04-04-2024, 05:43 AM | #1 |
Rep 440
Dinan X Midpipe
Anyone using the Dinan X mid-pipe on a g8x vehicle? If so what are your thoughts on it. I have been looking to increase the sound level of my 2024 M4 comp X-drive but don't want rasp, drone or burbles. I am aware that for a deeper sound the single mid-pipe is the way to go however I do not want to eliminate the secondary cats (I have a very sensitive nose for smell) and every single mid-pipe I've seen does so. I also feel there might be some muffling effect from the secondary cats so it wouldn't sound like a fully open exhaust. I will be keeping my factory muffler as I have a valve controller and it is open all the time so I cannot see any value that justifies the cost of replacing the axle back exhaust. I also do not intend to change downpipes.
04-04-2024, 06:29 AM | #2 |
Rep 1,929
There's no smell when you get rid of the secondary cats.
04-04-2024, 08:13 AM | #3 |
Rep 6,703
I have heard in person and it sounds great. Not too loud at all.
Race_Doc11463.00 M4Tejas788.00 |
04-04-2024, 08:25 AM | #4 |
Rep 440
I've heard that from several people but I know I can smell a lot of things that others cannot and some of the smells (such as this one) make me sick. I did watch a Active Autowerke's video where the person from the company talks about the secondary cats being needed to eliminate the smell so that scares me. Even these in-car air fresheners make me sick. I am thinking that later on I can add a secondary cat delete pipe to test for a smell which would be a lot less expensive than buying a whole new mid-pipe if I sensed a smell.
04-04-2024, 08:28 AM | #5 |
Rep 440
04-04-2024, 09:01 AM | #6 | |
Rep 1,929
04-04-2024, 09:02 AM | #7 |
Rep 6,913
i like my dinan mid, it's a subtle increase in sound, maybe too subtle. But a valve controller is a must.
2022 Dravit/Fiona M3cx - Dinan midpipe w/VC, NW Carbonhaus CF, AST Springs, FC Spacers...more to come!
2016 Indi F80 M3 - SMB|Amaro | Mode Carbon | ESS | Akra EVO | KW HAS...SOLD 2012 MR e92 M3 DCT, ESS SC, Brembo BBK, BBS FI... GONE but not forgotten! 2008 AW e92 M3 6MT, ESS SC, BBS LM's...SOLD! |
M4Tejas788.00 |
04-04-2024, 10:51 AM | #8 |
Rep 190,838
No smell from removing the secondary cats, but if you are looking for a subtle increase without changing the secondary cats, the dinan midpipe is an excellent choice.
M4Tejas788.00 |
04-04-2024, 11:06 AM | #9 | |
Rep 4,934
I wouldn't be concerned about any noticeable odor inside the vehicle when removing the secondary cats; it's unlikely you would notice any difference at all. However, if you're concerned about a slight increase in odor when standing behind the exhaust or in confined spaces like a garage, you might notice a small increase, especially if you're particularly sensitive to such odors. I'd still go with a full midpipe as the gains in sound from just removing resonators and is not likely to be worth the hassle or money. You also need to cut your stock midpipe in two spots if that matters to you. If you do go with the x pipe a valve controller will be a must.
04-04-2024, 12:42 PM | #10 |
Rep 440
I would just like exhaust of my M4 to be somewhat louder. I actually started out thinking about going to an exhaust shop and having the resonators cut out and replaced with straight pipes but then I would loose the crossover effect of an X or H system.
I have read enough to be convinced that the single mid-pipe would give me the deeper sound which I desire and probably would pull the trigger on the MAD single pipe if it was available in stock as the price seems reasonable. However, I don't like pre-ordering anything as I've gotten burnt several times in the past with multiple delays. In addition, there is the smell risk which would be a deal breaker for me. Right now is my down time for driving the car and I don't like tearing the car apart during the little nice weather we get where I live. As for the smell... I'm not talking about inside the car as unless the windows were down and the breeze just right I doubt it would get inside but standing behind or near it if it were running would be my main concern. I felt that with the Dinan mid-pipe that if I wanted to later on I could experiment with adding the secondary cat replacement pipes for under $300 and if I didn't like the result I wouldn't loose the entire exhaust system as I could just put the secondary cats back on and still have the extra sound level increase of the dual resonator delete. As for an additional cut on the stock exhaust it would certainly make storage a lot easier so I don't mind. My only concern right now with the Dinan mid-pipe is how it sounds and if it was raspy, had a drone or had excessive burbles. I want the character of the exhaust sound to match the rich character of the M car and not that of a teenager's (mother's) souped up 4 cylinder KIA. |
04-04-2024, 01:30 PM | #11 | |
Rep 4,934
With that said the dinan x pipe sounds like a good fit for you. Please report back and let us know how it goes.
04-04-2024, 06:42 PM | #12 | |
Rep 440
Right now I am thinking I would get the Dinan and play around with it as it isn't awfully costly. If I don't like it I'm not adverse to swapping it out and hopefully by then you will have your single mid pipe back in stock. But who knows, I may really like it and not need to do anything else. |
04-04-2024, 06:45 PM | #13 | |
Rep 4,934
Exactly. I think it fits yours needs especially with your concern of smell it will guarantee you have no more than you do now.
04-04-2024, 07:34 PM | #14 |
Rep 159
I recently installed the Dinan Midpipe and felt quite underwhelmed. It's louder than stock on coldstart, but barely noticeable on regular driving except the burbles are more pronounced. I don't have a valve controller yet, it might help.
04-04-2024, 08:35 PM | #16 | |
Rep 1,929
turbojg personally i wouldn't spend that much money for a dinan midpipe, any muffler shop will be able to cutout the two resonators for you for around $2-300.
04-05-2024, 07:28 AM | #17 | |
Rep 440
I do now have a valve controller and keep it open all the time. I am waffling between thinking that the mid-pipe swap (actually, resonator delete) might be either too loud or not loud enough - but leaning toward that it might not be loud enough. The problem is that I definitely won't be adding catless down pipes and am reluctant to remove the secondary cats. I really do think that removing cats might make the sound more raspy and burbly (which I totally do not want) unless I were to go to a single mid-pipe. Am I right or way off base with my thinking? forcefed - I initially thought about going to a muffler shop and having the two resonators removed but I gather that there is a need for some sort of X or H setup which I wouldn't trust a muffler shop with. So it comes down to buying something mass produced that I know works. Last edited by turbojg; 04-05-2024 at 07:34 AM.. |
04-05-2024, 09:03 AM | #18 | |
Rep 4,934
In your case if you were to go single I would be looking at a resonated single.
04-05-2024, 09:40 AM | #19 | |
Rep 440
Are the resonated and non-resonated singles both due in mid May? |
04-05-2024, 10:50 AM | #20 |
Rep 190,838
If you keep the downpipes and/or the axle back stock, I recommend the non-resonated midpipe.
If you are upgrading either of them, I'd go with the resonated midpipe for the cleanest sound.
04-05-2024, 12:25 PM | #21 |
Rep 1,929
Find some local g80 clubs/owners/meets and start asking them to rev their car and see what you like
04-05-2024, 12:32 PM | #22 | |
Rep 4,934
Yes both have a estimated ship date of may 15th. I recommend the resonated based on your comment about not wanting rasp. The resonator helps with that especially if you running the valves open more than factory. Forcing the valves open will allow less air through the muffler so a resonator is a good idea to have as it will smooth out the harmonics in the exhaust.
