10-13-2022, 04:11 PM | #23 | |
Rep 92
On a stock fuel system best results are found around E60 as that's about the max ceiling for the fuel system on a max effort tune. Don't forget as well.... cold weather will play apart as to when your stock fuel system headroom falls off. You conceivably can be fast in warm weather and then start to have fuel headroom issues when the da drops. Max effort tune on stock Direct Injection is playing with Fire IMO . I would be conservative add the port Injection and reflex control so not to worry when pushing the envelope. I have always had excellent results and Excellent support from Paul Johnson |
10-15-2022, 06:42 AM | #24 | |
Rep 290
This part confuses me. Makes total sense if running an ancillary pump, but surely if you just hook up port injection to the stock fuel system what you gain at the manifold, you lose at the injectors (less fuel there). |
10-16-2022, 03:15 PM | #25 |
IG @bmwF9xG80
3813
Rep 7,593
Drives: G80 M3, X4M, G07 X7m50
HCP.CH 5.49s
Rick_Mlife G80Paul 5.55s HCP.Brasil 5.67s Mcc420 HCP US 5.70s (Canada Record Holder) rmeitz167 OrlandoAUTOwerks 5.80s To name some
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 Last edited by FSociety; 10-24-2022 at 03:30 PM.. |
10-24-2022, 08:59 AM | #27 |
Rep 273
Drives: 2024 BMW M4 Competition xDrive
Is the tuner handling the unlock for you as well? Meaning are they sending the dme to femto, or are you all sending it to femto directly, or is there some other service handling this?
2024 Verde British Racing BMW M4 Competition xDrive
2024 Sapphire Black BMW iX xDrive50 2023 Vapor Blue Ford Mach-E GT Performance Edition |
10-24-2022, 09:04 AM | #28 |
Rep 221
You can do it directly with FEMTO. If you can remove the ECU, you did the hardest part.
IG: @f98comp
10-24-2022, 03:29 PM | #29 | |
IG @bmwF9xG80
3813
Rep 7,593
I know @OrlandoAUTOwerks and @TristateBM3 are helping a lot of ppl in different states.
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
10-25-2022, 01:02 PM | #30 | |
Rep 92
Adding a secondary pump that comes on via a Hobbs switch or controlled thru the Motiv Pi controller will be necessary at a certain HP level especially on E85. I honestly don't know the ceiling for for the factory pump but I know people are going 9's on full e85 with port injection and factory fuel pump so at least 700 to 750 whp. My guess would be anymore that that and you would need an additional pump but maybe someone that's pushing those numbers can chime in. |
Vectors2final1356.50 |
12-09-2022, 09:45 AM | #31 |
Rep 673
UtkuNoaPerformance
I’ve used UtkuNoahperformance on my F90 and G80
Fastest I got full interior oem wheels on my 22 G80 FBO with stock exhaust on e40 is 60-130 5.86 and 1/4 9.98 @139mph. |
12-09-2022, 05:07 PM | #32 |
Rep 425
I'd go with F80 Paul, only because he actually owns a G80 now, which would give me more peace of mind.
2020 MG 330i xDrive M Sport
2023 AR M3 Competition M xDrive |
12-17-2022, 03:21 PM | #35 |
Rep 435
I'd go with Utku at UNP, he tunes all our shop cars. G80 fastest in the world and F90 right up there as well.
g80: 9.4 1/4 and 4.4 60-130 f90: 9.5 1/4 and 4.5 60-130 -R
12-18-2022, 06:21 AM | #36 |
Rep 1,074
Can I ask why you went with them over other tuners in the beggining instead of choosing other well known tuners? Im just trying to get more info as all i see is the same tuners being recommended. Which is why i went with F80 Paul. Please share your story with Utku at UNP. Could help others and myself
Instagram: M2_Medusa
12-18-2022, 08:03 AM | #38 |
Rep 86
Keep in mind, all of the 'big numbers' are guys in low low DA scenarios. There is a reason they post draggy slips cropped and are all posted around this time of year. When your near the coast and get -1400ft DA at 3am in the morning and it's 28F, of course your going to BrEaK REcOrds.
If your real life and don't live in a coastal area, your car will get close but won't get those numbers. I paid one of the big two tuners to tune my 16 M4 for a full E85. My DA is always at 4.5k or higher unless it's Dec or Jan and 1st revision was a balls to the walls misfire tune. Took 6 revisions to get it to not misfire, left me pretty sour at the whole experience. They blamed my plugs, boost leaks, etc. Ended up being the tune running out of fuel for my DA. Ended up throwing that tune away and went with https://abperformance.co/ . Avtandil has tuned my 16 M4 (Rare fueling combo at the time of M5 injectors w/ spool FX150 HPFP), my old 2020 X3M on E50 and now my M4CX. X3M's best was a 10.6 (draggy) at 3k DA and recently my G82 M4 a 10.5 at the track w/ a 4.3k DA (ECU was 1 day old from getting back from Finland so I blame my driving and not knowing how to launch the car, will go much faster)
~2022 M4 Comp Xdrive - Bm3, KW V3s, Downpipes, E50 Custom Tune
12-18-2022, 12:24 PM | #39 | |
Rep 435
The stage 1/2 projects are cake walk because we've developed tunes for those already. Thanks -R
12-18-2022, 12:28 PM | #40 | |
Rep 435
Then ends with ABP who only post dynojet "big numbers" in "low DA" I must be missing something here. -R
12-18-2022, 12:59 PM | #41 | |
IG @bmwF9xG80
3813
Rep 7,593
What you're missing is that ABP holds the F90 North America 1/4 mile record at 9.3 and they started only this year on this build while yours started in 2019. Just a few things you're missing not much
nickohlie111.00 |
12-18-2022, 01:12 PM | #42 | |
Rep 435
If you're going to bring tony's time up, then you can share how we didn't even launch our car, and braked hard at the end, yet still broke it. my car "only" does a 150+ trap and "only" runs 4.4 60-130 over and over. But we won't talk about that because that doesn't fit your agenda. -R
12-18-2022, 01:21 PM | #43 | |
Rep 1,074
12-18-2022, 01:22 PM | #44 |
Rep 1,074
Jordan doesnt blow motors, Users blow motors by asking for him to go beyond what he normally does saying " I know the risks " Then blame him. Cary has a bunch of blown motors in hiss arsenal also. Some people get tunes not even knowing what a misfire is. Everyone I know locally who has F80 paul is just fine, everyone I know that has Cary is just fine, Each of them have tuned many cars that blew their motor.
However nowadays their tunes are basically spot on. They figured this shit out long time ago
