11-06-2022, 05:53 PM | #1 |
Rep 48
CSL vs GT3 - Track Test
11-06-2022, 11:14 PM | #3 |
Rep 398
11-07-2022, 09:24 AM | #4 |
Rep 615
It really should be. I'm sure it's very close to the GT4 in overall capability. Perhaps a little better or a little worse in the corners but the CSL has a leg up in the power to weight and there is a lot of straight on that track. A stock GT4 only makes around 370whp. Then you have to ask what tires are the other cars running. You know what the CSL has.
forumlurker779.50 |
11-07-2022, 09:45 AM | #5 |
Rep 1,048
The CSL was tested on a CUP2R, whereas the GT4 was manual and on a normal Cup. The cup2R is worth probably 2-3 seconds here so realistically they’re about the same and PDK might be a bit faster even.
The GT4RS was 1:47.x so that should be telling enough. |
forumlurker779.50 |
11-07-2022, 09:46 AM | #6 | |
Rep 1,048
11-07-2022, 04:10 PM | #7 |
General
21117
Rep 20,741
Drives: 2021 911 turbo
While tires matter, I don't believe PSC2 to PSC2R would make that much difference. Hockenheim is a high speed track where power matters, the M4 CSL power-to-weight advantage over the GT4 also helped it quite significantly IMO.
11-07-2022, 07:52 PM | #8 |
Rep 1,048
They did a test not long ago of a cup2 and cup2r on a 1 min circuit and in the dry the cup2r was 2 seconds faster than the cup 2 on a GT3RS. The fact that the GT4RS did 1:47 (3 seconds faster than the CSL with a very similar power to weight) probably was split between the GT4 of 50% delta from power/transmission and 50% from tires. I do think a PDK GT4 with Cup2R would likely be a 1:50 car give or take. I mean the fact that an NA 414 hp car can do the times it’s doing is impressive to say the least.
11-07-2022, 09:15 PM | #9 | |
General
21117
Rep 20,741
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 11-07-2022 at 09:33 PM.. |
11-08-2022, 06:27 AM | #10 | |
Rep 1,048
11-08-2022, 09:32 AM | #11 | ||
General
21117
Rep 20,741
Looking at the average of tests, I don’t believe 1:50 is in grasp for the GT4, even with PSC2R. I know you are a big fan of Porsche, but we need to remain realistic here. Quote:
7MT=1:53.4 PDK=1:53.5
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 11-08-2022 at 11:53 AM.. |
PLF693766.00 |
11-08-2022, 12:04 PM | #12 | |
Rep 1,048
I think it would be close with a 2R (I believe you're underestimating their impact on a single lap) - that tire is incredible for a one lap time. The GT4RS and CSL have almost the exact same power to weight (6.4x for each based on power and weight from Sport Auto) yet the 4RS is so much faster, and while it does have more aero (only 25% more than a GT4 at 220 lbs @120 mph) but also much more high speed drag. The one thing these tests don't do a good job of at all is how well these cars would be over many laps. As much as some of these times seem great for one lap I don't foresee many of these heavier cars keeping these up for long. Have you run a Cup2R on your turbo S yet? Last edited by HeelToeShift; 11-08-2022 at 12:39 PM.. |
11-08-2022, 05:23 PM | #13 | |
General
21117
Rep 20,741
I guess we’ll have to agree to disagree on the incremental advantage of the PSC2R over the PSC2. Maybe I need to try a set and find out for myself.
11-08-2022, 05:31 PM | #14 | |
Rep 1,048
And conditions here do make a difference because the 992 GT3 already ran a 1:45.8 (which is 1.5 seconds faster than this test and on the same tire) a while back which was faster than a 765LT. Last edited by HeelToeShift; 11-08-2022 at 05:46 PM.. |
11-09-2022, 04:00 PM | #15 | |
Rep 161
M4CSL set almost the same time as the GT4RS! So, I don't think that your calculations are that simple |
CanAutM321116.50 |
11-09-2022, 04:24 PM | #16 |
Rep 2,700
Both car are so different in design it's just normal they perform differently depending on the track.
CanAutM321116.50 |
11-09-2022, 06:57 PM | #17 |
Rep 1,048
It's .42 seconds SLOWER on a VERY short lap that is geared towards high hp cars (like Hockenheim). 0.4 seconds on this track is a massive delta. After 20 laps, the CSL would be nearly 10 seconds behind - and that's if it could do 1:29.54 lap after lap which it would not as those times would get slower whereas the 4RS would able to do the same time with little to no delta.
11-10-2022, 03:08 PM | #18 | |
Rep 161
https://fastestlaps.com/tracks/val-de-vienne M4CSL 1:43.28 GT4RS 1:44.65 As you say, after 20 laps, the GT4RS would be nearly 28 seconds behind! And Val de Vienne is a relatively slow track, with overall average speed of 122 kph (76 mph) |
PLF693766.00 |
11-10-2022, 09:59 PM | #19 | |
Rep 1,048
From the article which you seem to have not read; “Second, the car was supplied to us with the very well established Michelin Cup 2s and not the Cup 2 Rs…Honestly, with the new Cup 2 Rs, I think it’s ahead of the GT3 (1:42.8)”, continues Christophe. And this is further proof of how much a CUP2R is worth. https://www.tracednews.com/chrono-to...-it-be-better/ So with the R it’s a 1.42.8 or faster and again that is crushing the CSL given how short the lap is. And again, the gap only gets larger as laps add up not even considering that 4 RS being able to be consistent in those times. Last edited by HeelToeShift; 11-10-2022 at 10:40 PM.. |
11-11-2022, 06:47 AM | #20 | |
Rep 161
But it still doesn't change the fact that you can't just put the Cup2R on the base GT4 and make it as fast as M4CSL on most tracks. First, what you have wrote is just a speculation on your part and on the part of the Christophe, because he, just like you "thinks", and until we have the time for the GT4RS on Cup2R's the M4 will stay a faster car on that track! In order for the GT4RS to be faster than the GT3, the tiers need to provide at least 2 seconds advantage on such a track! To put it in to a perspective, here are the Sachsenring lap times (the track with almost the same length as the Val de Vienne) for the GT4RS and GT4: GT4: 1:31.51 GT4RS: 1:29.12 So, according to your logic, just putting the Cup2R's on the GT4, it would make it almost as fast as the GT4RS?! I really don't think so, but that is just my opinion |
11-11-2022, 08:24 AM | #21 | |
Rep 1,048
You can say the M4 CSL is faster, but with the MASSIVE CAVEAT that it was on a MUCH softer, and MUCH faster compound tire - but giving this type of statement is not only illogical but rather foolish since it's not even close to apples to apples comparison. Equal out tires, and that is not the case given how much a Cup2R would be worth here (it's a ~4km track so about 2 seconds or more). Go look at how the Cup2R impacts times. When they tested the CUP2R on a GT3RS initially, the Cup2R was 1.8 seconds faster than the Cup2 on a lap that clocked just over 1 min. Imagine how that can play out over even longer laps... And again, you are WRONG on the tires longevity. The Cup2R is only good for 1-2 laps. After that it falls off a cliff - please go read up on this because the Cup2 over the long run will be the better tire, but not on a single hot lap. I also think that the driver, Christoph Tinseau would be much more knowledgeable on how a tire would impact a car. You saying his estimate is not accurate is like saying you're not going to trust a rocket scientist when it comes to propulsion engineering. https://fastestlaps.com/tests/z8kutlgj9k07 (left hand side it gives all the details; same for the 4RS link below) https://fastestlaps.com/tests/rlitl017mk58 I did NOT say the GT4 would simply be as fast as the RS just with tires (it would not). I said the gap would be cut down by 2-3 seconds at Hockenheim - the power and slight aero advantage take care of the rest. Last edited by HeelToeShift; 11-11-2022 at 08:42 AM.. |
11-11-2022, 02:34 PM | #22 |
Rep 2,700
A lot of you seem to assume changing tires will instantly provide a faster car, remember cars are driven.
What tires provide by adding grip is more confidence and a more confident driver will most of the time be faster. All I will say is the confidence between a mid/rear engine car and a front engine rwd car isn't the same at all, everything you feel from the the first time you start driving to the point your becoming fast is totally different. More variables than tires alone.
