09-13-2022, 07:33 AM | #45 | |
Rep 458
09-13-2022, 08:33 AM | #46 |
Rep 2,679
What I noticed is that I6 n/a and turbo run smoooth with Sunoco 93. When I use Shell or Mobil there are more click clack sounds in the engine so no more those unless Sunoco is unavailable in the sticks.
09-13-2022, 08:48 AM | #47 |
Rep 3,548
09-13-2022, 09:54 AM | #49 |
Rep 2,558
Diesel gets better mileage and low end torque so typically I mix in 30-50% diesel using a funnel. Better for the wallet than using lower octane.
Adds another 4-5 mpg and 30 ft/lbs |
09-13-2022, 11:13 AM | #50 |
Rep 2,442
Drives: 2022 M3 6MT
You know what's even more fun? Throw some diesel in the tank.
2022 M3 6MT - Portimao Blue Metallic
2022 X3 M40i - Tanzanite Blue Metallic |
09-13-2022, 07:32 PM | #51 |
BMW Owner Since 1971
2272
Rep 1,417
Drives: 1964 700 Sport Cabriolet
My E28 manual says 87AKI = 91RON
My E82 manual says minimum octane for 128i is 87AKI and 89AKI for 135i. It also says no harm will come from using these minimum-octane fuel though Premium is recommended. Wouldn't it make more sense if the pumps just said "AKI" on the buttons? |
09-13-2022, 08:10 PM | #52 | |
Darth ZEDer
6268
Rep 1,119
Drives: 2022 BMW Z4 sDrive3.0
09-13-2022, 08:15 PM | #53 | |
Darth ZEDer
6268
Rep 1,119
09-13-2022, 09:09 PM | #54 | |
2272
Rep 1,417
I don't really see what additional additives have to do with knocking and they have nothing to do with octane ratings other than the assumption that higher-octane fuels may contain more additives than lower grades. If you don't have deposits on your valves, you're getting enough additives. |
09-14-2022, 12:09 AM | #55 | |
Darth ZEDer
6268
Rep 1,119
I haven't seen anyone in this thread claim "additives have anything to do with knocking" but I'll suggest they could but only indirectly. Carbon deposits in the combustion chamber can build up to an extent that they can increase the effective compression ratio (and impact fuel/air dispersion patterns) thus increasing the likelihood of engine knock, especially under load. I suspect that scenario is rare due to minimum EPA standards for fuel additives and modern engines' ability to adjust timing to compensate. "If you don't have deposits on your valves, you're getting enough additives" I generally agree with that statement but how is the typical vehicle owner able to determine that without taking it in for an inspection that is likely to cost more than money saved buying cheap gas? Some Ford Ecoboost motors are infamous for carbon buildup and most vehicle owners didn't discover the issue until they started having engine problems. If curious, do a Google search for "direct injection carbon buildup". We're just trying to share knowledge and well accepted practices here. You do you. It's your vehicle and if you're happy with cheap gas, go for it. I generally buy new vehicles so I don't have to worry about what gas, oil, or service schedule was used by the previous owner of a used vehicle. |
09-14-2022, 08:36 AM | #57 | |||
2272
Rep 1,417
________4160.00 |
09-14-2022, 11:53 AM | #58 | |||
Rep 129
09-14-2022, 12:29 PM | #59 |
Darth ZEDer
6268
Rep 1,119
09-16-2022, 10:38 AM | #60 |
Rep 10,370
Knock sensors will retard timing and engine will make a few less HP. How much less is anyone's guess.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
09-20-2022, 09:58 AM | #61 | |
Rep 35
Recommended gas qualityCan you “recommend” a minimum? Rollercoasters don’t recommend that children meet a certain height; they insist on it. |
09-20-2022, 10:03 AM | #62 |
Rep 3
Always premium especially when you have a remaped car. on my car when i use regular one i fill like its dying, cant accelarate fast and consumes more so 99% i use premium gas. Also its cleaner means less trouble with injectors and low and high fuel pressure
09-20-2022, 11:49 AM | #63 |
Rep 1,328
It's already been said here, but Premium fuel from premium distributors tends to have the cleaner formulations with the higher additive packages. If all other things were EQUAL, one could use lower octane when you're just toodling around town, but then you're always wondering if you tromp on the throttle do you have enough octane to prevent knock.
Easier just to have it right, all the time. Shawn |
tracer bullet2489.00 |
09-20-2022, 11:54 AM | #64 |
Rep 328
As a matter of course I add a can of Berryman Chemtool fuel system cleaner every 1000 miles. Have had great success over the years with this product for M2C and e90.....
2023 M4 Comp
Dravit Grey Metallic |
09-20-2022, 12:07 PM | #65 | |
Rep 1,328
And then, WHY? I'm not saying fuel system cleaner is a bad idea, I'm just saying that skimping on fuel that you then NEED a fuel system/injector cleaner is a bad idea. False economy. Shawn |
09-20-2022, 05:17 PM | #66 | |
Rep 6,037
