03-09-2024, 11:39 AM | #45 | |
Rep 4,149
03-09-2024, 02:11 PM | #48 |
Rep 1,038
BTW, using a REAL filter is the way to go with a turbo (if you can find one), not an oiled cotton media filter… those are just glorified bug screens. I say that somewhat hypocritically as I have one on a car, but it’s not turbocharged.
I would think a housing could be 3D printed if necessary without too much trouble. Turbos spin so fast that anything in the airstream will chew them up. Previous comment regarding oil contamination is true as well, and turbo bearings (ball or journal) don’t deal well with dirty oil. |
03-09-2024, 07:12 PM | #50 | |
Rep 149
The initial hit is way softer than a turbo car, but it pulls harder, higher up in the RPM range. -GT3M2 |
2Times1064.50 |
03-09-2024, 07:50 PM | #51 | |
Rep 857
This is why I like the S58 much. It literally is a modern day 2JZGTE. Only difference is the turbos aren’t sequential, they’re parallel from the factory. Toyota did that original setup like that because they wanted low end torque from the first smaller one and good power up top from the big one. When people go single turbo on those engines (to do it properly for a strong street and circuit high power setup) you do twin scroll like the OP did, so you get somewhat still good usable powerband and response and high top end power that doesn’t run out of steam. FYI, the RB26 that Nissan did has a setup on the turbos like the S58 does. Good sized medium power ones built for power from mid to upper stock RPM band. |
BMR.WRLD255.00 |
03-10-2024, 12:44 AM | #52 |
Rep 576
5150 AutoSport currently makes a 3.4L Stroker Kit for the S58. I’m not sure if a 3.5L kit has been made yet, but it could be in the works.
current
'18 F22 240i xDrive - FBO '16 F82 M4 ZCP - FBO previous '08 E90 335i Montego Blue |
2Times1064.50 |
03-10-2024, 11:27 AM | #53 |
I'd hit it
1065
Rep 1,106
First part of the question… BM3 just released an update which allows you to move the O2 sensor so it isn’t under as much stress… requires the ECU to be sent to Femto again though… I’m not doing that but cool that they’ve added it as an option for single turbo applications
2023 M4 xd BSM IG: MFor_YourPleasure |
03-10-2024, 03:17 PM | #54 |
i can haz horsepowr ??
3831
Rep 1,927
My single turbo build is finished up, just waiting on a dyno tune
DOC Race single turbo kit running a Next Gen PTE 6870. Precision RaceWorks port injection fuel rail with ID1050x injectors on stock intake manifold for now. Port fueling being controlled by MaxxECU. Currently also running Precision RaceWork's new standalone LPFP for the G8X, the AFS.425 since I'm not chasing big big power (hence why still on stock manifold too). All installed in a timely manner by M PowerHouse over in Mt. Vernon in N.Y. I drove her on the base map yesterday and she feels and sounds amazing. Currently awaiting Sameh, @SamehYehia, to dyno tune her on 93 fuel then I'll pick her up. I'll be doing street logging for ethanol blends. You'll also notice the filter on the turbo - it's essential for the longevity of the turbo and car in general. However, it muffles sound so it'll be taken off during specific occasions. On track days and daily puttering about - filter on. When I go to meets and am with friends - a mesh TurboGuard will be on as I refuse to completely raw dog it haha. Can't wait!
Dakar Yellow G80 M3
2Times1064.50 RUNSOK237.00 forcefed2567.00 Endeav388.50 McBobby Jr212.00 imperfectluck426.50 static_void965.50 yousefnjr6159.00 |
03-10-2024, 03:20 PM | #55 | |
I'd hit it
1065
Rep 1,106
That’s awesome!! So many different manufacturers (tuner) with the same goal. Fun seeing the options coming out and being supported for the S58
AhsanU3831.00 |
03-10-2024, 03:26 PM | #56 | |
Rep 1,446
AhsanU3831.00 |
03-10-2024, 07:31 PM | #61 |
Rep 1,038
03-10-2024, 07:42 PM | #62 |
Rep 54
More like upgraded turbos and increased displacement?
MilehighM3915.00 |
03-10-2024, 07:46 PM | #63 |
I'd hit it
1065
Rep 1,106
Check out the BigBoost upgraded twin kit… they keep the 2 turbo setup… I don’t really see anything good or bad about doing that compared to a big single… with the single I can always go bigger if needed. Twins you’re likely changing the manifold too
Sinister84035.00 |
03-10-2024, 07:55 PM | #65 | |
I'd hit it
1065
Rep 1,106
There will be others too
Sinister84035.00 |
