03-14-2024, 09:54 AM | #1 |
Rep 44
Mid-pipe exhaust recommendation
I know there are TONS of threads on here talking about exhaust setups, but I was curious if anyone had a recommendation given my specific goals.
I want to make my exhaust a little bit louder, but nothing obnoxious. I prefer the low growl to a higher-frequency sound. This is also my daily driver, so the most important thing is to have little to no drone. I've read that in combination with a valve controller, you can also close the valves to kill the drone if needed. But ideally, I'd love setup that didn't require that. From what I've read, I'm leaning toward the MAD single midpipe. That comes with the option to be with or without a resonator... thoughts on that? Am I correct that the single mid-pipe is the best setup for what my goals are? It seems like I saw something that said x-pipes are going to be MUCH louder than stock and that is not what I'm after. I'm also leaning toward the SST valve controller. I like the multiple modes they have. 100% open, 75% open, 50% open and stock mode, where they still modulate depending on throttle input. It's hard watching videos online to tell the difference in volume. My goal is to get a little more volume, without adding drone or a high-frequency sound. Thanks in advance for any feedback. |
03-14-2024, 10:13 AM | #3 |
Rep 2,606
If you only swap the midpipe, with everything comfort/closed, the car is as silent as it is stock. It's only when you go into Sport+/open the valves do you get the louder sound.
If you don't fully open the valves, it's just a louder version of stock. If you open the valves 100% with the SST, it'll be even louder but it will also drone slightly at highway speeds. Removing *any* resonators will drone at highway speeds with the valves 100% open, but that's the beauty of the valve controller. Back to OEM and drone is gone. IMO the single midpipe + SST is absolutely peak for sound and flexibility when it comes to no drone but louder setups. |
03-14-2024, 10:31 AM | #4 |
Rep 190,807
The single midpipe offers the cleanest sound, with a deep midrange and a rasp-free tone. it's a perfect daily driver choice.
if you plan on upgrading the downpipes, I recommend the resonated downpipes version for the cleanest sound. the valve controller is a must in my opinion.
03-14-2024, 10:41 AM | #6 |
Rep 44
03-14-2024, 10:46 AM | #7 | |
Rep 44
Also, do you have any special pricing for Bimmerpost users? If not no worries, figured it can't hurt to ask! |
03-14-2024, 10:49 AM | #8 | |
Rep 190,807
We do offer special pricing on MAD; note both versions are currently out of stock.
03-14-2024, 11:02 AM | #9 |
Rep 44
03-14-2024, 11:04 AM | #10 |
Rep 44
One more question! What is the benefit of also swapping the downpipes?
03-14-2024, 12:29 PM | #11 | |
Rep 4,923
The main advantage of a downpipe is POWER however without a tune you are not likely to take advantage of the increase flow rate. Most people without tunes are using them for increased sound and throttle response with the ultimate goal of tuning down the road.
03-14-2024, 12:34 PM | #12 |
Rep 150
I currently have the AA catted DPs and have yet to install the AWRON valve controller. Was considering the Remus secondary cat delete or the Akrapovik ti resonated mid pipe
03-14-2024, 12:42 PM | #13 | |
Rep 2,606
All of these can also be done in steps, midpipe is the easiest, no-warranty-issue way to get louder sound while still keeping it tame and not obnoxious. If you still feel you want more sound after that, downpipes and axleback can be swapped very easily after that, but none of these changes are irreversible. BMW might have an issue if they flag your car with swapped downpipes later down the road. If warranty isn't a concern then just do whatever you want. |
Info@mad-us.com1924.00 |
03-14-2024, 01:23 PM | #14 |
Rep 336
I would definitely get the SST controller. I currently have the MAD non-res midpipe and if I were to do it over again I would get the resonated version. I still may swap them down the road here.
03-14-2024, 03:33 PM | #15 |
Rep 44
Thanks for the feedback. The difference in price between the resonated and non-resonated version is pretty much the price of the SST controller. Seems like a no-brainer to me!
03-14-2024, 03:36 PM | #16 | |
Rep 44
03-14-2024, 03:47 PM | #17 |
Rep 2,606
You definitely won't be disappointed. Good luck!
03-14-2024, 07:09 PM | #18 |
Rep 92
Drives: 2008 E90 M3 2024 G80 M3
I’m installing a Dinan mid-pipe and axle back with a valve controller. With the valve controller I assume it’s no biggy to go fully open in efficient mode, but what about having the valves closed in Sport+? Only asking for track days purposes, as a few of the tracks near me have sound limits. So if I wanted sport+ mode but valves closed for sound Will that have any negative effect on the motor? Like an increase in back pressure or anything like that?
03-14-2024, 10:01 PM | #19 | |
Rep 336
03-15-2024, 07:38 AM | #20 |
Rep 34
I recently did the non-resonated MAD midpipe and SST valve controller, and am very happy with it. At first with the valves open on the freeway it had a little drone, but once I turned off ASD in BimmerCode it is great. If you want it quieter then put it in OEM or closed mode, and it is far quieter.
03-15-2024, 09:54 AM | #21 |
Rep 2,076
Actually, that's what they said, but that 50% is like 90%. I really cannot tell that big of a difference at all.
03-15-2024, 10:00 AM | #22 |
Rep 4,923
