04-09-2021, 04:52 AM | #45 |
Rep 114
Clearly a cost decision, BMW chose not to engineer a fix. BMW probably thought, no-one can tell the difference between a steel or CFRP driveshaft when driving, and the G80/82 is going to heavy anyway.
I believe Alfa Romeo, magically, still have CFRP driveshafts on the Giulia and Stelvio Quadrifoglios
Gone: e46 M3, e92 M3, f82 M4
04-09-2021, 07:26 AM | #46 | |
Law Enforcer
24972
Rep 22,264
AESZ497.00 |
04-09-2021, 07:26 AM | #47 |
Facts matter
325
Rep 337
Exactly. I can't imagine what they think they're doing with this video. It's essentially a bunch of 'see what we wanted to do and how much we had to deviate'.
2008 330i 6MT Graphite Metallic
2014 335i 6MT M Sport Estoril Blue 2021 M3 6MT TBII/Silverstone |
04-09-2021, 07:37 AM | #48 |
Rep 1,477
Drives: BMW M2
Giulia and Stelvio Quadrifoglio don't have any OPF, they meet the new regulations without it.
It's not hard to understand, the CFRP DS was too big to fit, making it with a thinner diameter would have meant making it thicker (more 'material') with no advantage in weight saving but a lot of extra cost. Basically useless. But maybe someone lives better knowing there is a carbon fibre CF under their car at any cost even though it would have no advantage. |
04-09-2021, 08:54 AM | #49 | |
Rep 390
My guess is that all the CFRP parts that went missing from F80 to G80 ... we will see them again on the CSL version ... horse shoe, shaft, hood, trunk... |
Poochie9103.00 |
04-09-2021, 09:28 AM | #50 | |
Law Enforcer
24972
Rep 22,264
04-09-2021, 12:35 PM | #51 | |
Rep 72
It will be interesting to see if the drive shaft is included though. That part seems like a lot of cost in materials and engineering for a minimal performance gain. But if people will pay... |
04-09-2021, 01:46 PM | #52 | ||
Luxury at the redline :)
9103
Rep 7,563
Custom carbon driveshaft at the local level goes for about 2 to $3,000 and is paperweight in comparison to steel. Deducing from that, I'm convinced that in the case with the G8X, there was some number crunching and the bean-counters triumphed over the engineers, so then steel was ultimately settled on. If they can save like say $500 per vehicle, it adds up. I'm not upset, I just don't appreciate my intelligence being insulted but either way, I still want one but the truth would of been divine. |
04-09-2021, 02:09 PM | #53 | |
Rep 1,477
Drives: BMW M2
Sedan_Clan24971.50 AESZ497.00 |
04-09-2021, 02:14 PM | #54 | ||
Law Enforcer
24972
Rep 22,264
04-09-2021, 02:14 PM | #55 | |
Rep 9,709
I suspect in the case of F82, it was the heat from the OPF that they were concerned about damaging the carbon, not the size, but then why give the wrong reason? : |
04-09-2021, 02:29 PM | #56 | |||
Rep 2,557
On top of that I haven't seen one piece of data that showed the carbon fiber driver shaft actually affected lap times or acceleration in a measurable way.... my opinion is the carbon driveshaft was essentially a "because race car" marketing feature which is why it was so easy to ditch when they need the space back. Yes there is probably some some calculator that showed 0.0001% benefit but nothing any owner ever noticed in the real world |
04-09-2021, 02:31 PM | #57 | ||||
Law Enforcer
24972
Rep 22,264
04-09-2021, 02:35 PM | #58 |
Rep 1,477
Drives: BMW M2
It's amazing how people without any knowledge of the car and its specifics assume that Bmw's engineers are lying
04-09-2021, 02:48 PM | #59 | |
Rep 114
04-09-2021, 02:59 PM | #60 |
Rep 1,477
Drives: BMW M2
04-09-2021, 03:07 PM | #61 | ||
9103
Rep 7,563
It doesn't matter anyway, a carbon driveshaft was an exotic option and it was frankly a gift they added it to the previous model but steel is denser and cheaper but adds unsprung weight, the worst of all weights. Like I said, I'm not mad at them, do your thing BMW AG, I'll still give them my money and I don't believe it's a conspiracy; like everything else, it came down to money. It's all good. |
04-09-2021, 10:33 PM | #62 |
Rep 834
90mm to 50mm is a big reduction from the carbon shaft. Just look at the thickness of the carbon shaft. The 50mm just looks small and thin.. Hopefully the shaft can handle the power increase from the motor when upgrading..
M Forever!!!!
04-10-2021, 02:33 AM | #63 | |
Rep 153
And there’s also the fact that a company never just gives something more expensive for free. A carbon shaft would’ve either increased the price of the car or taken away from something else. As for the Alfa Romeo comparison, I’d much rather have the German-engineered car with the steel shaft than a car that breaks down already during their first drives. Fancy CFRP shaft or not. |
04-10-2021, 04:05 AM | #64 | ||||
Rep 5,109
They just have added port injection to the engine in the Quadrafoglio. Port injection creates less particles during combustion since the fuel is injected in a more liquid state under low pressure in the port. DI engines atomize the fuel into a fine mist as it's injected under high pressure (same reason why diesel engines also need a particulate filter), which is why DI engines generate more particles during combustion. Port injection is less fuel efficient and doesn't give as much control over combustion as DI. The first version of the AR engine just had DI, they added port injection to cope with stricter particulate requirements. See attached spec sheets for 2017 and 2020. I guess AR use the port injection to create less particles during the WLTP cycle. One other advantage is that you don't get carbon build up in the intake port/valves. The other petrol engines in the AR Giulia lineup is just DI. Which makes me think that AR was not able to make room for OPF on the Quadrofoglio or could justify to re-engineer the car to make room for the OPF. The Cosworth V12 for the Red Bull and Aston Martin hypercars also use port injection and doesn't require OPF to meet particulate emision requirements. |
04-10-2021, 04:20 AM | #65 | |
Rep 1,477
Drives: BMW M2
The best part of port injection is the cleanliness of the intake, something FSI owners are familiar with |
04-10-2021, 04:25 AM | #66 | |||||
Rep 5,109
I guess AR use the port injection to create less particles during the WLTP cycle. Ie, they don't use the DI during the WLTP test cycle (unlike VW most likely). Running the engine on just port injection in the WLTP cycle creates a lot less particles, and they meet requirements without OPF. The other petrol engines in the AR Giulia lineup is just DI. Which makes me think that AR was not able to make room for OPF on the Quadrofoglio or could justify to re-engineer the car to make room for the OPF. If this was a «better» engineering solution they would have done the same on the lesser models as well. I'm pretty sure particulate requirements is the only reason they added port injection and that they weren't able to/could afford to make room for the OPF on this low volume model with a larger engine with less room to play with. Port injection is a low cost compromise to the problem. |
