      12-06-2021, 08:56 AM   #23
jimbethesda
jimbethesda's Avatar
Drives: M3 (F80)
Originally Posted by Kminor2578 View Post
Iphone, it just start recently display the info, after the app was updated like a month ago. Make sure you're on the most UTD app.
My app is updated. Weird
2001 330Ci (sold)
2007 335i (sold)
2008 E90 M3 (sold)
2015 M3 (sold)
2022 G83
      12-06-2021, 08:21 PM   #24
jailonacs99
jailonacs99's Avatar
484
Originally Posted by JTO24 View Post
Also note that there's a setting in the tire pressure setting for "<100 mph" and ">100 mph" driving (for US folks).
If you select the <100 mph option, the target pressures will be as they are on your door jam, (32 psi I believe). If you select >100 mph, the targets will be something like 35-36 psi front and 38-40 psi rear as it is in the owner's manual. I forget what the actual >100 mph numbers are but they are a bit higher than the <100 mph figures. I know this because I selected the >100 mph option when I changed to my winter wheels/tires and then the system told me my rears were now low at 32 psi when they were fine before I selected that option. I since went back to the <100 mph option because realistically, I'm not hitting 100 mph in my daily drive (essentially no highway).
Does anybody know what the >100 MPH means in practice? Are you supposed to run that PSI if you go above every now and again (e.g. freeway passing like you mentioned) or only for sustained >100 MPH like folks who commute on the Autobahn?
JTO245274.50
      12-06-2021, 09:06 PM   #25
zambarossa
Vault Dweller
zambarossa's Avatar
Drives: 2021 M3 6MT (Dravit/KO/ZPP)
Only if you drive a significant distance at > 100mph.
JTO245274.50
