04-20-2024, 03:21 AM | #1 |
Bmw340i Mppsk, bm3 tune,vrsf downpipe dinan intake
99
Rep 189
60-130 time dahler and cs tran tune 93 octane
6.95 decent da and temps half tank gas
|340i mppsk dinan intake vrsf catted downpipe|
|full alcantera carbon fiber interior| |bootmod 91, 93 and full e85 tune stage 2 agg| |firehawk tires and hawk perfomance brake pads | |bimmer code, | upgraded spark plugs full carbon exterior |
04-20-2024, 05:59 AM | #2 |
Rep 1,291
It’s not valid unfortunately, the spike near the end means you lost satellite connectivity, usually means you went under an overpass.
hellcat2m4227.00 |
04-20-2024, 07:55 AM | #3 |
Rep 86
So with draggy it can say it is a valid run but the spikes indicates actually it isnt...?? I thought if it passes under a bridge or something it would throw invalid due to low satellite signal. I guess what I am saying is this one of those cases where the run is barely legal?? 🤔
04-20-2024, 08:03 AM | #4 | |
Rep 1,291
04-21-2024, 11:39 AM | #12 |
Rep 508
You're just playing Russian roulette with a 25k motor because you can't monitor AFR, fuel trims, or knock with RaceChip. And without EWG control the higher RaceChip maps under boost heavily causing tuning issues. But hey, you can get a good time out of it a couple times to brag on the internet, right? That's worth at least 25k right there.
04-21-2024, 09:25 PM | #15 |
Rep 6,593
04-22-2024, 06:17 AM | #17 |
Rep 381
I agree completely and test my E content anytime I fill up containers. Where I live I get on average between 81-84%. Please do your due diligence and make sure you E content measure appropriate. With that said, if you have at least 80% E content then 1 gallon of E to 6 gallons of 93 is roughly E20.
forza19763399.00 |
04-22-2024, 08:06 AM | #18 | |
Rep 6,593
When I lived in Denver, best I could get was like 68% |
04-22-2024, 11:33 AM | #19 | |
Rep 191,145
if using a piggyback, we recommend the JB4 with E85 because of the following reasons: 1- dataloging to know when you reach max fuel trim before damaging your engine 2- Jb4 has E85 maps; other piggybacks do not. which brings 2 separate issues a) if you use E85 and don't add more boost, you are not getting much of the benefits b) some piggybacks don't even tell you how much boost each map is adding, this coupled with the no data logging is a bad combo
M4Lou442.50 |
