04-02-2021, 07:47 AM | #23 |
///MFlight Member
454
Rep 246
Looks like you can't save your HUD sport display setup with the TACH on any of the M1 or M2 settings. Only way to do bring up the HUD in sport mode with TACH is to select your M1 or M2 and then press the MMode button down on the middle console.
EXE462100.00 |
04-07-2021, 02:17 PM | #24 | |
Rep 262
rajahfl38.50 |
04-07-2021, 02:19 PM | #25 | |
Rep 262
04-07-2021, 04:10 PM | #26 | |
Rep 2,007
Drives: 2022 i4 M50
This mode is also tied to turning off some nannies such as the lane keep /steering assist which has it's own set of pluses/minuses. I didn't have to worry about steering assist in the F80, but I have always set M2 to be my more aggressive mode like many. I always joke that a high HP car with good brakes and suspension is a necessity for safety purposes when driving on open/public roads, but I do really feel some legitimacy behind that. It was nice to know I could double tap M2 and avoid certain situations without looking down. Now, if I'm not already in sport mode through the M mode button and need to drive defensively, I have to fight the steering assist if that means I'm going over a solid line to avoid something. It's not horrible, but it's an added variable that could be catastrophic if unexpected.
Current: 2022 i4 M50 | 2022 G07 X7
Gone: 2020 F92 M8 | 2020 G07 X7 | 2018 F80 M3 | 2017 F15 X5 | 2016 F16 X6 | 2015 F36 4 series GC |
rajahfl38.50 |
04-08-2021, 03:47 AM | #27 | |
///MFlight Member
454
Rep 246
04-08-2021, 08:10 AM | #28 |
Rep 102
Can the programmable memory buttons [1..8] be used as shortcuts to set specific attributes? The manual says: "The Drive functions can be stored on the programmable memory buttons and called up directly … for instance menu entries"
04-08-2021, 08:47 AM | #29 | |
Rep 2,007
Drives: 2022 i4 M50
Still, I think the answer is no. If I go into the car/m setup menu and try to hover over anything then hold one of the memory buttons to attempt to save it, I simply get "Unable to save". I'd imagine it's a safety thing, they likely don't want actual drive settings to be altered with a ambiguous programmable button that could also be used to change a radio station, pull up a menu, start navigation, etc.
rajahfl38.50 |
04-08-2021, 12:30 PM | #30 |
Rep 102
04-08-2021, 01:38 PM | #31 | |
Rep 2,007
Drives: 2022 i4 M50
You can pull up the menu through the setup button, and through a widget, or display it in your Guage cluster.
04-09-2021, 04:54 AM | #32 | ||
Rep 60
PVC154.50 |
