03-21-2022, 07:38 PM | #1 |
Rep 109
Wheel Oxidation
2,000 on my 2022 M4 with 825 bi-color wheels.
One of the wheels has some nasty oxidation in the clear coat already. I noticed this around 1,200 miles. I am 99% certain nothing I did caused this. Wondering if y'all have any suggestions on how to fix this? It's only on one wheel, all others are fine. I've tried claybar and i've tried a very light polish. Should I keep going with a cut and polish?
2022 G83 XDrive Comp - Dravit Grey
AST Lowered - VSC Valve Control - TLG Mud Flaps - AutoTecknic Carbon Head Rest Covers |
03-21-2022, 08:19 PM | #2 |
Rep 1,383
I wonder was there some steel on steel rubbing in the hub/breaks and you got some really hot Sparks melted in to the paint?
You can see a similar color on the rotor and hub |
03-21-2022, 09:02 PM | #3 |
Rep 109
It's a bit hard to capture in pictures. Here's another one with the problem area circled.
The rotors and calipers seem to clean up good. First picture was right after a wash.
bimmermann88310.50 |
03-21-2022, 09:32 PM | #4 |
You got my money?
3158
Rep 4,646
Drives: Ice Cream Truck
brake fluid leak?
03-21-2022, 11:28 PM | #5 |
Rep 596
Just throwing an idea out there but have you tried a heat gun? I've seen similar spots on paint get rectified with the application of heat. Don't over heat it though.
Hard to tell what it is. Is it rough to the touch? |
03-22-2022, 07:55 AM | #6 |
Rep 869
I'm not sure what's causing those specific spots, but I can see in your pic that you have pretty good spider webbing and scratches on those inner darker sections. I don't know how you wash your car, but it may be time to re-examine your wash routine to prevent further damage. How is the rest of the paint on the car?
2022 M3 xDrive, Brooklyn Grey over Tartufo
2021 Tesla Model Y 2019 MB AMG C43 (Sold) 2016 M235i xdrive, Alpine White, Terra Leather, Orbit Gray Wheels (Sold) |
Laguna01///M31397.50 |
03-22-2022, 11:10 AM | #7 |
Rep 1,241
Have you tried using just regular cleaner wax to remove those wheel spots? The wheels are not matte, right? Only use if they have a clearcoat.
Worked like a charm getting off similar spots on the black window trim of my wife's Mercedes. Be sure to use a microfiber applicator/cloth when applying & removing when dried....
3/19/22: Deposit placed on MY2023 Skyscraper Grey M3 Comp xDrive / 6/08/22: Dealer order placed - Status 047 / 6/25/22: Added Full Leather / 8/05/22: Received Allocation & Added Personal eSIM 5G / 09/18/22: Asked Dealership to Add M Drive Professional to My Build and They Canceled My Order
03-22-2022, 06:39 PM | #8 | |||
Rep 109
03-26-2022, 08:31 AM | #9 |
Eleet Tech
183
Rep 295
This may seem unusual but try this. I had similar spots and this cleaned it. Also removed water spots on my ppf.
I bought a used MacBook and it had some hard stains that alcohol wouldn't clean. This spray cleaned it up with no problem. https://www.chemicalguys.com/p40-qui...-detailer.html |
03-27-2022, 08:16 AM | #10 |
Rep 711
Be super careful on using chemical sprays on your car. There are some options out there I’ve heard people say that can eat right through your ceramic coating regardless of if they’re advertised as safe. Not sure if you have a ceramic coat or not, but just keep it in mind.
07-27-2022, 03:01 PM | #11 |
Rep 8
I have the same problem with the 825 bi-color wheels on my 2022 M3 and I have only driven it from the dealership to my house. I have less than 70 miles on mine. I have been paint correcting and doing a proper cleaning. I pulled the wheels off to coat the calipers and wheels and noticed the spots on the wheels when I was peeping them. They are all over my driver side wheels, but just on the front face of the black finish on the wheels. I haven't worked on the passenger ones yet so I'll be surprised if I don't find more of the same spots. I have tried clay and light polish and some cutting compound. It doesn't seem to affect the spots at all. It almost seems to be under the clear. The wheels are smooth as glass. The dealership did a half ass wash and out way to much tire dressing on it when I picked it up but I don't think they would have caused it but they might have. Anyone else have this issue or find a solution. I am ready to call the manager and tell them to replace my wheels.
2023 G05 X5 | AW | sDrive40i | mSport - 1/14/23
2022 G80 M3 | BGM | Competition xDrive 2011 E70 X5 | PG | 35i Sport 1984 Z28 | DB | 406 cid | 6-speed manual 2018 F80 M3 | AW | ZCP | DCT - (gone) |
07-27-2022, 03:02 PM | #12 |
Rep 8
My Pics didn't post
07-27-2022, 03:04 PM | #13 |
Rep 8
Few more
07-27-2022, 05:46 PM | #14 | |
Rep 445
07-27-2022, 09:46 PM | #15 |
Rep 109
I've yet to figure anything out. I've actually started now to have the clear coat peel on two of my wheels. it's very disappointing and fees like defective clear coat. I have it on 2 of the 4 wheels. I perform all the same maintenance and cleaning on them.
I am going to try a light polish and wax here this weekend and will report back.
07-27-2022, 10:13 PM | #16 | |
Rep 2,370
Formerly Wyndi335I
beden1511.00 |
07-27-2022, 10:20 PM | #17 | |
You got my money?
3158
Rep 4,646
S55 M313.50 |
08-03-2022, 04:20 PM | #18 |
Rep 1,661
S55 M3 (and OP), the discoloration looks like something was (over)sprayed onto the rims and left to dry. As Bigworm recommended, I'd demand the dealership take first crack at a remedy.
Now, if those blemishes appeared after I'd possessed and washed the car myself a time or two, I'd suspect hard water spots, or some chemical/cleaner which had been left to dry on those surfaces. CarPro Spotless does a great job on removing hard water spots, and CarPro Eraser removes oils and other contaminants (used a last prep step before ceramic coating). Other detailing brands offer comparable products; I just suggest based on personal experience. (FWIW, I too have bi-color 825s, still blemish-free even after one Michigan winter.) |
S55 M313.50 |
09-01-2022, 07:55 PM | #19 |
Rep 739
Im having the same problem with all my wheels after a few brushless car washes . I brought it to 2 different car detailers and had them try to fix the wheels and nothing… I have the tire and wheel insurance hopefully that will cover it!
09-02-2022, 02:31 PM | #20 |
Rep 701
I’d say in both situations a wheel cleaner is being left on too long, no products should ever be allowed to dry.
I’d try a fall out remover, then a non-acidic wheel cleaner and then a light polish. And also, unless you’re confident doing it yourself, get a quote from a detailer. It might only cost $100-$200.
Wo-Wo Detailing Accessories
www.wo-wo.co.uk |
Dr.Deep1827.00 |
09-02-2022, 11:08 PM | #21 |
Rep 2,370
That definitely is product left on wheels. Your car wash you use is not rinsing it off enough. I go back with a damp rag and get any residue left on wheels.
Formerly Wyndi335I
Dr.Deep1827.00 |
