07-14-2024, 03:35 AM | #1 |
Rep 25
Fix-it ticket for loud exaust, whats the procedure?
So.... i got pulled over for having a loud exaust. My car has the Valvetronic Stainless Steel full system, NO down-pipe and HAS cats. So now I'm unsure what needs to be done. Do i really need to go back to stock to have it tested, or can i take it in with the valves closed on comfort mode and pass? Well they require me to open valves and put it on Sport + and rev it?
Few places i read they said the cars are tested at normal operating conditions which means it can be on comfort since that's the default state when the car turns on and valves closed reved slowly up to 2500-3500 RPM, if that's all that's needed I'll 100% pass since the exaust is very quiet on comfort with valves closed. Anyone been in this situation before? P.s. a lit of cars are wayyyyy louder then this stock out of factory like Lambos, Hellcats and mustangs and 1000 others. Sure they might be quiet on comfort mode with the valves closed and only get loud on track modes but that's the same situation with a after market exaust. They can't possibly make me put it in a super agressive setting and then test it because if that's the case, every person driving the cars i listed should get a ticket as soon as they buy the car. |
07-14-2024, 05:41 AM | #2 |
Rep 27
Drives: 2025 M4 Competition
DreamM3,
I have not been in your situation, however, I would switch back to stock (if still available)...get it tested and be done with it. And of course, you could always take another chance...hopefully, they used a decibel meter to determine your exhaust sound. And finally, please don't worry about those "other" drivers...this is on you...don't mean to be harsh, but the other drivers (Mustangs, Lambo's, etc.) are not going to help you. Semper Fi |
flipflop9.00 |
07-14-2024, 07:42 AM | #3 |
Riding the knock sensor
2733
Rep 1,778
Drives: 21 X5MC | 23 M4CSL
Is this a state ref referral? If so, the inspection will be about identifying whether the exhaust is modified or in disrepair and the car overall is emissions compliant. Volume is not really a consideration other than the officer's assessment that it is louder than stock and should be inspected. How it compares to other stock cars is irrelevant.
07-14-2024, 10:28 AM | #4 | |
Rep 25
07-14-2024, 12:21 PM | #5 |
2733
Rep 1,778
No, you will fail the visual inspection since none of the exhaust mods for these cars have been CARB certified.
07-14-2024, 12:55 PM | #7 | |
Rep 25
That's why I'm asking if i can pass with the after market exaust already on the car without having to do all this |
07-14-2024, 08:16 PM | #8 |
Rep 1,227
Ouch. Gotcha. May be worth a try if you don’t have any other non CARB mods like tuner or intakes that they can look for. You can always go the other route if you fail. You might want to consider a Quick Jack if you plan other upgrades like spacers, lowering springs etc. very simple to swap out the exhaust with one of those. Pays for itself after remove and replace exhaust on 2 cars.
07-21-2024, 12:18 AM | #9 |
Rep 893
Been through this, switching back to stock is the best scenario. The key is fix it is correct able so you can try valves closed and hope CHP doesn't go to far on inspecting everything else.
07-25-2024, 11:03 AM | #13 |
Rep 6,798
07-27-2024, 10:12 AM | #14 |
Rep 893
07-27-2024, 12:20 PM | #15 | |
Rep 6,798
Did this change? |
07-28-2024, 12:22 AM | #16 |
Rep 893
Technically you can just pay it off to the tune of $1k ish, so you could. But the caveat is what I mentioned.
08-06-2024, 01:15 PM | #17 |
Rep 215
OP, is there a little sticker on your ticket that says referee inspection required? Or does it just say inadequate muffler. If it’s the second option pay it, if ref inspection buy ramps from Walmart and do the swap yourself or do the swap at any muffler shop and get the car inspected
current garage:
2023 m4 comp 2022 m8 comp 2021 panamera 4s 2021 M5 |
08-20-2024, 10:44 PM | #18 | |
Rep 14,187
Drives: G82 M4C X-Drive
