06-22-2023, 05:08 PM | #1 |
Rep 1,291
oil cooler damaged
I'm driving home from a hiking trail today and I got a low pressure oil light and the car told me to stop driving right away. So I pull off into a parking lot and look under the car and it appears there is a hole in the oil cooler and the oil is leaking out. I didn't hit anything so I think a rock must have kicked up and damaged it. I was concerned something like this might happen given the fact the oil cooler is completely exposed on the bottom of the car with no cover or anything to protect it. Has anyone else had their oil cooler damaged by road debris? The car is over at the dealership now so I'll be interested to see if they cover it under warranty or not.
06-22-2023, 06:34 PM | #2 |
Rep 766
Just curious, do you have the ZTK package with extra oil coolers?
This is the exact reason I didn’t option this package, the coolers are way too exposed Sorry to hear boss |
mblaucoupe135286.50 |
06-22-2023, 06:41 PM | #3 |
Rep 1,966
A skid plate to give it some protection is available through Turner motorsports, which I am now going to prioritize.
The brakes and wheels make ZTK worth it, IMO. https://www.turnermotorsport.com/p-1...0i-skid-plate/ |
06-22-2023, 06:47 PM | #4 |
Rep 1,291
06-22-2023, 06:49 PM | #5 |
Rep 1,291
06-22-2023, 06:51 PM | #6 |
Rep 1,966
06-22-2023, 06:53 PM | #7 |
Rep 1,291
06-22-2023, 06:55 PM | #8 |
Rep 1,966
Yeah, they really didn't take rocks and random road debris into consideration for something as serious as the oiling system. Hopefully they own up and cover it. Let us know how you make out.
06-22-2023, 06:58 PM | #9 |
Rep 1,966
I'm thinking some steel mesh secured over the openings on the skid plate will be a good idea. I'd rather sacrifice cooling a bit for more protection. My car sees no track time so I should be fine
06-22-2023, 07:02 PM | #10 |
Rep 1,291
06-22-2023, 07:03 PM | #11 |
Rep 1,291
That sounds like a good plan. I do plan to track mine here in a few weeks actually so I'm hoping this is all sorted out by then.
06-23-2023, 01:45 PM | #12 | |
Rep 272
This is only my opinion as I'm a retired professional ASE master grease monkey technician, now instructor. Your best teacher is your last mistake. Use what I post at your own risk as you know teachers only know book knowledge.
mblaucoupe135286.50 MPR1829.50 Bimmer Pleaser206.00 XC3LLR82062.50 Nate48151.50 CSBM52756.00 ayilar22.00 kwikit35627.00 |
06-23-2023, 02:34 PM | #13 | |
Rep 1,966
Even with that plate you run the risk of a rock putting a hole in the oil cooler. Was hoping to put in some stainless mesh |
06-23-2023, 02:54 PM | #14 |
Rep 272
I think that there is but there are deflectors to help prevent this. You have me thinking about this. Not a bad idea. The only thing I'm not sure about these is the front mounting is on plastic and a good hit might not save the cooler. The rear mount is solid so that might work.
06-23-2023, 02:55 PM | #15 |
Rep 220
I'm constantly worried about this. Going to prioritize the skid plate as well and I think it's a great idea to add some wire mesh to cover the openings.
I'm not sure how this design was pushed through. It's so obviously susceptible to damage that can be catastrophic to the engine. |
06-23-2023, 03:02 PM | #16 |
Rep 1,966
How would a deflector stop a rock from getting kicked up and hitting the fins? Do you know how large the openings are? Any images of the backside?
I ordered 2 of these: 1 PC 11”X14” (28cmX36cm) Wire Mesh 5 Mesh, Sturdy Metal Mesh Sheets for DIY Projects 304 Stainless Steel No Rust Mesh Screen https://a.co/d/di56BLr |
06-23-2023, 04:05 PM | #17 |
Rep 652
M240i Brooklyn Grey
My Build Thread |
06-23-2023, 04:30 PM | #18 |
Rep 1,966
Help what?
I just ordered the Turner skid plate and the stainless mesh is on the way, I'll post a DIY thread assuming the idea works. |
ZeusHorkios107.50 |
06-23-2023, 09:48 PM | #19 |
Rep 1,966
oldbmwtech did your car come with a plastic splash guard for your oil cooler? Mine is just sitting there commando
Turners skid plate description: "...The Turner skid plate weighs only a bit more than the plastic OE splash guard while providing an exponential amount of increased protection." Edit: nevermind, mine is like this https://g87.bimmerpost.com/forums/sh....php?t=1926516 |
06-24-2023, 12:42 PM | #22 |
Rep 652
M240i Brooklyn Grey
My Build Thread |
Invisiblename355.00 Nate48151.50 |
