04-08-2021, 05:00 PM | #23 | |
Rep 5,110
04-08-2021, 05:04 PM | #24 | ||
Law Enforcer
25085
Rep 22,283
04-08-2021, 05:16 PM | #25 |
Rep 6,759
The single use adhesive capsule is very interesting... I wonder if this method could be used for other fittings in the car...
The CF driveshaft discussion awakened my curiosity. I have an end of production F80, built in June or July 2018 at a time when BMW was allegedly fitting steel driveshafts in all the M3 and M4s. I have an alignment coming this Monday, I should able to confirm the material. The CF unit definitely has the “cool” factor. Although I seriously doubt anyone could tell the difference in a side by side driving test.
2018 F80 Santorini 2019 Z4 3.0i 2022 X2 M35i |
zamboni1130.50 Sedan_Clan25085.00 |
04-08-2021, 05:22 PM | #26 | |
Rep 5,110
04-08-2021, 05:36 PM | #27 | ||
Rep 5,110
04-08-2021, 06:20 PM | #28 | |
Rep 9,709
But even with the filters it's only the front section that is restricted, they could have made a full 90mm OD rear CFRP section. They didn't. But in any case, there isn't a single thread in G80 forum crying about CFRP drive shaft omission. Everyone moved on after F82 lost CFRP. So this marketing video only serves to drag up an old topic. In a negative way. We also find out that it's even worse. The DS is now only 50mm diameter, and is so thick wall sectioned to keep the stiffness that it needs a collision sleeve in it to prevent it spearing the cabin. What a marketing triumph that was to come clean on. |
04-08-2021, 06:36 PM | #29 | ||
Luxury at the redline :)
9105
Rep 7,563
If they wanted to, they could of fitted a carbon fiber driveshaft, with an OPF filter and find some work-around but you know, that's just more added cost that they can't up-charge you for in some optional $4,000 "performance" package, so why bother when they can just increase the boost pressure to compensate for the potential lost of unsprung weight reduction. |
04-08-2021, 06:57 PM | #30 | |
I want to drive a Zamboni
1131
Rep 5,557
Drives: 13 E93 M3 18 F80 M3 16 K71
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni |
04-08-2021, 07:19 PM | #31 | |
General
21117
Rep 20,741
Drives: 2021 911 turbo
04-08-2021, 07:27 PM | #32 | |
General
21117
Rep 20,741
04-08-2021, 07:31 PM | #33 | |
General
21117
Rep 20,741
04-08-2021, 07:33 PM | #34 | |
General
21117
Rep 20,741
04-08-2021, 07:37 PM | #35 | |||||||||
Law Enforcer
25085
Rep 22,283
04-08-2021, 07:50 PM | #36 | ||
9105
Rep 7,563
04-08-2021, 08:01 PM | #37 |
General
21117
Rep 20,741
Composites are very strong per unit weight, but require much more volume for a given load bearing capability. There are very few materials that favourably compare to steel regarding load bearing density.
04-08-2021, 08:20 PM | #38 | |
9105
Rep 7,563
Ok bro, we going to have to agree to disagree on this one.. I'm sure it has absolutely nothing to do with the cost.. . |
04-08-2021, 11:54 PM | #40 | |||
Rep 2,858
2022 G83 PCD & 2024 G05 S68 PCD
Retired:2021 F95 ZCP PCD,2018 F85 PCD,2018 F83 ZCP- ED/PCD, 2015 X5 50i PCD, 2015 435 vert ED, 2011 X3 PCD, 2011 335is vert ED/PCD, 2007 X3is PCD, 2007 335i vert PCD, 2004 328i vert PCD |
Fugly M35071.00 QuarterMileJoe9.00 |
04-09-2021, 12:22 AM | #41 | ||||
9105
Rep 7,563
I'm going to reserve judgment until an official technical training manual or equivalent is leaked, with more intricate details; so I can make a more logical conclusion on its efficacy or - lack thereof. However, I must say, I don't like the sound of breakaway driveshafts and never heard of a driveshaft becoming projectiles in an accident or it being failure-prone, so if it ain't broken.. But I still have faith in BMW, so we'll see how it goes.. |
QuarterMileJoe9.00 Ibiza3611.50 |
04-09-2021, 12:40 AM | #42 | ||||
Law Enforcer
25085
Rep 22,283
04-09-2021, 02:20 AM | #43 |
Rep 1,083
Certainly that regulations and cost might just be some of the issues, but the adhesive & balancing issues with a CF driveshaft should also be considered.
For the E9x M3 aftermarket, CF driveshaft from DSS/Fall-Line/MFactory all had some sort of issues whether it's from bonding or from balancing or from heat issues such that additional heat resistant material is to be installed around the CF driveshaft.
04-09-2021, 03:11 AM | #44 | |
General
17488
Rep 25,113
Yep we will re engineer the car based around the filter :
My car made front page of Bimmerpost
