11-17-2021, 12:49 PM | #1 |
Rep 1,902
Another KW HAS on M3C AWD
Dropped my M3 Competition M xDrive using KW HAS yesterday.
The front is almost at max drop and I love it that way. The rear is a little too low for my taste so I expect to raise it a little when I go for alignment. Ride quality is great and to be honest I didn't even notice a difference vs. stock driving it back home. First pic is "Before", the rest are "After". Update 12/2: I raised the rear all the way up. Added two pics to end of this post. Level ground. Looks much better now and that's exactly what I'm looking for but I'm surprised that's the highest you can go on KW HAS
2022 G80 M3 Comp M xDrive Last edited by M3AWD; 12-02-2021 at 01:34 PM.. Reason: Edited 12/2 to add pics after raising the rear |
11-17-2021, 01:10 PM | #2 |
Rep 10,166
Looks good but I agree on the rear being too low--- and thats on PS4's which have less protruding sidewall than the Pirellis.
Its a simple fix as you know you still want to put a few hundred miles on before the alignment. Raise it first, then let the parts settle and then align... dont align and raise.
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black Last edited by Vic55; 11-17-2021 at 01:24 PM.. |
11-17-2021, 02:58 PM | #3 | |
Rep 1,902
2022 G80 M3 Comp M xDrive |
11-17-2021, 03:39 PM | #4 | |
Rep 10,166
Thats what I would do and have done when Ive lowered cars where the tech went too high or low- get it to the proper height you want, then settle it via miles and align. YMMV Side note- my local alignment shop which vin scans, could not get the specs yet on the 2022 G80. But that was a week or so ago.
11-17-2021, 06:46 PM | #6 | |
Rep 3,051
2022 RAM TRX
2021 Ford Bronco 2022 BMW M3 |
11-17-2021, 07:12 PM | #7 | ||
Rep 1,902
11-17-2021, 07:13 PM | #8 |
Rep 1,902
I went to Solo Motorsports in John's Creek. If you need anything done there PM me.
11-18-2021, 04:22 AM | #9 | |
Rep 137
11-18-2021, 05:00 AM | #10 |
Rep 2,538
I promise I don’t understand this. Why do you guys like that look? Even weirder is when you take the wheels and put them at a angle when they are that low. It looks so gangster and ruins the beauty of a high-end sports car for me. To me it’s no different than if you put it on those giant tires that have hubcaps that spin. Then even some of you guys lower your car so much that you don’t have a prayer of even running over a small chunk of tire on the highway safely. You are definitely going to destroy your front spoiler when you have it that low. It’s absolutely just a matter of time. None of this makes any sense to me. I understand and get spacers to bring the wheels out a little. The factory puts them in because of regulations and laws to prevent rock chips from what I understand. So spacers I get. It definitely makes the car look better so long as it doesn’t stick out . But lowering your car so you can’t see 2 inches of the tires and so the spoiler is literally 2 inches off the ground just makes zero sense to me. It looks goofy and you’re going to damage your car. IMHO
11-18-2021, 06:16 AM | #11 | ||
Rep 1,902
11-18-2021, 11:56 AM | #12 |
Rep 10,166
Ill fathom its closer to 35mm plus seeing mine is 30mm and I dont have a tire tuck
Patton2502939.50 |
11-18-2021, 01:36 PM | #14 | |
Rep 750
also... |
11-18-2021, 03:56 PM | #15 |
Rep 2,538
11-18-2021, 04:50 PM | #16 |
Rep 750
11-18-2021, 08:44 PM | #18 | |
Rep 3,051
2022 RAM TRX
Vic5519354.50 |
11-18-2021, 09:11 PM | #19 |
Rep 1,902
From the factory the rear is lower than the front (i.e. smaller tire to fender gap). I'll raise the rear a little but might keep it slightly lower than the front.
11-19-2021, 01:09 AM | #20 |
Rep 1,074
This is mentioned several times in the MSS installation instructions. Does the G80 and G82 have a negative rake from the factory?
11-19-2021, 04:14 AM | #21 |
Rep 2,538
In other words keep my opinions to myself on a forum designed for people to interact and give their opinions? Gotcha
