01-01-2024, 01:03 PM | #1 |
Rep 190,807
SST VALVE CONTROLLER INSTALL ON THE G8X’s
One of my customers did a review and installed it on their cars. Hopefully, this helps answer your install questions.
13
mathys202.50 JDUNITNOW3516.00 Idemo52.50 forcefed2567.00 Jax327436.00 blackops23486.00 808Gsxfknr24.00 SkyNinja8326.00 Bryantbjb52.00 nosbocaj695.00 Rotherd311177.50 Info@mad-us.com1923.00 M4Tejas788.00 |
01-01-2024, 06:15 PM | #2 |
Rep 2,617
Only problem with this method is I've found my signal reach is a bit inconsistent with the homelink that it doesn't always work. I had to move mine closer (behind the trunk liner).
Would be good if someone did an install video having it go through their battery compartment. |
Bryantbjb52.00 mike@x-ph.com24203.50 |
01-02-2024, 10:52 AM | #4 |
Rep 190,807
01-05-2024, 12:01 PM | #5 |
Rep 336
I have a question. On my remote, I have A and C programmed in my homelink. When Im in option C, the valves appeared to be closed when I hit M1 or M2 as well.
*update- So i played around some more with it. So when I put it on with the valves wide open, then hit C (stock) the valves close completely, when I hit M1 or M2 the valves are still staying closed in C. It did work one time when I could see the valves were open at 70% in option C but I started the car back up again and they were closed as if it were in B or C. Last edited by Jax327; 01-05-2024 at 12:32 PM.. |
01-06-2024, 01:30 AM | #6 | |
Rep 2,617
01-06-2024, 01:02 PM | #7 |
Rep 190,807
+1 OEM range goes from 0% to 70% based on throttle. Thats why it makes a big difference when you force the valves open with the valve controller.
Dnshift156.50 |
01-13-2024, 12:01 PM | #9 |
Rep 190,807
Thank you
01-14-2024, 06:41 PM | #10 |
Rep 1,279
Drives: 2024 BMW M4 Base
Had my SST installed this week. Mounted the controller in the trunk. I have a clip below. I start with factory valves in Comfort mode. Rev then factory in Sport+. The next set are valves open in Comport then in Sport +.
https://youtu.be/MNHdggXf-JI?si=Ot7BrOkTPGbtyQlx The only odd thing I noticed is the car gets super quiet even with the valves open when you come to a complete stop when in gear. Otherwise it works as expected. |
01-15-2024, 10:16 AM | #11 | |
Rep 190,807
wether the valves are open stock, with an aftermarket component, or manually, they should sound the same.
01-15-2024, 09:06 PM | #12 |
Grand Duke
1540
Rep 1,114
Drives: 2023 M4CSL
Maybe a dumb question, but why not just disconnect the stock plug on the exhaust? On my F80 I started the car, put it in sport plus, turned off the car, unplugged the valves and tucked them away. That left the valves always open, which is what I would want. That was the trick many would do. Is that not doable with the G8X platform?
2023 M4CSL
2005 Lotus Elise |
01-15-2024, 11:05 PM | #13 | ||
Rep 2,617
That and it's also nice to have the option to have it quiet so as to not wake up neighbors or if you're just cruising (there's a bit of drone at 1.7-2k RPM with the valves fully open). |
01-16-2024, 10:15 AM | #14 | |
Rep 190,807
01-16-2024, 01:33 PM | #15 | |
Grand Duke
1540
Rep 1,114
Drives: 2023 M4CSL
2023 M4CSL
2005 Lotus Elise |
01-16-2024, 01:38 PM | #16 | |
Grand Duke
1540
Rep 1,114
Drives: 2023 M4CSL
I just ordered some goodies from your shop, including a valve controller. I told myself I wouldn’t mod this car. I made it almost 2,000 miles before I caved.
2023 M4CSL
2005 Lotus Elise |
01-16-2024, 02:42 PM | #17 |
You got my money?
3158
Rep 4,646
Drives: Ice Cream Truck
You can remove the valve servo and worm clamp the butterfly valve open 100%. There is a thread on here on how to do it. Only problem with it is that you lose ability to be quiet if you wanted too.
I cant blast my neighbors every day at 6am so I went with the valve controller. Open 99.9% of the time and OEM mode when I cold start early mornings.
Dnshift156.50 |
01-17-2024, 10:50 AM | #18 | |
Rep 190,807
MNoob1539.50 |
01-17-2024, 11:17 AM | #19 |
Rep 256
Drives: '24 M3 Comp X-Drive
I haven’t even gotten my car yet (slotted for next week) and waiting for the SST controller to ship from germany haha. Shoutout to X-PH for great customer service.
Haters gonna' hate, ainters gonna' aint.
01-17-2024, 07:09 PM | #20 |
New Member - but old visitor
13
Rep 60
Mike finally pulled the trigger. SSTVC on its way. Thanks for the sidebar conversation. Ended up just ordering through the site. Hoping this does the trick, if not next stop Dinan X mid pipe
08 E92 M3 Space Gray (the one that got away)
13 Mini Countryman S (Had a good 10yr run) 23 G80 M3 DG (Base getting used to all the tech) 24 G05 X5 M60i (That damn V8 smh) love it. |
01-18-2024, 11:34 AM | #21 | |
Rep 190,807
My pleasure and congrats!
01-18-2024, 08:17 PM | #22 |
Rep 687
I can’t decide on a mid pipe. But I may not need one with this.
Order placed with some BMS Filters. |
