03-08-2024, 09:56 PM | #2 |
Rep 1,929
Could have swore someone asked that before and the response was that the jb4 for x3m simply had longer cables and will work on the m3. You could email burger to confirm.
03-09-2024, 01:26 PM | #4 |
Rep 190,807
You can use it; only the G87 M2 jb4 is different.
Note, if you are getting a used JB4, you void your BMS warranty and you risk connecting a water-damaged unit to your car. If the deal is too good to turn down and you trust the seller, get it. But if you are only saving a couple hundred dollars, you are better off getting from an authorized dealer instead.
03-13-2024, 10:50 AM | #5 |
Rep 885
I wouldn't get jb4 on any car ... a lot of trusted performance shop won't tune your car if it had a jb4 on it before. my friend had a ignition issue right after installing his jb4 and dealer flaggued the car immediatly.
Instagram : @gc.g80brg
2023 M3C Xdrive British Racing Green 2009 M3 Alpine white DCT 2001 M3 Laguna seca 6 speed |
03-13-2024, 11:17 AM | #6 | |
Rep 190,807
they will not touch the car that has a JB4 or any other piggyback
03-13-2024, 11:52 AM | #7 |
Rep 885
Jb4 isn't a tune ^^ it is just a external that falses the data so the car injects more fuel, o2, etc
03-13-2024, 12:41 PM | #8 |
Rep 190,807
ok then
03-16-2024, 06:07 AM | #9 |
Rep 70
Drives: 22 G80 M3, 19 488 Pista
03-16-2024, 07:01 AM | #10 |
Rep 885
Lol ...
03-16-2024, 08:56 AM | #12 |
Rep 277
03-16-2024, 09:34 AM | #13 | |
Rep 857
That said (and this depends on how BMW handles the updates and if it messed with the DME enough to break things due to calibration versions changing which may or may not matter if they match up with other modules in the car, if checked for security reasons before starting), but if someone’s REALLY that hung up on having the latest updates, buy another DME (these are cheap since they’re factory locked), clone it and swap DMEs when you want to update, then swap back. Again, not 100% certain on this on this platform, but this definitely works on others and a ton of people that want to keep bringing a car into the dealership for full service and updates will do this. You have one tuned ECU and one factory ECU and swap as needed. Anyway, people can do whatever, but I’ve always thought piggybacks were a shit way to try and tune a car. It’s bullshit… this isn’t 1995… even 1995 wasn’t 1995 since you could pull EPROMs and flash them on the bench and put them back in. |
03-16-2024, 10:48 AM | #14 |
Rep 191
JB4 you can add custom tuning. You can also run PI with JB4.
My buddy who has been doing a ton of R&D and is on this forum currently has a mid 9 second M3 on a JB4 with port injection. So if you don't want to unlock the DME you can still put down a lot of power with a JB4 if you have it configured right. |
03-16-2024, 12:26 PM | #15 | |
Rep 190,807
I traded my RWD for an X-drive because the power was too much for rear rear-wheel drive car.
