07-12-2022, 06:35 AM | #23 | |
Rep 729
I thought the Alpin 5’s were the same size front and rear — I just looked it up and they appear to be. Here they are from an OEM parts supplier. I can’t find the “9,5J” for the rears on this screenshot, but confirmed it last night. I can dig more later. Very good catch on these differences. I never noticed the “J” and was just focusing on the ET offset.
BMW M3 Competition xDrive, Dravit Grey over Tartufo
07-12-2022, 08:56 AM | #24 |
Rep 1,241
The wheels on the 829M set are wider in the rear (9.5), same size tires though....so no wheel rotation from front to rear....
3/19/22: Deposit placed on MY2023 Skyscraper Grey M3 Comp xDrive / 6/08/22: Dealer order placed - Status 047 / 6/25/22: Added Full Leather / 8/05/22: Received Allocation & Added Personal eSIM 5G / 09/18/22: Asked Dealership to Add M Drive Professional to My Build and They Canceled My Order
07-12-2022, 09:10 AM | #25 |
1952
Rep 1,912
Drives: E92 M3
Absolutely do not buy the OE winter package, it's a terrible tire for real winters with snow and ice. Most of us that bought them in 2021 did it because there were no other options available with the necessary wheel sizes, offsets, etc.
Pilot Alpin 5s are "performance winter" tires which really means they're good when it's wet and cold, but not really cold and icy or cold with a lot of snow. xDrive will mask the traction issue in deep snow, but it will not if you're RWD.
Forzanerazzurri6919.50 |
07-12-2022, 09:19 AM | #26 | |
Rep 729
I am likely going with Vredestein Wintracs. I mention the 829’s and Alpin 5’s only for the purpose of deciphering the wheels size differences in this discussion. I am not advocating for the Alpin 5’s.
07-12-2022, 09:25 AM | #27 | |
Rep 729
How does the interaction work on the 829’s between the offset, wheel width, and the fact that on the OEM 829’s the Alpin 5’s are the same size all around. Thanks! Very good discussion.
07-12-2022, 09:35 AM | #28 | |
1952
Rep 1,912
Drives: E92 M3
07-12-2022, 09:42 AM | #29 |
Rep 1,241
Yes this would work....going with a complete square set of OEM sized/offset 19" wheels and size tires. Staying with the stock wheel/tire diameter and ensuring the brake calipers clear is what matters most, hence why I would just stick with OEM wheels to minimize problems. Improper offset could lead to rubbing issues, or increased debris being spun up on the body panels.
07-12-2022, 09:45 AM | #30 | |
Rep 729
Meaning 20mm from the center of a 9” wheel (4.5” center) is going to be slightly different than 20mm offset from a 9.5” wheel (4.75” center). And how does that 1/4” difference in offset add clearance for the suspension? Shouldn’t the smaller rear caliper still clear a 9” ET20 wheel? Argh. Crap. I thought I had my wheel sizes all sorted out. I thought it was fairly common for members on this board to get four of then same 19” wheel to use for a winter square set up. Will that work, or cause problems? Keep in mind that winter tires (at least for me) by definition mean less aggressive driving on dry pavement. So if I were looking for a set of summer wheels, I would definitely follow factory OEM dimensions to the letter and number. I do not intend to add spacers to my OEM summer wheels/tires. I am leaving that stock.
07-12-2022, 09:49 AM | #31 | |
Rep 729
You would suggest getting 9.5” x 19” ET20 for the rear? I was really hoping to be able to rotate the winter tires front to rear to maximize useful life of those tires.
07-12-2022, 10:25 AM | #32 | |
Rep 729
Or it is absolutely necessary that the rear wheel is 9.5” wide? I see people messing with offsets all the time using spacers. I just wonder how much 1/4” will really matter in this winter tire application.
07-12-2022, 10:41 AM | #33 | |
Rep 1,241
May I ask why not just buy the slightly staggered in width 829M Winter wheel set and use as is? Is the main importance here to have the ability to rotate the wheels from front to back? If so, these are Winter tires after all, so you won't be getting the best mileage from them. If you are concerned when using a square wheel set as to the look of the 9.0" rears being slightly tucked compared to the 9.5" wheels, you could always use spacers in back.
07-12-2022, 11:00 AM | #34 | |
Rep 729
I do not care if the rears look 1/4” more tucked with the winter wheels/tires. Right now I run steelies in the winter so am use to a different look. If that bugs me with nice winter wheels on the M3, your suggestion about adding a small spacer back there to correct to factory spec is a good one. And I really baby my winter tires. Once they go on the fun gets dialed back substantially. I think I am able to get 3-4 winters out of the Xi3’s (December through March is a season). Part of the reason the fun gets dialed back is that the winter tires just have so much lower of a limit on dry pavement than summer performance tires. And they feel a bit squishy, so the car doesn’t handle as sharply. And if we get a March snow storm, I don’t want to be left with thin winter tire tread because I was acting like a hooligan with them. The car will be my DD.
07-12-2022, 11:04 AM | #35 | |
1952
Rep 1,912
Drives: E92 M3
Front: 9,0J x 19" ET 20 mm Rear: 9,5J x 19" ET 20 mm 826M: Front: 9,5J x 19" ET 20 mm Rear: 10,5J x 20" ET 20 mm I don't really understand why they didn't do 9.5Jx19" ET 20 all around for the winter package. If someone knows, please share.
07-12-2022, 11:12 AM | #36 | |
Rep 1,241
Since my new M3 will also be a DD, not driven in snow storms (I have the ability to work from home those days), and will be on the car for 5 months or more a year, I think I can get away with just A/S tires and hopefully enjoy as much as a stock feel to the car as possible during that time. Fingers crossed!
07-12-2022, 11:16 AM | #37 | |
Rep 729
Winter wheels could be 9.5J x 19 ET20 all the way around. But the reality is probably that 9J or 9.5J on all sides probably doesn’t matter as long as they clear the calipers and suspension.
07-12-2022, 11:18 AM | #38 |
1952
Rep 1,912
Drives: E92 M3
There's a post somewhere on here that says 9.0Jx19 will not clear the rear. Still doesn't explain the odd sizing for the winter package.
07-12-2022, 11:20 AM | #39 | |
Rep 729
And to be honest, there is enough snow pack on the roads for several days after a storm that all seasons would be too much of a compromise. I also change the winter wheels myself so literally it sometimes happens at 8:00 pm the night before the first snow. It is much harder predicting when I am safe to take them off in the spring though. Summer tires in even a dusting of snow is really bad news.
07-12-2022, 11:23 AM | #40 | |
Rep 729
I might just bite the bullet and order 9J front, 9.5J rear and deal with replacing the winter tires sooner than I may prefer. Although I guess I will see how they wear, perhaps I can just do new fronts although I have always in the past done all four tires at once (but I could always F-R rotate summer and winter tires). I don’t think any of us are buying M cars to save money on wear items and gas….
07-12-2022, 11:36 AM | #41 | ||
Rep 1,241
07-12-2022, 12:45 PM | #42 |
6920
Rep 3,276
Drives: E46 M3 Coupe/G80 M3CX
So any issues if we run
826M Front: 9,5J x 19" ET 20 mm x4 all around for winter? |
07-12-2022, 02:57 PM | #43 |
Rep 30
I just ordered aftermarket wheels for winter and went 9.5x19 w/22mm offset as a square setup per the recommendation of the guy I worked with at Fitment industries
07-12-2022, 07:05 PM | #44 | |
Rep 729
Why the 22mm offset? Just filling out the wheel wells or function? I would be very interested in seeing how they look. When will you get them? Although will you not mount them until the winter?
