      01-23-2023, 12:37 PM   #45
Vmaxx
Drives: 2021 M340i xDrive
Originally Posted by jimbethesda View Post
The law was changed with the infrastructure bill. Not sure what else needs to happen in order for BMW to push this feature out to their cars.
The law changed, but US requirements are still more stringent than other countries. US requires higher refresh and scan rates from anti-dazzle equipment, which differs from other countries, so it may require more than just coding or software from BMW because it seems those requirements maybe beyond current hardware capabilities.
      01-23-2023, 04:23 PM   #46
Limegrntaln
Limegrntaln's Avatar
The bill was passed. I think they actually have until the end of 2023 to complete the verbiage and laws and legislation on it. And we still wont get the ultra high intensity. The lighting output is still being held back to the 1970 standard of light output.
https://www.nytimes.com/2022/02/18/b...eadlights.html
YT: G Dubyou
      01-24-2023, 07:05 AM   #47
beachBmmr
beachBmmr's Avatar
Drives: 2023 F90 M5 SG/AB
So I did Bimmercode anti-dazzle and had a drive last night. Most noticeable was the left to right sweeping based in steering angle. Tunneling was not so obvious but the car definitely lit up the sides without oncoming cars, and seemed to light up around the car ahead.
High beams on street signs are obnoxiously bright, and the car seems to know this and switches them off when there are a few bright reflective signs, its actually irritating to my eyes, so I appreciate it.
Overall worth the 5 mins it took.
2023 F90 M5
Retired - 2021 G82, 2019 440xi, 2020 X7, 2019 X5, 2013 F10, 2010 F10
      01-24-2023, 02:35 PM   #48
Unimatrix0
Unimatrix0's Avatar
74
Drives: 2022 M4 Comp
Nice to know!
You did the coding with Bimmercode?
What coding did you use?
      01-24-2023, 02:58 PM   #49
Team Tonka
Drives: 2022 G80 M3 xDrive Comp.
Someone should do a video on how to exactly do this via Bimmercode for us novice folk. Pretty Please, and thank you.
Or at least a bunch of screen shots.
Dnshift156.50
      01-24-2023, 03:35 PM   #50
beachBmmr
beachBmmr's Avatar
Originally Posted by Unimatrix0 View Post
Nice to know!
moproblems guide-
https://www.bimmerpost.com/forums/sh...php?p=27650517
2023 F90 M5
      01-29-2023, 02:45 AM   #51
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Originally Posted by thegrandfacade View Post
Almaretto - are you still doing this coding? sent you a PM a while back but perhaps you didn't see it
Yes, still coding. Not my regular day job, so response is sometimes delayed.
      01-29-2023, 02:57 AM   #52
thegrandfacade
thegrandfacade's Avatar
9
Drives: 2022 M4 Comp RWD
Understood! Will send a follow up PM now.
      01-31-2023, 02:38 AM   #53
BrooklynGreyM3
///MFlight Member
BrooklynGreyM3's Avatar
454
Drives: 2022 BMW M3CX G80
Question about warranty.. If anti-dazzle is coded I assume this will make the brights turn on more than usual. I read on various other threads this can cause the headlights to get hotter than normal. That being said, this would cause the headlights to burn out faster. If you take it to service, BMW will see you coded anti-dazzle so the headlights won't be covered under warranty.
I also saw a YouTube video where a guy coded his X3 to have a different instrument gauge cluster and his BMW service center wanted to void his entire warranty.
Do any of you have any factual experience with any of the above?
Current - 2022 M3 G80X Competition/Brooklyn Grey/Silverstone
- 2022 X3 M40i/Brooklyn Grey
Sold - 2021 M3 G80 RWD Competition/Brooklyn Grey/Merino Black
Follow Me on IG: BrooklynGreyM3
      01-31-2023, 08:43 PM   #54
Almaretto
Almaretto's Avatar
2374
If coded incorrectly, then yes, they can burn out and fail quicker.
Dealership does not have ability to see coding changes (only behavior), unless they call in specialist, which would have to prove coding resulted in fault.
      02-01-2023, 08:38 AM   #55
aktif8
Drives: 22 M4c vert
Originally Posted by Vmaxx View Post
Has anyone tried the below coding? Someone else posted in another thread that claimed better anti dazzle performance and all accessible via bimmercode.
7083 AL_MODE_ECO: LOW_LEVEL_3_DIPB[03]
7083 LIN_VARIANTE_SZL: szl_r_HW_aic_4Band_fla [30]
1DF8 C_AFS_ECO_LEVEL_3_ENA:enable
1DF8 C_AFS_ENA: enable
1DF8 C_BLC_PRE_ENA:enable
1DF8 C_CLC_BLINK_ENA: enable
1DF8 C_CLC_CURV_V2: ECE
1DF8 C_CLC_CURV_V3: ECE
1DF8 C_CLC_EXT_ENA: enable_roundabout
1DF8 C_CLC_REV_ENA: enable
1DF8 C_HBA_GFHBA_ENA_V_HI: standard
1DF8 LUT_AFS_CODRV_HOR: G05_Laser_ECE
1DF8 LUT_AFS_DRV_HOR: G05_Laser_ECE
1DF8 LUT_FLC_FORWARDLIGHTING_Y: AFS[00, 00, 00]
C_HBA_DIM_DELAY: default [0A]
C_HBA_DIM_ENA: enable [01]
C_HBA_DIM_MAX_DIFF: default [02]
C_HBA_DYN_RESERVE_LOWER_MAX: default [FB]
C_HBA_DYN_RESERVE_UPPER_MAX: default [0A]
C_HBA_ENA_V_HI: standard [28]
C_HBA_ENA_V_HYST: default [0A]
C_HBA_FILT_BND_BOT_DEC: default [05]
C_HBA_FILT_BND_BOT_INC: default [19]
C_HBA_FILT_BND_HOR_DEC: default [05]
C_HBA_FILT_BND_HOR_INC: default [19]
C_HBA_FOG_ENA: default [01]
C_HBA_GFHBA_ENA_V_HI: standard [3C]
C_HBA_GFHBA_ENA_V_HYST: standard_10_km/h [0A]
C_HBA_GFHB_HGWY_ENA: default [01]
C_HBA_HOR_BND_F_INC: default [07]
C_HBA_HOR_BND_OFF: standard_04_deg/s [28]
C_HBA_HOR_OFF_VEL_HI: standard_11_deg/s [71]
C_HBA_HOR_OFF_VEL_LO: vel_6_9_deg/s [47]
C_HBA_HOR_OLAP_CODRV: 2Grad [15]
C_HBA_HOR_OLAP_DRV: 2_grad [EB]
C_HBA_PREV_REA_ONC: default [00]
C_HBA_SWITCH_DEL_T: default [05]
C_HBA_TAU_EX_HGWY_ENA: default [01]
C_HBA_TAU_EX_HGWY_L: default [F6]
C_HBA_TAU_EX_HGWY_R: default [0A]
C_HBA_TAU_EX_L: default [...]
I tried this after the 7/22 update - all coded successfully, but anti dazzle no longer works.
My suspicion:
In the "base" coding (which i had applied before, and it worked) these values are different:
LUT_AFS_CODRV_HOR Laser_US/G007_US standard/init
LUT_AFS_DRV_HOR Laser_US F040_G005_AHL/G015_G020_Laser
*however* post 7/22 the co-driver whore (sorry, I'm 12) target value no longer exists. It's just laser_us. I re set these 2 values - verified all else is set. Let's see if it works. Will report back tonight.
FISH225402.50
      02-01-2023, 08:17 PM   #56
aktif8
Drives: 22 M4c vert
My suspicion:
Yep, for.anyone interested, using the posted "new" version works if you use the "old" values for driver and co-driver whore. My antidazzle is back!
Unsure if the new coding makes a substantive difference, but it can't hurt?
FISH225402.50
Aalfred2607.00
M4Tejas788.00
      02-02-2023, 01:23 AM   #57
BrooklynGreyM3
///MFlight Member
454
Do you think the new coding gives you the same results as you would get with ESYS such as tighter tunnel beams and better results with the lights reflecting off things like street signs and such?
What (if any) difference do you see between the old coding and the new one? Thanks.
      02-02-2023, 02:18 AM   #58
Almaretto
Almaretto's Avatar
2374
Definitely does not offer they came effectiveness as if you code FLM and KAFAS.
KKSigs1267.50
Limegrntaln13469.00
      02-02-2023, 07:50 AM   #59
aktif8
Drives: 22 M4c vert
I had the full fat coding on my last car, and it's definitely better at understanding what a reflection is vs what's a car driving towards you.
I just had a quick drive last night, but even the revised coding is still very aggressive in shutting down the high beams upon street sign reflections
Limegrntaln13469.00
      02-03-2023, 03:06 AM   #60
BrooklynGreyM3
///MFlight Member
454
Could you repost the entire new coding with the values you used to make it work? Based on your comments I wanted to verify that you made this work with the 7.22 update?
FISH225402.50
262Hou49.00
      02-04-2023, 02:59 AM   #61
Almaretto
Almaretto's Avatar
2374
Maybe you need some more adjustments.
      02-07-2023, 01:37 AM   #62
BrooklynGreyM3
///MFlight Member
454
So I had Steve from "Code My Bimmer" code in anti-dazzle for my 2022 X3 M40i (LED Lights) and my 2022 G80 (Laser Lights). It took him about 20 minutes to do each vehicle. I won't advertise his exact fee for this but I can say he charged me less than $100 per vehicle.
I tested it out and it was amazing to see the lights do their magic. I highly recommend Steve. Communication was great the entire time from start to finish to include appointment confirmation via WhatsApp.
Go check him out: https://www.codemybimmer.ca/
Malloy985.00
G80e0.00
      02-08-2023, 12:13 AM   #63
Forzanerazzurri
6918
Drives: E46 M3 Coupe/G80 M3CX
Just to confirm after this is coded do the hi beams stay on all the time when in the city or is this only when the auto hi beams would normally come on (ie outside the city).
      02-08-2023, 01:15 AM   #64
Almaretto
Almaretto's Avatar
2374
No. They will turn on/off and independently dim based on ambient conditions.
Limegrntaln13469.00
      02-11-2023, 07:14 PM   #65
willywilson
Drives: G82 Comp Xdrive (ordered)
There is a line item on my 2023 M4 build sheet (yet to take delivery) for anti dazzle coding. not sure what that means.
      02-11-2023, 07:15 PM   #66
Almaretto
Almaretto's Avatar
2374
Means it is disabled
