02-10-2022, 03:56 AM | #45 |
Rep 248
I've a G80 M3 X drive due for delivery early April. When I drove the demo I was able to switch off the 'Sound Control'. Does this render the exhaust button redundant, or are the exhaust valves now decoupled from the 'fake' noise played over the speakers?
02-14-2022, 07:55 AM | #46 | |
Rep 33
If you used the exhaust botton, you closed the valves as well affecting the real sound. |
02-15-2022, 03:02 AM | #47 |
Rep 5
02-15-2022, 07:46 AM | #48 |
Rep 248
02-15-2022, 08:32 AM | #49 |
Beware of cheap bait!
709
Rep 715
02-15-2022, 08:46 AM | #50 |
Rep 581
Please post a picture of the option in iDrive.
2022 M4 Competition xDrive Coupe Portimao Blue
2022 911 Carrera Coupe Chalk |
02-15-2022, 09:55 AM | #51 |
Rep 33
02-15-2022, 11:00 AM | #52 |
Rep 248
I don't have the car yet. I did this in the idrive of a G83 I test drove.
02-15-2022, 11:06 AM | #53 | ||
You got my money?
3156
Rep 4,646
Drives: Ice Cream Truck
Its under car, settings and in the M menu. I believe the valves do stay open even when you toggle that setting in idrive? I tested this, this morning. I turned off sound in idrive and my exhaust button down near the start button stayed on? Still sounded loud. I think pressing the button down by the start button turns off the valves and sound. At least that's how I seem think mine works.
02-15-2022, 11:13 AM | #54 | |
Rep 248
02-15-2022, 11:21 AM | #55 | |
You got my money?
3156
Rep 4,646
Now, I did just get my software updated. My car had the update screen totally missing so they had to flash my car to whatever the full latest update was. I also have the CG precision valve controller. I tested the above with it in OEM mode AND in full open override mode. I was able to turn off interior active sound with the valve controller in full open or in OEM mode. Personally, I like the CG controller because in full open every start sounds much better. It makes efficent mode sound nice. And I dont have to be in hyper throttle sport plus to hear my exhaust. It makes efficient sound DEEP. So even if your software does not support keeping the valve open when you turn interior active sound off, you could just get the controller and have them open 24/7 even with interior sound off. And or you can turn it off and go back into OEM mode for pure silence.
02-15-2022, 11:30 AM | #56 | ||
Rep 581
Would greatly appreciate if you could let us know what is a "CG precision valve controller." What it is, BMW or aftermarket, how it is installed (easy or requires a mechanic), and any other info you can share.
02-15-2022, 11:37 AM | #57 | |
You got my money?
3156
Rep 4,646
CG precision is a little box gizmo that plugs into the valves activators near the muffler under the car. It intercepts the BMW signal allowing you to FULLY open or run in OEM mode how you see fit. They give you two keyfobs with an on/off buttons. You take those and program them to your mirror home link buttons. One for activated (full open) and the other for OEM mode. Its a couple hundred bucks and you get to choose how you want it to act at every start up. Most choose FULL OPEN every start and OEM mode when you want to be silent. Check this post out for what it looks like and how you install it. It literally takes 25 mins to install. No jack needed. But lifting one side would give you more room to work. https://g80.bimmerpost.com/forums/sh...1&postcount=16
02-15-2022, 11:41 AM | #58 | |
Rep 581
BIGW0RM3156.00 |
02-18-2022, 08:01 AM | #59 |
Rep 398
I coded the Active Sound off using BimmerCode to test it about a week ago and I've left it off, as I prefer the sounds of the car without the sound being piped into the cabin. I didn't have an issue with the piped-in noise, it's actually pretty good, however I was looking for things to code as a lot of the stuff I coded on my F82 you can now do natively through the car's settings.
You still get the fart noise on upshift with it coded off and the exhaust valves still work the same in Sport / Sport+ modes. I've decided to leave it off, I may try changing it back at some point to see how it compares after driving with it off but at the moment it's nice not to have the piped noises. |
Spiffx448.00 |
02-19-2022, 07:57 AM | #60 | |
9052
Rep 7,621
02-19-2022, 11:40 AM | #61 |
You got my money?
3156
Rep 4,646
What fart noises? I havent heard my car fart? At least not like the F8X series did. That series had a massive FART.
02-19-2022, 02:23 PM | #62 |
9052
Rep 7,621
After the last software update when the car upshifts it makes this low rumble farting noise. Same on my friend's X3M. I don't like it.
02-20-2022, 02:50 AM | #63 |
Rep 398
I coded ASD back on yesterday and drove the car for a couple of miles, then stopped and coded it back off for the rest of the journey home.
I definitely prefer the car with ASD off, as now I've got used to the sound of the engine on its own, I much prefer it over having the piped in noise too. The ASD noise seems overly boomy and you can't really hear the engine properly, at least not at the lower end of the rev range. So comparison over for me - I'll be leaving ASD deactivated. |
TENPIN330.50 |
02-20-2022, 11:04 AM | #64 |
You got my money?
3156
Rep 4,646
Do you know what the latest software version is? I recently had mine reflashed at the dealer because the "update" section was missing in my idrive. Once they reflashed my car, the update section returned an I was able to check for any other additional OTA updates. Mine didn't show any other additional updates. But I dont think my car farts. At least nothing like the F series M cars I had did or my F10 M5 did. This is interesting.
01-14-2023, 05:46 AM | #65 |
Rep 248
Gents
I now have a G80 M3 with ID8. The M Sound button definitely closes the exhaust valves. Any way to sitch off ASD (pull a fuse?), but have valves open? |
