      01-19-2023, 09:37 PM   #1
juniM3
juniM3's Avatar
Drives: BMW G80 M3
DW Fuel Injectors for port injection failing ?
I’ve heard around that 2 G80’s have ran into issues with the DW injectors claiming they failed on their car and caused serious motor damage. DW is pretty reputable and wouldn’t expect this. Anyone running Dw’s and came across any issues ? Would like to know before installing on my car lol.
      01-20-2023, 11:34 AM   #2
mikewho_G82
mikewho_G82's Avatar
175
Drives: G82X
was the issue ever identified? clogged injector? or did it die completely?
      01-20-2023, 12:59 PM   #3
cleaningup
Drives: 23 M3, 68 GTO, 18 Wrangler
I just installed pi with 550 dw injectors. I’d love some more info on these failures and to grab a different manufacturer if this is happening
juniM31.50
      01-23-2023, 05:24 PM   #4
TKT2SPEED
TKT2SPEED's Avatar
140
Drives: 2022 G80M3 Comp X Drive
subd ......
You Cant go wrong with IDX from injector dynamics but the smallest they have is 1050 which is pretty big unless your going for big turbo power.
I may go idx anyway just for the reliability even though they are bigger than what I need.
I'm not knocking DW at all for all we know there was an installation error and one cyl wasnt gettiing the proper fuel
      01-23-2023, 11:35 PM   #5
juniM3
juniM3's Avatar
Drives: BMW G80 M3
I’m pretty sure it died completely this, It’s coming from a random source I met at a car meet just making thought i just ask around since i’m about to run it aswell. He also ran 1100cc which on a stock thrbo car is overkill which can cause inaccuracies in fuel spray.
      01-24-2023, 09:39 AM   #6
amrazM
mTekMods
amrazM's Avatar
Drives: like a granny.
I would avoid DW products.
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged
First DCT to Manual Conversion Worldwide
KW CS, BBS RI-A, BW Headers, Snow 2.5
      01-24-2023, 09:45 AM   #7
juniM3
juniM3's Avatar
Drives: BMW G80 M3
What’s you’re reasoning for that? Just curious because debating if I should switch out these injectors or not on my PI kit i’m installing soon.
      01-24-2023, 09:57 AM   #8
TrackSpecM3
Drives: BMW M3
DW injectors to me have always been known as pretty iffy. Can't go wrong with ID!
      01-24-2023, 10:59 AM   #9
mikewho_G82
175
Drives: G82X
we are running id1050, seems to work great stock turbo. I would stay with ID or FIC.
juniM31.50
TKT2SPEED140.00
      01-24-2023, 11:05 AM   #10
amrazM
mTekMods
amrazM's Avatar
numerous issues with DW in tank pumps, throwing off fuel trims, not supporting ethanol, pumps getting damaged from E. this isnt new data, alot of the japanese car tuners tend to advise away from DW parts.
I had issues with my dw in tank pump, switched to aem and never looked back.
      01-24-2023, 03:33 PM   #11
juniM3
juniM3's Avatar
Drives: BMW G80 M3
Thank you so much definitely going to sell these DW’s and not take the risk on it. If it isn’t too much to ask for if you could send me the link for tbe Id’s that would be great i see so many not sure which work with the car PI.
      01-24-2023, 03:43 PM   #12
TKT2SPEED
TKT2SPEED's Avatar
140
Are you running Motiv for port control ? Ecutek or BM3? Only asking because I'm on BM3 so will be making my own port map since they dont have integration....Its not the first time Ive had to do it but would be cool to get my hands on a base file for ID 1050's that I can tweak?
I was going to reach out to Jacob at Motiv and see if he has one.
      12-09-2023, 09:06 PM   #13
vladdy3f
vladdy3f's Avatar
Drives: 23 BMW M3C X-Drive
Hoping someone can give me some light in my situation.
I have mishimoto manifold/ fuel rail with FIC 1200 injectors running reflex. Car is a full bolt on car running e70.
We are struggling to get into a 5 second 60-130, I’m seeing guys doing 5.0 with my set up. I’m tuned by a very reputable g80 tuner.
Is there a chance that the injectors are too big and it’s causing the car to run worse ?
      12-10-2023, 12:00 AM   #14
Mapper
Mapper's Avatar
Drives: M3 Competition
What is your DA?
      12-13-2023, 10:14 PM   #15
TopJimmy
TopJimmy's Avatar
Drives: 2023 M3 Comp xDrive
I ran ID1050x with Kratos EVOs on my F82 and will use the same ID1050x in the Mishi manifold on my G80 (still with Kratos).
What turbo(s) are you using?
      12-14-2023, 08:47 AM   #16
vladdy3f
vladdy3f's Avatar
Stock turbo, trans, motor
TopJimmy5539.00
      12-20-2023, 11:22 AM   #17
ZheroG80
Drives: 2022 BMW M3 Comp XDRIVE
1200cc is big stress on your lpfp if you're running just the factory pump.
Could be the limit on your tuning. What's the fuel pressure in a wot pull?
      12-21-2023, 05:24 AM   #18
blackdm
blackdm's Avatar
China
47
Drives: F82/G80
Hello brother, how does it feel to use BM3 and MOTIV together? I want to use this solution and want to chat with you.
Current - G80 M3 Xdrive Fire orange
Past - F82 M4 Racing yellow
Riders from China
