04-16-2024, 10:36 AM | #67 | |
Rep 2,052
04-16-2024, 01:31 PM | #68 |
Rep 617
kgelfen3602253.00 |
04-17-2024, 08:09 AM | #69 |
Rep 6,758
Caveat: have worked on many brakes, including similar to the M3, but not done the M3 yet (for obvious reasons).
To retract the pistons, I usually use a large screwdriver wrapped in a towel. Lever against the caliper and push the pistons back. Pretty basic, but it has always worked. Just go slowly and retract the pistons evenly. |
kgelfen3602253.00 |
04-18-2024, 02:45 PM | #70 |
Rep 2,052
Needsdecaf DoubleDave
Have u guys tried applying Liquid Molly Brake Anti-Squeal Paste during new pad install? Any comments if needed or not? https://a.co/d/bfjbZPp Thanks |
04-18-2024, 04:20 PM | #71 | |
Rep 961
04-18-2024, 04:21 PM | #72 | |
Rep 961
kgelfen3602253.00 |
04-18-2024, 08:11 PM | #73 | |
Rep 617
04-19-2024, 08:29 AM | #74 | |
Rep 6,758
04-19-2024, 09:03 AM | #75 | |
Rep 1,281
04-19-2024, 09:27 AM | #76 |
Rep 126
04-19-2024, 05:07 PM | #78 |
Rep 6,758
04-19-2024, 05:09 PM | #79 |
Rep 2,052
04-20-2024, 05:11 PM | #80 |
Rep 6,758
04-24-2024, 12:04 AM | #82 |
Rep 2,052
SwankPeRFection Berzerker Needsdecaf
turbojg Hey guys need some help: I did the iSweeps myself. Install pretty straight forward. For the rear: I used BimmerLink: - Diaggnostic mode (3 clicks of start button) - BimmerLink - break service mode activated. Heard the motor unwind - changed the pads - BimmerLink again - deactivated service mode. Heard motor wind back. - I then pressed break button in the car without pressing brake pedal and got an error I then started the car and tried break and it engaged and disengaged no problem. I shut the car off and tried break and gives me an error ???? So basically if the car is running break engages just fine but when it’s shut off and I try to do parking break it gives and error (and I hear long winding noise) Any suggestions ??? |
M4Tejas797.00 |
04-24-2024, 08:22 AM | #83 |
Rep 6,758
Try this??
https://g80.bimmerpost.com/forums/sh....php?t=2098756 Sorry, I have not done mine yet so no help. |
04-24-2024, 09:59 AM | #84 | |
Rep 2,052
I did not mess with the EPB whatsoever during pads exchange. I basically removed caliper put new pads on and put caliper back on. All while using BimmerLink to activate break service mode and deactivate it. I did not compress piston either during exchange (did not need to) So what I noticed now is if I try to engage parking break without my foot on the break I hear long winding noise of the EPB and get an error. If I have the foot on the break it operates normally??? SwankPeRFection any advise man? |
04-24-2024, 01:19 PM | #86 |
Rep 497
Sp2pilot170.00 MaC-N54-E82488.00 |
04-24-2024, 10:14 PM | #87 | |
Rep 272
For bedding in, I didn’t for a while, and eventually did a typical bed in procedure once I was able to get out on a quiet road to do it. |
