11-03-2023, 09:35 PM | #45 | |
Learning to drive again
720
Rep 324
Drives: M3CS
Cheers,
BoB |
11-03-2023, 10:04 PM | #46 |
Rep 74
Makes sense. My view is coming from what I’ve learned from the person who as done all of the work on the car and the spl engineer who’s been able to drive it out on COTA. Suffice it to say you definitely know a lot more about suspension set-up than I do. And I could be conflating the “need” for sway bars based on their opinion, with the issue of the car’s slowness to change direction.
11-04-2023, 10:55 PM | #47 | |
720
Rep 324
Drives: M3CS
Best of luck and have fun.
Cheers,
BoB |
11-05-2023, 06:00 AM | #48 | |
Rep 74
BackOnBlack720.00 |
11-10-2023, 11:47 AM | #49 | |
Rep 4
Apologies for this miscommunication, but Eibach USA is working on development for bars on the M3/4 and M2. In fact, anyone local interested in getting the vehicle to Eibach, let me know (messages aren't active yet). CSL bars are currently the benchmark, but open to hear what owners are really looking for. |
11-10-2023, 02:51 PM | #51 | |
Rep 74
11-10-2023, 03:27 PM | #52 |
Riding the knock sensor
2378
Rep 1,596
Drives: 21 X5MC | 23 M4CSL
I can put a caliper on the CSL bars if that helps. I assume they’re solid- if not I.D. won’t be possible but pretty certain they’re solid.
11-10-2023, 03:28 PM | #53 |
Rep 4
M4nication498.50 |
11-10-2023, 03:55 PM | #54 | |
Rep 74
I did see that H&R is making sway bars for xdrive and rwd starting anytime. Some stores are showing them “in stock” but they are a couple of weeks out. With that said, H&R is a little more street performance and less track. |
Hit_Apex2378.00 |
11-14-2023, 05:26 AM | #55 |
Rep 324
Drives: '24 M4 Competition xDrive
11-14-2023, 06:18 PM | #56 |
2378
Rep 1,596
I agree academic, as it can be difficult to compare bars that can vary in material, and design. The CSL front bar is 29mm and appears to be a solid design. The rear on these cars is at the least variable and possibly hybrid material. On the CSL the torsion section (straight middle) is just 20MM which narrows down from 25MM at the ends. I vaguely recall something about this type of design that may be a mix of materials or construction. Keep in mind the weight difference, while the CSL is more aggressive, this may not translate into fatter/stiffer bars due to lighter weight.
None of this may be relevant, but never assume an after market product is more aggressive than all OEM variants. Many manufactures will market a product that was originally designed for variant x, later discover it works (bolts up) to other models, and simply add those models to their “fits” list without any testing or consideration to benefit. Lastly, ARBs were very popular in the past when cars came with mild setups. It may be the case that G8x cars can be tuned from full race to street sport with a good coilover setup using the stock bars where aftermarket bars just add an unnecessary variable to the mix. This is my current lean but open to other points of view.
11-14-2023, 08:46 PM | #57 | |
720
Rep 324
Drives: M3CS
Cheers,
BoB |
11-14-2023, 08:54 PM | #58 |
Rep 74
I guess we’ll see. I ordered the H&R bars and will have them installed by mid December, then out to the track a week later. It won’t be scientific but should be a decent before and after.
Hit_Apex2378.00 PabstBleuRibbon484.50 |
11-16-2023, 03:41 PM | #59 | |
Rep 4
Hit_Apex2378.00 |
11-20-2023, 09:42 AM | #61 |
Rep 250
11-20-2023, 11:47 AM | #62 |
Rep 4
Great review! Good to see the juice is worth the squeeze. It's a shame stabilizer bars keep becoming more and more challenging to install being tucked into subframes, as they are a good tuning tool.
11-21-2023, 09:09 AM | #64 |
Rep 250
11-21-2023, 09:59 AM | #66 | |
Rep 250
any other accessory parts needed to make this swap? bolts/hardware? https://parts.bmwnorthwest.com/p/bmw...358091425.html |
Tuner199.00 |
