16 PM | #153 |
Rep 134
Adding to this thread again..
I wasn't able to pick the car up yesterday after work, so it stayed at the shop. Today, they drove the car to see how the clutch was holding up, and now its slipping under normal driving conditions. I'm at a complete loss on what to do with this clutch system. Has anyone else actually installed the performance plate on their cars with no issues? And PTB hasn't answered my emails regarding the incorrect throw out bearing setting, so they haven't acknowledged the fact that they gave me wrong information. |
