11-28-2023, 08:50 PM | #793 |
Rep 413
Drives: BMW F30 335i xdrive
If they cannot adjust, they will do install and go with standart setting I would assume. When you have a car then you would need to pay probably alignment costs, i think it was like $220 (?) and they should follow your ask. If not… I would do alignemnt in other place.
12-01-2023, 01:37 PM | #794 |
Rep 1,067
I was under the impression that the port installers would perform an alignment? They aren't going to deliver a car that pulls to the side...
I don't have the patience to search all 37 pages of this thread again though. |
Limegrntaln13541.00 |
12-01-2023, 07:07 PM | #795 |
Rep 6,999
I don’t know why they wouldn’t? The car was aligned when it was built. Their job is to install the springs and put it back to factory spec. I can’t imagine delivering a car with a bad alignment. Although, my Civic Type R had the worst alignment from the factory.
YT: G Dubyou |
12-01-2023, 07:09 PM | #796 |
Rep 6,999
I wouldn’t think so. Unless it was a special request that was agreed to in a contract. And I don’t even know if that’s possible, or how you would even go about. If you had a contact at the port, you may have a chance, but, I don’t see any other way.
YT: G Dubyou |
mdr955359.00 |
12-02-2023, 06:55 PM | #797 |
Rep 990
Does it pair well with the spacers?(12mm)
12-02-2023, 07:08 PM | #798 |
Rep 6,999
YT: G Dubyou |
12-03-2023, 07:26 PM | #799 |
Rep 1,462
Drives: 2023 G81 M3 Touring
For those that are interested or end up here in the future, part number for OEM BMW M Performance G81 M3 Touring HAS suspension lowering Kit is 31305A87C79
12-03-2023, 07:28 PM | #800 |
Rep 6,999
Awesome! Thanks for the update! OP updated to add part number.
YT: G Dubyou |
MJBO2632.50 |
12-03-2023, 11:23 PM | #801 | |
Rep 413
What I meant is that for sure they can do alignemnt :-) but I doubt they will do anything unique like more of the track alignment. I would be positivly surprised if they do max out on negative camber and set the toe to zero as example Sorry for confusion. |
12-04-2023, 01:04 PM | #802 | |
Rep 360
2 questions. 1.Any rubbing up front/ And could you go to 15mm spacers in front without rubbing? 2.would you say this is a “level” drop, making the front and rear the same height? Love the look!
Current:
Past: - 2023 Brooklyn Grey G80 comp xDrive - 2020 Mineral White M340xi - 2017 Mineral Grey F80 ZCP |
RDG80M3X627.00 |
12-04-2023, 08:24 PM | #803 |
Rep 1,665
Dumb question, if you adjust the height does it need a new alignment?
18' F80 6MT, 991.1s cab PDK, F83 6mt, 996 C4S cab 6mt, F30 328iM 6mt
E60 M5 SMG, E39 M5, E46 M3 cab 6mt, E36 M3 5mt |
12-04-2023, 08:27 PM | #804 |
Rep 6,999
You “should” get an alignment with any suspension adjustments. And from listening to my installer, he had to readjust my rear springs after he drove it, and he had to remove the inside lower control arms to take the tension off the rear springs, even with the car in the air. So, after that, it definitely needs to be aligned.
YT: G Dubyou |
12-04-2023, 11:12 PM | #805 | |
Rep 317
1. No rubbing up front but I read reports of rubbing with even 10mm spacers up front so I had the fender liners trimmed just in case. I could definitely run a 15mm up front and I plan to switch to 15mm all around once these Pzeros wear out and I swap them for PS4Ss. 2. In person it is relatively even at eye level but I would say the front still rides slightly higher due to the size of the front fender well. To be fair this is as even as it’s going to get with the MP HAS. I personally hate the reverse rake “dumped” rear look so I knew I was going to max out the front from the get go. I also wanted the adjustability of the factory EDC without sacrificing ride comfort but if I had to do it again I’d get KWV3 coilovers and call it a day. I may do just that on the next one lol. |
carswithdonuts435.50 Limegrntaln13541.00 |
12-04-2023, 11:15 PM | #806 | |
Rep 360
Still waiting for car lol. But ordered 15mm front and 12mm rear spacers. Was concerned it’ll rub. But good to know. I don’t mind trimming a bit
Current:
RDG80M3X627.00 |
12-05-2023, 06:58 AM | #807 | |
Rep 346
12-05-2023, 01:57 PM | #808 |
Rep 1,067
Limegrntaln13541.00 mdr955359.00 |
12-05-2023, 03:41 PM | #809 | |
Rep 6,999
YT: G Dubyou |
12-07-2023, 05:54 PM | #810 |
Rep 786
Where have people been ordering the M Performance HAS Kit from? I see on the MP catalogue it's like 1800$ so wasnt sure if people have found it cheaper elsewhere. I was hoping to get the dealer to install it so it would be covered but 1800$ for what is essentially lowering springs is a tough pill to swallow.
Fugly M35161.00 |
12-08-2023, 12:14 AM | #811 | |
Rep 5,147
12-08-2023, 11:04 AM | #813 |
Rep 5,147
You can get the CS in gold for around 4100 shipped to you. That’s not that bad.
12-08-2023, 12:25 PM | #814 |
Save the Manuals
402
Rep 284
Here’s the link to Baum M Performance HAS kit. I ordered mine from here as well. Took about a month or two to get.
https://www.baum-bmwshop24.de/bmw-na...k-31305a2d979/ |
xxyion760.50 Limegrntaln13541.00 |
Tags |
g80 lowering springs, m performance accessories, m performance has, m performance suspension |
