03-22-2021, 09:06 AM | #1 |
Rep 387
What tire pressure are you running?
I have the 19/20 826s on the G80 and I was wondering if people are following the tire recommendations on the door? Looking for road use, not track settings. Thanks
03-24-2021, 09:23 PM | #2 |
Rep 90
I usually run my tires about 2-3 psi higher than the specified amount. With this approach I have gotten pretty good mileage and wear out of the tires. On my old F82 with PSS I was closing in on 20K mi with the expectation that I would be replacing the tires between 22K and 25K. I drove somewhat moderately but aggressively when the road and traffic permitted.
03-27-2021, 07:10 PM | #4 |
Rep 246
Checked mine this morning and they were all different and over inflated. Left rear was 42!
Set them to 32/33 per door jamb sticker. Ride quality improved as expected. This makes me crazy. If you can’t get something as simple as tire pressure right why would I trust you with something complex. It’s such a common issue that I usually check the pressure before a test drive. Drove a Giulia QV last year that felt like a truck. Checked the pressure and they had something north of 20psi over recommended. Salesman told me this was normal because it was cold out. |
03-30-2021, 09:11 AM | #6 | |
Track Rat
1760
Rep 403
Addendum: Just picked up my new M4 Comp yesterday and sure enough...rated pressure on the door jamb 32lbs. front & rear...actual pressure 50lbs. Felt like the tires were made of concrete. Like I said Namaste.
03-30-2021, 09:49 AM | #7 | |
Rep 246
G80 M3 manual
Notable-Giulia QV, MK7 Golf R man,991 Turbo,CTS-V3, CTS-V2 man Speed INC. build, E60 M5 SMG, E46 M3 ZCP man, E39 M5, E39 540 man, Porsche Cayenne Turbo EVOMS build, EVO X AMS build, Blobeye STI, 83’ RX-7 built by Alan Jackson racing, Volvo 164e |
Boomer 20191759.50 2011ninja3400.50 |
04-01-2021, 10:22 AM | #8 |
Rep 387
04-03-2021, 11:50 AM | #9 |
Plenipotentiary
2614
Rep 3,046
07-31-2022, 08:42 PM | #10 |
Rep 93
My tire pressures were too high as well from delivery and the iDrive settings were set to “other/track”… when I switched it over to the 20” rear and took air out to 32/33psi, my tire pressure warning comes on every time I start my car now.
Not sure what the issue is. |
08-01-2022, 12:44 AM | #11 | |
Rep 167
I set mine to Track/other tires and it doesn’t bug me anymore. Which I am running wider wheels and tires any ways but it stopped the finicky light from coming on. |
08-04-2022, 07:04 PM | #12 |
Rep 393
Drives: 22 G80 Sao Paulo Yellow
I run mine 35F and 38R. I understand the firmer ride and center wear. I honestly can't stand the soft ride and the inside camber wear with the lower inflation so I always increase my tires with cambered cars 3-6lbs but I never run the max pressure on the sidewall of the tire
