03-29-2021, 01:37 PM | #1 |
Rep 221
Valentine One Hardwire in G80?
Taking delivery of my M3 tomorrow, has anyone hardwired a V1 into one of these yet? Wondering which color wires I should use to piggyback by the mirror (and any info on removing the cover to get to the wiring)
Current: 2021 G80 M3 Comp; BG, KO
Previous cars: 2007 e92 328i; 2008 550i Sport; 2013 e92 M3 zcp; 2016 F82 M4 |
03-29-2021, 03:43 PM | #2 |
Rep 285
Here you go:
https://g80.bimmerpost.com/forums/sh....php?t=1811276 There are similar posts in the G2X forums with pics, I believe |
03-31-2021, 10:13 AM | #3 |
Rep 143
Yes, exact same as the G2X. You pull down on the piece above the mirror (it's basic clips holding it up). Also, you don't need to remove the other trim pieces, but if you wanted to, slide them left or right to remove.
From there just tap the outer most wires brwn/black is negative (left side) and Pink/Reddish is positve (right side of plug). I had "mini" taps which were pretty easy to slide into the plugs. Larger taps might be harder. I can take pics of anyone needs them. |
03-31-2021, 02:23 PM | #5 |
Rep 221
Just did it, pretty simple, though the car apparently constantly sets off the laser detection. Anyone have a solution to that?
03-31-2021, 04:13 PM | #6 |
Rep 659
I was reading on the G20 forum and it's to do with the gesture control. There's a sensor you can tape up but you'll lose the GC obviously, not that anyone uses it I think.
Love me a big old grille! Wish it was an xdrive G80
03-31-2021, 05:04 PM | #7 | |
Rep 285
When my new car comes in I'm going to leave the V1 in my wife's glovebox and get a Uniden R7 for myself. It allows pretty extensive adjustment. That said, I didn't get the Exec Package so this shouldn't be a problem for me. |
03-31-2021, 05:47 PM | #8 | |
Rep 246
Off the top of my head I don’t recall why changes I made but have no false alarms in my new F80 M3. I did disable gesture control prior to installing the detector. This was the guide I used. Possibly enabling Traffic Monitor Filter and Junk-K Fighter. https://www.valentine1.com/wp-conten...OriginalV1.pdf If I remember what I changed I’ll reply.
G80 M3 manual
Notable-Giulia QV, MK7 Golf R man,991 Turbo,CTS-V3, CTS-V2 man Speed INC. build, E60 M5 SMG, E46 M3 ZCP man, E39 M5, E39 540 man, Porsche Cayenne Turbo EVOMS build, EVO X AMS build, Blobeye STI, 83’ RX-7 built by Alan Jackson racing, Volvo 164e |
03-31-2021, 07:47 PM | #9 |
Rep 143
I have an R7 and don't have any type of false laser alerts in my m3c with all the assists and gesture stuff. I can check my 9500ix if anyone cares.
Digitalfujjjrel186.00 |
04-01-2021, 10:14 AM | #10 | |
Rep 352
I don't think in 15 years of running V1 I ever actually had a rear laser alert... |
04-08-2021, 07:09 PM | #11 |
8960
Rep 7,589
Is there anywhere else you can wire it into besides the mirror? I know it's not as ideal but I usually put mine in the left lower windshield so it's kind of out of the way.
01-16-2022, 11:27 AM | #12 |
Rep 121
Dang, this is kind of a bummer for my V1 gen 2 purchase for my g80. Really wanted to plug in and be ready to rock. I wonder if the escort max360c has the same issue?
03-31-2022, 05:58 PM | #13 |
Rep 198
The gesture control is what sets the laser off. I have my laser off on my V1 Gen 1, and it looks like there is a way to turn off the rear laser detection only on Gen 2. As far as I know all the laser does is let you know to pull over since the cop already has your speed.
2022 M3 Competition Brooklyn Grey/Full Fiona Red- Build Week 50
04-06-2022, 08:36 PM | #14 |
Rep 1,064
Curious why you want to run the hardwire rather than using the mirror tap?
04-07-2022, 09:51 PM | #15 |
Rep 841
Yes I connected differently. I bought long cable and mirror mount.
Mounted Val1 to a mirror and started to hide the cable in roof sheathing and slowly going to the right side of windshield pillar from there to the back trunk charger. ! Hard to explain but here is some quick pictures. I don’t use that trunk charger anyway. I use for valentines after when bmw removed my favorite location which was under glove box compartment. Cables are not visible and look like hardwired Cablehttps://www.amazon.com/gp/aw/d/B006G...b_b_asin_title Mount https://www.amazon.com/gp/aw/d/B0063...b_b_asin_title Last edited by GoodGuyAvi; 04-07-2022 at 10:04 PM.. |
LuckyBrand1140.00 |
05-06-2022, 06:14 AM | #16 |
Rep 222
I installed the Valentine1 Gen2, blend mount and ran wiring to OBD2 Valentine Savvy plug in my 2022 M4. It works perfect. Looks close to stock as you can get. It took less than 30 minutes.
