      07-27-2023, 07:54 AM   #45
Salter
Drives: M340i
Originally Posted by The_RGNBULL View Post
So I have ID8 and "disabled" ASD via Bimmercode in both options; standard AND expert mode.
Is disabling ASD reduced "noise" levels in the cabin? Is it literally quieter?
Thanks!
      07-27-2023, 08:18 AM   #46
The_RGNBULL
Drives: 2023 M3 Comp Xdrive
Thanks!
Yes, it "disables" the fake engine sound pumped in via the speakers so you will hear the actual engine/exhuast.
Although I'm still not convinced it turns it off 100%
Salter26.00
      07-27-2023, 08:56 AM   #47
Salter
Drives: M340i
Gotcha. Thanks for this. I will totally understand if this questions is difficult to answer, but I'm wondering if you could roughly estimate what the overall reduction in cabin noise as a result? Would you say 10% or so? Thanks in advance.
      07-28-2023, 07:41 AM   #48
The_RGNBULL
Honestly for me, I didn't notice much of a difference at all. Granted, I have a full aftermarket exhaust...
      07-28-2023, 08:28 AM   #49
FloridaM5
FloridaM5's Avatar
Drives: 2021 M3 Comp RWD
  [5.83]
If your exhaust is stock, I would say 80% noise reduction. It was such a change that when I turned it off before I'd modified the exhaust (valve controller first, and then Dinan x-pipe), it was too quiet...turned it back on until I did the mods. Now turned it back off. Much better.
      08-01-2023, 08:03 AM   #50
twistedmorphine
Drives: M3 Competition
Out of curiosity, what kind of difference does it make in comfort mode with stock exhaust?
      08-20-2023, 04:27 PM   #51
Anthony4579
Drives: Audi S5
I did the software update today and it restored my ASD. When I went back in with BimmerCode to code it off again I noticed there are two ASD sections (hadn’t noticed before). One is just basic ASD. The. Below is a section for M3/M4 that has separate options for Startup, Burbles, etc. what has everyone done with the additional ASD options? Have you also turned those off?
      08-21-2023, 10:34 AM   #52
TheFwed
TheFwed's Avatar
24
Drives: M3 xdrive Comp
I turned all of them Off in expert. If I only turn Off the basic ASD, it doesn't do anything (= I can still hear the fake sound )
      08-29-2023, 09:34 AM   #53
Skyroller
Drives: BMW M2C
I turned all off and deactivate the code, but if I turn the engine to sport mode or sport plus, the sound comes out again, need to switch off manually.
      12-16-2023, 03:00 PM   #54
cristobald888
Drives: X3 20d, M340d, M3 Comp
Does Bimmercode allow coding the exhaust button so it is always on/off at car startup ?
My M3 is still on the way but I'm already exploring the options
      12-16-2023, 11:44 PM   #55
Berzerker
Are you talking about the center console button? I believe that stays in the way you set it, either on or off. M1/M2 are able to turn it on or off. You can set them to be off, and press it off in non-M1/M2 efficient mode, and it should just always be off. Otherwise it's always on.
      02-09-2024, 07:38 AM   #56
bmoss1610
Drives: 2021 M2 Comp; 2022 M5 Comp
Originally Posted by Zircon View Post
Disabling ASD removes the fake sound from the speakers and also improves music quality by a bit.
The button controls the exhaust valves. If the valves are closed, the car will be a bit quiter. When the button is lit, it allows the valves openess to be modulated in order to improve exhaust sound and make burbles.
The button also controls the fake sound, not just the valves. The valve setting is controlled by the throttle mode in iDrive and the fake sound is also linked to that. If you have everything in Sport Plus and you press the button it will close the valves and turn off the fake sound. I installed a valve controller to separate that function and coded ASD off with bimmercode but there is still some fake sound unless I press the M Sound Control button which does turn it off. Bimmercode now also has separate toggles for some of the other sounds like burbles, haven’t played with that yet.
      02-09-2024, 09:03 AM   #57
jimbethesda
jimbethesda's Avatar
Drives: M3 (F80)
Not correct. Fake noise is always on unless you code it permanently off.
https://www.bimmerpost.com/forums/sh...php?p=28491968
2001 330Ci (sold)
2007 335i (sold)
2008 E90 M3 (sold)
2015 M3 (sold)
2022 G83
      02-18-2024, 07:01 AM   #58
ChrisM4
ChrisM4's Avatar
Drives: 2024 M4 Comp X-Drive
What Bluetooth OBD2 adapter are you guys using with the latest rev of BimmerCode with an IOS device?
https://bimmercode.app/adapters/?series=g
      02-18-2024, 06:04 PM   #59
Berzerker
None. Get an ethernet ENET adapter w/ a USB-C or Lightning (Depending on your phone connection) to ethernet adapter. It's much much quicker and more reliable of a connection than BT.
      02-18-2024, 06:17 PM   #60
ChrisM4
ChrisM4's Avatar
Sorry I mean wifi OBD2 adapter. Which wired connector would you recommend for IOS?
Thanks!
      02-18-2024, 08:08 PM   #61
Berzerker
Thanks!
Any of the ENET OBD to Ethernet ones should work fine. You just need the right Ethernet adapter. Either get a Lightning one (MFi certified) if you're on a 14 or older, or any Ethernet to USB-C adapter if you're on a 15.
ChrisM41621.50
