02-22-2024, 01:25 PM | #133 | |
You got my money?
3210
Rep 4,696
Drives: Ice Cream Truck
Thats true, but technically there is coding to add to make it work exactly like OEM. The coding you enable in bimmer code activates a setting menu in idrive for the charger that will allow you to set a reminder on/off to take your phone out of the tray when you shut down the car.
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
03-12-2024, 09:17 AM | #134 | |
Rep 6
Digital key disappeared from Samsung Wallet and I am unable to add it back. I can however add the keycard back, so reader is functioning. Tried: S24+ / S23+ iPhone 15 Reset digital keys for all profiles. Uninstalled and reinstalled app. Followed the instructions here: https://bmwi.bimmerpost.com/forums/s....php?t=1947441 I get the e-mail with the activation code, but the pairing fails as soon as I place the phone on the charging pad. Anyone else experiencing similar issues? Last edited by JDSmith14; 03-12-2024 at 12:35 PM.. |
03-13-2024, 11:53 AM | #135 | |
Rep 6
Can you please confirm if you only had issues with your phone before re-coding / Did the NFC card work before you re coded? My NCF cards works fine after the retrofit, but I am experiencing the same issue as described above when trying to add the phone. |
03-13-2024, 12:00 PM | #136 | |
You got my money?
3210
Rep 4,696
I dont remember if I had my iphone setup as a key before doing the wifi charging retrofit. I had issues adding my iphone as a digital key after doing the wifi charging retrofit. Adding bimmercode WIFI coding to idrive made my NFC/Wifi charging pad accept my iphone. Not sure if my NFC key gave me any issues or not. I dont use that. But adding the two codes for the wifi tray in bimmercode got my iphones to pair immediatly.
03-13-2024, 12:04 PM | #137 | |
Rep 6
Thank you BIGW0RM - Will update here after coding |
BIGW0RM3210.00 |
04-02-2024, 12:11 PM | #138 |
Rep 6
Thank you BIGW0RM
I can confirm that I had to code the following two options: Body Domain Controller BDC > WCA_ENABLE = aktiv Headunit HU > WCA = aktiv The digital key activated first time after adding these. |
