01-11-2024, 06:28 PM | #1 |
Rep 218
Yellowstuff EBC
So i was going to break in the front pads and misread what the instructions were so instead of breaking from 80-30 in .2 miles 8 times i breaked 80-30 pretty quickly then repeated every .2 miles, i then did the second break in which was 80-20 every .2 miles pulling .4 gs. Did I ruin my rotors or pads?
01-11-2024, 06:35 PM | #2 | |
Supreme Allied Commander
3863
Rep 54,426
Drives: F80 M3
01-12-2024, 12:22 AM | #3 |
Rep 218
Heres a picture hoping its not bad
01-12-2024, 10:42 AM | #4 |
3863
Rep 54,426
Drives: F80 M3
I don't see any pad smearing or heat check marks. You should be fine. Looks like you put new pads on used rotors? It might take another bed in session to get the pads to uniformly seat on the rotors.
01-12-2024, 11:05 AM | #5 |
Rep 190,975
your rotors look fine to me.
01-12-2024, 03:23 PM | #6 |
Rep 218
01-12-2024, 03:28 PM | #7 |
Rep 218
01-12-2024, 03:30 PM | #8 |
Rep 5,645
Do another round of the recommended bed-in procedure. Don’t forget to get the rotors up to temp with normal driving/braking for 15-20 min before doing the pad bedding. Try not to engage ABS during the pad bedding process.
S58King147.50 |
01-12-2024, 04:16 PM | #9 |
3863
Rep 54,426
Drives: F80 M3
For a mild/OE/Street performance street pad what you want to do is 60-20 slow down with 80% pedal pressure. Repeat this half a dozen times. Sometimes a few more times depending on the compound(or another bed-in cycle after cooldown). I personally like to do it until I feel the pads fade then go into my cool down drive(as little braking as possible for around 5 minutes on the highway).
S58King147.50 |
01-12-2024, 06:20 PM | #10 | |
Rep 218
01-12-2024, 06:22 PM | #11 |
Rep 218
Ebc has 3 bed ins I might do the third phase since I haven't yet which includes 90-20 80% brakes then full speed back up to 90 6 times followed by 20 minutes of coasting.
01-12-2024, 06:55 PM | #12 |
Rep 5,645
Six 90-20 mph stops is aggressive for street pads and you’ll get the pads to fade before you reach the sixth stop. This sounds a bedding process for a track pad which the yellow is not.
01-12-2024, 08:14 PM | #13 |
Rep 218
Well the yellows are considered track pads they were removed because the bed in was so long, blues bed in much faster
01-12-2024, 08:35 PM | #14 |
Rep 5,645
Yellow is a higher performing street pad and is in the elusive dual-duty street-track pad category. I don’t believe there’s a dual-duty pad - it’s either street or track. I don’t know what “light track driving” even means. I have no personal experience with EBC pads. The Ferodo ds2500 is supposed to be like the yellow compound but the ds2500 gets destroyed on track.
01-13-2024, 02:52 AM | #15 | |
Rep 218
01-15-2024, 10:22 AM | #16 | |
Rep 190,975
the blue pads are considered a hybrid that works for street cars and casual track days. The RP are the trackpads.
S58King147.50 |
