      01-31-2024, 08:18 PM   #1
nardobenz
Drives: G80 M3
Midpipe installed and now getting vibrations on the interior?
Hey guys! I just had the mad single resonated midpipe installed, and I'm realizing that at certain rpm/load the harmonics of the car vibrate the seat and interior. Is this normal? The car is completely stock other than the mad midpipe. I am wondering if maybe the midpipe is touching the car somewhere underneath?
Thanks
      01-31-2024, 08:21 PM   #2
kamakaziplayer
kamakaziplayer's Avatar
48
Drives: BMW 2023 G82 xDrive
check if its mechanical vibrations or speakers rattling. Same happened to me. I turned off ASD and it fixed my problem. My passenger side speakers were rattling
      01-31-2024, 08:30 PM   #3
nardobenz
Drives: G80 M3
I have ASD off, it isn't the speakers its for sure engine harmonics vibrating inside the car.
      01-31-2024, 08:45 PM   #4
markoz28
Drives: BMW 2017 340i, BMW 2020 M340i,
The mid pipe could be rubbing on the crossover brace. This can cause vibrations. Only way to tell is to get under the car. You need at least 1/4”
Clearance of the pipes from touching anything that is attached to the body.
      01-31-2024, 09:15 PM   #5
Info@mad-us.com
Info@mad-us.com's Avatar
1923
Drives: bmw
90% chance it's sitting on the brace . Loosen it all up raise it so it sits higher than you want it and it will sag right down the middle.
Also double check none of the bolts for the clamps are touching the heat shields. twist them if need be.
- Click Here
Performance Parts For Your Bmw At Crazy Low Prices!
Email: info@mad-us.com
      01-31-2024, 11:04 PM   #6
nardobenz
Drives: G80 M3
Originally Posted by Info@mad-us.com View Post
90% chance it's the sitting on the brace . Loosen it all up raise it so it sits higher than you want it and it will sag right down the middle.
I figured... I'll get it back on the lift tomorrow and update y'all. Thanks for the recommendations.
      01-31-2024, 11:05 PM   #7
Akrem3
Akrem3's Avatar
Drives: BMW M3 ISLE OF MAN GREEN
I notice this too at around 3000-3500 rpm and mainly in sport plus mode. ASD off and no part of exhaust touching anything. I have the single non resonated bay optics mid pipe. So far no solutions.
      01-31-2024, 11:25 PM   #8
nardobenz
Drives: G80 M3
Oh no 😥
      02-01-2024, 09:21 PM   #9
Jax327
Jax327's Avatar
436
Ive noticed some noises in my car as well after my midpipe install. I checked everything under the car and nothing is touching and the ASD is coded off.
      02-01-2024, 11:02 PM   #10
nardobenz
Drives: G80 M3
It isn’t touching anywhere unless it moves while driving.
      02-02-2024, 10:39 AM   #11
mike@x-ph.com
mike@x-ph.com's Avatar
It vibrates when the car is on, so even though it's not touching now, it will touch at a certain RPM if it does not have enough clearance.
From what you are explaining, you should turn off ASD, and if the problem persists, recheck clearance. I cannot think of any other reason
https://x-ph.com/sale/
Phone number 702-494-9435
      02-02-2024, 11:31 AM   #12
nardobenz
Drives: G80 M3
ASD has been coded already! I guess I will have the shop adjust it higher, but it looks like it has plenty of room.
      02-02-2024, 11:34 AM   #13
Info@mad-us.com
1923
Drives: bmw
Is the car on a lift? Check the clamp bolts and if the pipe is touching the heat shield anywhere.
- Click Here
      02-02-2024, 12:37 PM   #14
GolfCoyote
GolfCoyote's Avatar
568
Drives: 2024 M3 Comp xDrive
Could remove that brace temporarily and see if it rattles still? That would at least eliminate that to help you narrow it down.
2015 VW GTI (446whp/414wtq)
2024 M3 Comp xDrive
yeetyeet391.50
      02-02-2024, 01:52 PM   #15
nardobenz
Drives: G80 M3
I don’t think it’s touching the brace it just seems like it’s the engine harmonics at certain rpm’s. It doesn’t do it with the valves closed.
Akrem346.50
      02-02-2024, 03:54 PM   #16
nardobenz
Drives: G80 M3
Just had it on the lift. It isn’t touching anywhere, I guess it just is how it is.
      03-21-2024, 05:14 PM   #17
Akrem3
Akrem3's Avatar
Learning to live with it lol. Makes me appreciate having valves closed at times for a more luxury ride.
      03-21-2024, 09:58 PM   #18
kgelfen360
kgelfen360's Avatar
Which midpipe?
      03-21-2024, 10:03 PM   #19
Burrcold
Originally Posted by kgelfen360 View Post
Which midpipe?
He previously stated Bay Optics.
Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5
      03-22-2024, 12:44 AM   #20
christianb5s4
Drives: Built 2001 Audi S4
It's going to happen just off resonance from louder exhausts or stiffer suspension. Start by pinpointing culprits and use Tessa (felt tape) to take care of it.
