03-09-2024, 11:07 AM | #1 |
Rep 268
Which exhaust cutting tool?
For those that have done DIY exhaust modifications, which chain style exhaust pipe cutters did you use and were you happy with them? There are a plethora of options on Amazon with mixed reviews. Many do not call out stainless. I know the basics, keep the pressure light, use oil, let the tool do the work, take your time, etc.. Just seeing if I can narrow down the right tool that doesn’t give me fits when I do the job.
Thanks |
03-09-2024, 12:12 PM | #2 | |
Rep 401
It worked great. Just started off with little pressure to score the initial cutting line. Then keep applying more pressure. Surprisingly it cut through pretty quickly and a very clean cut. |
03-09-2024, 01:01 PM | #3 |
Rep 742
Drives: 22 M4c vert
Important point to note is that these tools are basically one time use. Super easy on the first usage, then they all but fail. Best bet is to just dispose of them after you use them.
03-09-2024, 03:52 PM | #4 |
Rep 459
Harbor Freigh's chain pipe cutter worked great for me. Took about a minute per side. I've never used one before this and I was blown away with how easy it was.
cozye334.00 |
03-09-2024, 04:28 PM | #5 | |
Rep 2,022
03-09-2024, 04:30 PM | #6 |
Rep 401
kgelfen3602217.00 cozye334.00 |
03-09-2024, 04:39 PM | #7 |
Rep 869
This is what we use at the shop. It does the cleanest cuts and the cutting wheel is replaceable. The only downside is it requires more clearance than a cutting chain so the exhaust will need to be dropped rather than cut on the car.
https://www.eastwood.com/eastwood-ex...-diameter.html
Speed & Tech Motoring
23585 Overland Drive, Unit 178 Sterling, VA 20166 (Headquarters) 23541 Pebble Run Place, Unit 140 Sterling, VA 20166 (Satellite shop) |
03-09-2024, 06:20 PM | #9 |
Rep 468
03-09-2024, 07:17 PM | #10 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
No they are not. My local group has been using the same exhaust cutter. Most people just don't know how to use them properly. The cutting wheels are either not lubricated enough or the get dull from people squeezing them too hard.
03-09-2024, 09:25 PM | #12 |
Rep 268
03-09-2024, 09:29 PM | #14 | |
Rep 1,929
cozye334.00 |
03-14-2024, 09:19 AM | #15 | |
Rep 1,422
If you've gotta grab it with both hands or slide on a cheater bar, it's way too tight. |
