10-04-2023, 09:31 PM | #46 |
Rep 2,021
What’s weird is they do the orange in the light and that stupid orange marker in the fender. These are US requirements. But why can’t it be that the orange side marker is enough. It’s easy to get rid of that one. Why did they do the light as well.
Malloy985.00 |
02-20-2024, 10:49 PM | #47 |
Rep 867
Drives: OG M2
Bumping this up - does anyone know the definitive way to turn off the sidemarkers on an iDrive 8 G8X with lasers? I tried messing with the LMM1 settings in the FLE modules but it didn't work
OG M2 with the OEM M mirror retrofit
pdjafari151.50 |
03-02-2024, 04:07 PM | #48 |
Rep 867
Drives: OG M2
Anyone? lol
03-03-2024, 12:47 PM | #49 | |
Rep 1,286
03-03-2024, 01:07 PM | #50 |
Rep 867
Drives: OG M2
I don’t like paying for coding lol - I’ll just tinker til I figure it out
03-29-2024, 12:53 PM | #52 |
Rep 167
This can be done through Bimmer utility guys super easy to do use the following
Coding out the Side marker Lamps G82 M4 go to FLM2 - there is a Left and Right Side so you will have to do both - Search Duty: you will see the following LM03_DUTY_CYCLE_BINNING_CLASS1 through 4 - you need to change the Values from Wert_2( C8) to Wert_1(00) to all of them and there you go side marker lamp deleted |
04-01-2024, 09:59 AM | #53 | |
Rep 2,614
thatguyM4187.00 |
04-01-2024, 10:02 AM | #54 |
Rep 167
Yeah you don't need too I double checked and it worked flawless also did the added steps for anti dazzle and it worked.alot better not so crazy sensitive and stays on longer .works great though
04-10-2024, 11:12 AM | #55 |
You got my money?
3156
Rep 4,646
Drives: Ice Cream Truck
Whats this bimmer ulitity? Where that come from?
04-10-2024, 11:19 AM | #56 |
Rep 2,614
04-10-2024, 11:20 AM | #57 |
You got my money?
3156
Rep 4,646
Oh interesting. I will have to look into that. I apprciate the heads up.
04-10-2024, 11:46 AM | #58 |
Rep 247
so is this not something that you can do with Bimmercode? I am coming back to BMW after a long time away (used Esys on a laptop back then) and will likely buy something for coding. What's the best tool now?
04-10-2024, 01:31 PM | #59 | |
Rep 2,614
I use both Bimmercode and Bimmerutility, but the latter requires more setup (ESYS and psdzdata) and a more expensive license. |
Diesel power130.00 davisy2k177.50 |
04-10-2024, 04:54 PM | #60 |
Rep 167
In my opinion Bimmer utility - its translate somewhat to English to know what values your looking at to code - I stumbled on changing the color of my car so now the wrap is the same color and my car instead of the factory Blue ... Finding alot of stuff in there - Bimmercode I would say its for the average first entry to coding - you cant mess up anything at all -
Diesel power130.00 |
04-12-2024, 02:37 AM | #61 | |
Rep 318
Drives: '24 M4 Competition xDrive
Also was trying to code the anti-dazzle stuff so I can use all that, and I can't seem to figure that out either. So as of right now, I'm $100 poorer from buying BimmerUtility, but still have my amber corners on and still no anti-dazzle 🤦🤦 |
04-12-2024, 08:55 AM | #62 | |
Rep 2,614
Anti-Dazzle is much more involved as it requires VO coding as well (the codes that you see in your car specs, one of them is decoding anti-dazzle for the US market, that's what you remove) along with some additional FA coding. I can send you some documentation via PM but it's not for the faint of heart. |
thatguyM4187.00 |
04-12-2024, 10:20 AM | #63 | |
Rep 167
M4Tejas788.00 |
04-12-2024, 10:23 AM | #64 | |
Rep 167
The way I did the Anti Dazzle is through Bimmercode then Bimmer utility to finish the last process - I see the other member sent you something - 2024 should work |
M4Tejas788.00 |
04-12-2024, 11:56 AM | #65 |
Rep 2,614
They have a button for the quick FA coding stuff but it still requires you to do VO coding separately. It can be done in BimmerUtility, but it still requires setting up ESYS and psdzdata, if you want the "full" anti-dazzle functionality.
thatguyM4187.00 |
04-12-2024, 01:30 PM | #66 | |
Not new just quite
31
Rep 123
Drives: E60, F30, G22 & G80
Berzerker could I get a copy of your doc, pls.
tkx much in adv.! Quote:
2024 BMW M3Cx G80 | Alpine White + Fiona Red | 2021 BMW M440i G22 |
