      02-22-2024, 01:25 PM   #133
BIGW0RM
You got my money?
BIGW0RM's Avatar
Drives: Ice Cream Truck
2022 BMW M3  [9.50]
Originally Posted by JDSmith14 View Post
Confirming that 84105A62826 works flawlessly on 2022 G80 xDrive that only had NFC pad..
Key card digital key working
Galaxy S24+ digital key working
Charging multiple Samsung and Apple devices.
Did not need to set up anything after swop out.
Hardest part was disconnecting the USB connector. There is a locking pin on the right hand side that allows the connector to release if pressed
Thank you for a great post and all the info provided!
Thats true, but technically there is coding to add to make it work exactly like OEM.
The coding you enable in bimmer code activates a setting menu in idrive for the charger that will allow you to set a reminder on/off to take your phone out of the tray when you shut down the car.
      03-12-2024, 09:17 AM   #134
JDSmith14
Drives: M3 G80
Experiencing some strange behavior.
Digital key disappeared from Samsung Wallet and I am unable to add it back.
I can however add the keycard back, so reader is functioning.
Tried: S24+ / S23+ iPhone 15
Reset digital keys for all profiles.
Uninstalled and reinstalled app.
Followed the instructions here:
https://bmwi.bimmerpost.com/forums/s....php?t=1947441
I get the e-mail with the activation code, but the pairing fails as soon as I place the phone on the charging pad.
Anyone else experiencing similar issues?
      03-13-2024, 11:53 AM   #135
JDSmith14
Drives: M3 G80
Originally Posted by BIGW0RM View Post
Heads up to all those who have done this retrofit.
I did this retrofit without the coding and could not get my iphone to pair with digital key for the life of me. That was earlier this year.
I then used bimmercode to add the WIFI tray settings in idrive. The second I did that, my iphone would pair with the digital key process.
Flash forward... Ive had an idrive update and got a new iphone 15 pro. I lost my digital keys. I also lost the WIFI tray settings in idrive.
Went back to bimmercode to reprogram the wifi tray back into idrive. And realized I cant connect my new iphone to the USB lightening adapter since my iphone is USB C now. UGH! Ordered a USB C to Rj45 adapter and got my WIFI tray coding back into idrive this morning.
Tried doing my digital key again and BAM, it took the first time.
So if any of you all did this mod. And cant get digital key to pair. You must add the wifi tray coding (mentioned in this thread) to idrive for digital key to pair.
At least thats what I had to do.
BIGW0RM
Can you please confirm if you only had issues with your phone before re-coding / Did the NFC card work before you re coded?
My NCF cards works fine after the retrofit, but I am experiencing the same issue as described above when trying to add the phone.
      03-13-2024, 12:00 PM   #136
BIGW0RM
You got my money?
BIGW0RM's Avatar
2022 BMW M3  [9.50]
BIGW0RM
I dont remember if I had my iphone setup as a key before doing the wifi charging retrofit.
I had issues adding my iphone as a digital key after doing the wifi charging retrofit. Adding bimmercode WIFI coding to idrive made my NFC/Wifi charging pad accept my iphone. Not sure if my NFC key gave me any issues or not. I dont use that. But adding the two codes for the wifi tray in bimmercode got my iphones to pair immediatly.
      03-13-2024, 12:04 PM   #137
JDSmith14
Drives: M3 G80
Thank you BIGW0RM - Will update here after coding
BIGW0RM3156.00
      04-02-2024, 12:11 PM   #138
JDSmith14
Drives: M3 G80
Thank you BIGW0RM
I can confirm that I had to code the following two options:
Body Domain Controller BDC > WCA_ENABLE = aktiv
Headunit HU > WCA = aktiv
The digital key activated first time after adding these.
