      11-26-2023, 09:26 PM   #1
g80.dre
g80.dre's Avatar
100
Drives: '18 M4
G80/G82 Aftermarket Wheel Specs Differences
Hello all,
Looking to purchase a set of wheels off of someone with a G82 M4, I own a G80 M3. Are wheel specs pretty much the same for both?
      11-26-2023, 09:50 PM   #2
yeetyeet
yeetyeet's Avatar
Drives: '24 M3 Comp X-Drive
2024 M3 Comp X-Drive  [10.00]
2022 BMW X5  [9.75]
I was curious about this also. I want to lean towards them probably being the same.
Haters gonna' hate, ainters gonna' aint.
      11-27-2023, 02:11 PM   #3
forcefed
forcefed's Avatar
Drives: .
Why would you think that? Bmw has 4 models, g80, g81, g82, g83 no way they would have 4 different spec of rims. Only the g87 wheels are different, they're cast rather than forged.
      11-28-2023, 02:26 PM   #4
g80.dre
g80.dre's Avatar
100
Drives: '18 M4
Referring to aftermarket wheels with specific fitment. I assume they’re the same but just wanted to make sure beforehand
      11-28-2023, 02:53 PM   #5
TopJimmy
TopJimmy's Avatar
Drives: 2023 M3 Comp xDrive
Yes, G80 and G82 interchange stock wheels no problem. If you’re swapping aftermarket then check the Apex Wheel G8X fitment guide for tested sizes, offsets and advice.
      11-29-2023, 09:22 PM   #6
Camarejh
Camarejh's Avatar
Drives: 2021 BMW M3 Competition
The m4 is a tad wider. My buddy figured that one out. He swapped wheels (an 11 inch wide wheel with a +10 offset) that sat flush on a G80. He needed to put a tiny spacer on to get them flush on his M4. He ended up ordering his own set of the same wheels with a +7 offset.
g80.dre100.00
      11-29-2023, 09:23 PM   #7
Camarejh
Camarejh's Avatar
But all the stock wheels are the same specs with a +20 offset for all models except for the 18 inch wheels. Not sure what they are.
      11-30-2023, 10:11 PM   #8
Prossx
Prossx's Avatar
293
Drives: 21 G82 6MT SPY/YMB
If you go after market also check centerbore and bolt size if you want to easy swap yourself and use the same bolts.
Center Bore (DIA): 66.5 mm
PCD: 5x112
Thread Size: M14 x 1.25
15 F80 YMB DCT - retired
14 F30 MSport MG/CR 6MT - retired
