03-06-2023, 07:44 PM | #1 |
Rep 259
Mixing bmw star with non bmw star ps4s same axle
At 400 miles I had to replace rear right tire after road debri sliced the sidewall. Tire certificates from discount tire was my first purchase so was covered but 10k miles later realize a standard ps4s was used as the replacement as it had much less wear then all three other tires that were needing to be replaced. I do have awd and transfer box code cf5573. Discounts getting me the proper tires but discussing possible damage.
03-06-2023, 08:09 PM | #2 |
6918
Rep 3,277
Drives: E46 M3 Coupe/G80 M3CX
What's the question?
03-06-2023, 08:16 PM | #3 |
1919
Rep 1,889
Drives: E92 M3
Mixing a standard PS4S and the BMW star spec PS4S tire on the same axle is fine. You won't notice the difference. You also don't need to worry about the wear difference because a couple of mm in tread depth isn't going to damage anything.
03-07-2023, 11:06 AM | #5 | |
Rep 2,700
It may also be totally possible that your diff code has nothing to do with your tires, keep in mind these cars are built pretty strong to withstand track abuse, the stress on a full track day is worse that street driving for 9k miles with a different compound tire.
03-07-2023, 11:55 AM | #6 |
Rep 259
If my car was all stock I'd just let bmw deal with it but they'd probably flag me for any issues or have to put it all back. Had the code before I modded it but figured the tire issue after.
03-07-2023, 04:33 PM | #7 |
Rep 687
So you're trying to figure out if there is damage to your car from a slightly different tire?
No. You don't have a claim against the tire shop. |
03-07-2023, 05:46 PM | #8 |
Rep 259
03-08-2023, 10:04 AM | #11 |
Rep 735
03-08-2023, 10:13 AM | #12 |
Rep 735
OP, for what it's worth, I wouldn't be concerned about damage, or future warranty coverage at the dealership (assuming you show up with matching tires on each axel and don't offer all these details). But I think the uneven wear you experienced is good evidence to avoid mixing different tires on the same axle. Even star vs non-star... The best approach is always to have identical tires on an axel. I'd even say avoid significant difference in tread. It sucks when you have to replace a tire due to damage when the other side still has half tread remaining, but when you go through tires so quickly anyway, is it really that bad of a cost hit to just replace both? That's what I've typically done in the past, and then sell the used tire to get a few bucks.
davidmct-M3234.00 |
03-08-2023, 10:36 AM | #13 |
Rep 541
The star and non star size tire is different. I know because a non star 285 front did not fit but a star 285 (my previous rears) fit fine for what it’s worth.
I won’t give an opinion on whether it will be problematic for your diff. Don’t know enough.
Instagram - _MOWE_
PLF693767.50 |
03-08-2023, 11:54 AM | #14 | |
Rep 259
03-08-2023, 11:56 AM | #15 |
Rep 259
Could you elaborate on the fitment issues with the non stars?
03-08-2023, 12:25 PM | #16 |
Mr. Irrelevant
3642
Rep 589
Good information/video found here:
https://g80.bimmerpost.com/forums/sh...65&postcount=4 Credit to Limegrntaln
Past results aren't a guarantee of future performance.
Forzanerazzurri6918.00 Limegrntaln13473.50 |
03-08-2023, 12:30 PM | #17 | |
Rep 259
03-08-2023, 01:05 PM | #18 |
Rep 541
It’s been stated and I found true that the tires may be the same number size, the reality is a star tire is a little smaller in overall diameter.
Star fit. Non star in same size rubbed up front.
Instagram - _MOWE_
03-08-2023, 01:27 PM | #19 |
Rep 735
Yeah, I understand what happened to you and didn't mean to say you made any bad choice since you had no intention of mixing star and non-star. For the people saying it's fine to mix I was trying to point out that the difference in lifetime you experienced is pretty good evidence that mixing isn't a great idea. And if they are not exactly the same size to start with, that's even more reason not to mix.
11-26-2023, 11:49 PM | #20 | |
2022 M4 Comp Xdrive
1016
Rep 1,540
Any updates on this? |
