      03-18-2024, 12:14 AM   #1
eric97h
Bmw340i Mppsk, bm3 tune,vrsf downpipe dinan intake
Drives: Bmw 340i fbo
BMW m3 60-130 stock time
BMW m3 x drive
1.5 gallons e85 rest 91 half tank gas
Bmc filters
And m3 cs flash
|340i mppsk dinan intake vrsf catted downpipe|
|full alcantera carbon fiber interior|
|bootmod 91, 93 and full e85 tune stage 2 agg|
|firehawk tires and hawk perfomance brake pads | |bimmer code, | upgraded spark plugs full carbon exterior
Limegrntaln13475.00
      03-18-2024, 08:03 AM   #2
RUNSOK
RUNSOK's Avatar
237
Drives: 24 M4 COMP XDRIVE
Are these before and after CS flash runs??
10.06 stock
8.96 with CS Flash
Also why are the dips on the speed graph in the middle of the 2nd run. Looks like, you could have gone even faster.
      03-18-2024, 09:55 AM   #3
markoz28
Drives: BMW 2017 340i, BMW 2020 M340i,
10.06 stock
8.96 with CS Flash
I noticed those dips too and then checked my logs to see if I have them and none of my runs show that. All of mine are smooth. Wonder if it was a change in the road or maybe a hesitation in the shifting from transmission.
      03-18-2024, 10:01 AM   #4
RUNSOK
RUNSOK's Avatar
237
Not sure... looks like elevation did not change at the spot the dip happens. Only possibility I can think of due to the road is if the road was not straight and OP actually was going through a fast turn... may be... but I doubt it.
Regarding shifting, if he was shifting manually with pedals may be he hit the rev limiter that can show as a dip as well. Hopefully OP can shed a light...
      03-18-2024, 11:28 AM   #5
eric97h
10.06 stock
8.96 with CS Flash
no both are stock no dahler tune yet i wanted a before and after run
      03-18-2024, 11:29 AM   #6
eric97h
im assuming its because i changed lanes maybe ? the two runs one has a 2.7 percent slope and the other has -0.25 slope
      03-18-2024, 11:30 AM   #7
hellcat2m4
Drives: 2022 M3 Competition
The second run is invalid you must have went under an underpass or something similar.
Give it another shot. I got 9.3 and 9.7 when stock
      03-18-2024, 11:39 AM   #8
eric97h
ya i will do the second run again im assuming i get around 9.4 cuz in the first run with 2.6 slope its 10.1 with correction tis mid 9s
      03-18-2024, 11:46 AM   #9
RUNSOK
RUNSOK's Avatar
237
So the CS tune was just transmission and steering tune?
      03-18-2024, 12:11 PM   #10
eric97h
trans steeing the dampers suspesnion
i waanted a before and after to compare with dahler tune and stock basically with cs tune
RUNSOK237.00
