03-30-2024, 09:39 AM | #1 |
Rep 450
What exhaust mod are you doing first if you're not 100 on doing a flash tune but defi
I’m thinking of starting with a DP since the rest of the exhaust system does little to nothing. I do not like rasp, excessive burbling, and prefer deep tone. Should I go resonated or 200 cell catted? If I go resonated thinking of keeping secondary cats (therefore no single pipe) to cut the smell/fumes. Thoughts?
03-30-2024, 09:57 AM | #2 |
Rep 871
Ask yourself what the max power level you want for the car. If you’re going to stay at 800 or under, just do GESI catted downpipes so you don’t have to worry about a CEL until you get a flash done. If you do 200 or no, you will set a CEL for CAT efficiency.
E63M6_G42M240i675.00 |
03-30-2024, 10:02 AM | #3 |
i can haz horsepowr ??
3833
Rep 1,930
Start with a valve controller, or wire the valves open completely so you actually hear what your car sounds like. AWRON has one, dÄHLer has one, etc. A bit of research as to which one works best for you should be conducted.
It sounds like MAD's resonated/catted downpipes + VT EL midpipes are your best bet according to what you're looking for. Catted dp's will be a bit quieter but resonated will be loud but less rasp, so it's up to you. Do not worry about the smell from the downpipes as there isn't any from in cabin even with the windows down. I put nearly 22k miles on mine and didn't smell anything in cabin but it is there if you're standing outside of the car with the car on. But you absolutely should get a single midpipe if you're after a deeper sound with less/no rasp.
Dakar Yellow G80 M3
03-30-2024, 11:16 AM | #5 |
Rep 1,929
I heard a g80 the other day with a catless dp, custom single midpipe(looks like any other midpipe actually but it was one piece and thick wall tubing) and a dinan catback and it sounded amazing, zero rasp.
I wonder if the thin wall tubing that most midpipes are made of contribute to the rasp.
03-30-2024, 11:33 AM | #6 | |
Rep 1,446
03-30-2024, 01:10 PM | #7 |
Rep 1,929
True, I just installed a single midpipe and not perfectly satisfied with it, a bit raspy with the valves open so still looking for that perfect sound.
03-30-2024, 01:55 PM | #8 |
Rep 2,026
03-30-2024, 02:10 PM | #9 | |
Rep 989
Drives: 2024 M4 Comp X-Drive
Exhaust stays in tact, easy to convert back if I decide not to buy out the lease in a couple of years, zero drone. Also considering coding out ASD while I’m at it too…
03-30-2024, 02:13 PM | #10 | |
Rep 450
03-30-2024, 02:16 PM | #11 | |
Rep 989
Personally I’d just go catless with the rest of the exhaust stock. There are a few videos around with this setup and it sounds amazing and is completely reversible.
03-30-2024, 02:29 PM | #12 |
Rep 450
03-30-2024, 04:15 PM | #13 |
Rep 1,929
Looks exactly like mad's single midpipe.
kgelfen3602218.50 |
03-30-2024, 06:04 PM | #14 | |
Rep 989
If you get 200 cell cats you’d want to use big Daddy O2 spacers that are just hollow with no mini cats. The ones you are talking about are also good but have the minicat actually inside the downpipe itself. Personally I’d prefer the cat in the O2 spacer itself.
03-31-2024, 11:36 AM | #15 | |
Rep 229
03-31-2024, 12:40 PM | #16 |
Rep 871
Which ones specifically and how many miles have you put on them in all different conditions? Secondary efficiency codes can be circumstantial sometimes if the CATs are just good enough… they could trip during long cruise control drives or just pulling out of a parking lot within 2 miles if you were parked long enough to be a warm start but long enough for the exhaust to cool down fully.
03-31-2024, 01:02 PM | #17 |
Rep 5,156
If you want deep tone but don’t like burbles or rasp, keep your stock cats and get the single midpipe. That’s all you need to start.
03-31-2024, 01:05 PM | #18 | |
Rep 229
04-01-2024, 12:40 PM | #19 |
Rep 4,934
200 cell and a midpipe with stock valves is my go to for the least rasp.
04-01-2024, 03:42 PM | #20 |
Rep 450
04-02-2024, 01:48 PM | #21 |
Rep 190,838
upgrading the downpipe will increase rasp. catted are a lot better than catless, but if rasp is a concern i would not start with the downpipes.
the single midpipe is the best starting point in my opinion. if you are keeping the downpipes stock, get the non-res option. if you are upgrading the downpipes, get the resonated midpipe
04-02-2024, 01:51 PM | #22 | |
Rep 450
