      01-31-2024, 09:15 PM   #1
hl0m4n
hl0m4n's Avatar
Question ► Sauna Install
i have an outdoor outlet, similar to pic, near the patio which i think has a conduit underground that leads to the garage where the fuse box is.
question is, can i remove the outlet and hook up the terminals to a 8kW 240vac 1ph sauna?
thinking about a barrel sauna and this would be the only power source available at the moment without having to install another line.
Cars: 07 335i ► 08 328i ► 11 328xi ► 13 M3 ► 17 M4 ► 14 M6
      02-01-2024, 06:30 AM   #2
vreihen16
Recovering Perfectionist
vreihen16's Avatar
Drives: 2015 BMW i3 BEV
If that is a 120V outlet, the best case is that it is a 20 amp circuit and fed by 12 gauge wire.
If my math is correct, you will need a 240V feed at 40 amps (33 amp load) including the usual safety factor.
I will let you Google for the required wire size for the above, and hope that your conduit is both passable and large enough for the new wire.
Disclaimer that I'm not an electrician, but had to install a 240V/40A outlet for my 32A EV charger.....
2015 BMW i3 BEV, Giga World (Lodge interior), Tech/Driving Assist Packages, 30K miles
2000cs3502.50
      02-01-2024, 07:55 AM   #3
antgenn
antgenn's Avatar
319
Drives: 2023 X3 M40i
2023 X3 M40i  [0.00]
2016 Infinity Q50  [0.00]
2016 BMW X3  [0.00]
That is correct calculation. One more thing to consider is how long are the wires. It may be necessary to increase gauge if over a certain distance for a given amperage. And one more: 240V wires should be red, black and grounding green. I bet the currents are black and white.
vreihen1615336.00
      02-01-2024, 05:29 PM   #4
vreihen16
vreihen16's Avatar
Size it for 50 amps?????
      02-12-2024, 05:13 PM   #5
vreihen16
vreihen16's Avatar
Originally Posted by JasonHayden View Post
Any update?
