03-12-2023, 12:18 AM | #23 | |
Rep 1,702
03-12-2023, 06:45 PM | #25 |
Rep 1,702
Quick question. Are you saying that the xDrive Super Sports have a different drop height than the RWD version or are you saying that they are the same but the xDrive version is sitting higher than the RWD version?
03-12-2023, 08:03 PM | #26 |
Rep 608
That looks really good. I can’t wait to try mine out. 👍🏾
G80 Comp, Hcp custom e50, 9.69@141
F90 Comp, Hcp custom e40 meth, 9.76@143, 174ml/h 1/2ml 60-130 5.53 F10 M5, HCP Tune ,BM3, 10:8@137, 166.05 1/2ml. Ig @mcc420 |
03-13-2023, 08:32 AM | #27 | |
Rep 18
A few other Xdrive owners have complained that the Super Sports do not lower the car as much as what is advertised on the H&R site as well. I actually just submitted photos and measurements to them last week on this issue, as it seems they didn’t do sufficient R&D on the Xdrive with this spring kit. I measured bottom of rim to fender before and after lowering (once settled), and these were my results: My car only lowered 1.25” in the front, and only .4” in the rear (and yes, I confirmed that I had the Super Sport kit, not the Sport kit.) From what I have seen on the forums, this kit does appear to lower the full amount on RWD cars. |
03-13-2023, 08:53 AM | #28 | |
Rep 1,702
Would you say that after your drop, your front and rear gaps are pretty equal? They look it in pictures but I'm interested in your observation in person. |
03-13-2023, 03:53 PM | #29 | |
Rep 18
Also, as far as ride quality these springs are outstanding. Nothing will ever feel exactly like stock, but these ride super smooth. Not sure why people are saying the H&R springs bounce ? |
mirob3042.50 |
03-13-2023, 03:59 PM | #30 | |
Rep 1,702
03-20-2023, 01:13 AM | #31 | |
Rep 301
Here is an example of 20s and 19s |
03-30-2023, 04:58 PM | #32 |
Rep 253
Finally did it boys. Got my 20" squared setup dialed in today. Definitely how it should have come from the factory. Absolutely love this look...
03-30-2023, 11:53 PM | #33 |
Rep 301
Here is my 20 Square setup 826M 285-30-20s Finished it two weeks ago and love it
03-30-2023, 11:54 PM | #34 |
Rep 301
static_void965.50 |
03-31-2023, 11:06 AM | #35 | |
Rep 46
I know its expensive but there is a replacement low pro fender liner, curious if anyone is running those or just cutting the fins. Thanks, |
04-29-2023, 08:56 AM | #36 | |
You got my money?
3159
Rep 4,646
Drives: Ice Cream Truck
08-26-2023, 01:52 PM | #37 |
Rep 521
Drives: 2022 ///M3 6MT
Question - if I am on stock suspension and swap to the 20x10.5 ET20 wheels in the front with NO spacers and then mount a slightly narrower tire - 275/30/20 - will I have clearance issues? I assume the wheel width is the issue being 12.7 mm "further in" with no spacer, but everyone also seems to run the rear 285/30/20 size whereas the 275/30 would not only be slightly narrower but also slightly smaller in diameter.
Just trying to understand if the issue is only when lowered or trying to run a spacer or if the spacer is a requirement due to the additional wheel width up front. Thanks! |
09-01-2023, 01:40 PM | #38 | |
Rep 60
10-05-2023, 07:44 AM | #40 |
Rep 307
I'm about to find out once and for all for everyone. I'm diving in head first.
Rear 826M 20x10.5s, Michelin 285/30/20s, 12mm spacers all around and no trimming up front. We'll see if it rubs in about week or so.
Blake - 2024 M3 Competition xDrive
Square 826M 20" Wheels, Dinan HAS, Dinan Midpipe, Dinan Axle-Back Exhaust, Dinan 10/12mm Spacers, SST Valve Controller |
PipeM3196.00 |
10-05-2023, 06:50 PM | #41 | |
218
Rep 260
10-30-2023, 10:27 PM | #43 |
Rep 18
11-09-2023, 09:09 PM | #44 |
Rep 326
