09-28-2021, 02:33 AM | #45 | |
General
60144
Rep 19,586
If two searchlights were fitted above say the bridge with an arc of around 25-30 degrees there was a very good chance of spotting an iceberg as far as five miles away. |
09-28-2021, 03:05 AM | #47 |
General
60144
Rep 19,586
09-28-2021, 05:26 AM | #49 |
General
17317
Rep 18,740
I would think that cold North Sea ocean water would act as an excellent heat sink and draw any damaging level of heat out from the steel hull. The laws of Thermodynamics being what they are.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
09-28-2021, 05:59 AM | #50 |
General
60144
Rep 19,586
The damage was already done in still warmer waters from first stoking up the boilers and the coal around them catching fire.
09-28-2021, 07:32 AM | #51 | |
Rep 1,222
M5Rick60143.50 |
09-28-2021, 08:21 AM | #52 | |
General
60144
Rep 19,586
White Star decided the original 32 boats would clutter the decks too much and look ungainly, also a lifeboat lowering and training drill was cancelled by Smith as he thought it was a waste of time. |
09-28-2021, 09:01 AM | #53 | |
General
17317
Rep 18,740
to the 21st century. But if there was coal burning in the coal stores, where did the emissions go? Coal is not very clean burning. I doubt there would be liveable conditions below deck to operate the power train. The ocean around Irealand is a good heat sink too. Anyway, have fun with the conspiracy |
09-28-2021, 10:01 AM | #54 |
General
60144
Rep 19,586
A three storey high coal store behind one of the boilers was on fire, a team of 12 men tried to put it out but was impossible with temperatures reaching 1000 centigrade, so when Titanic struck ice on that specific area it tore open the ships lining much more than it would have if there had been no metal weakening. The fire was raging even before the ship left Belfast.
09-28-2021, 12:33 PM | #56 | |
General
60144
Rep 19,586
The engines worked but every time the ship would move it for sure would expedite the flooding. |
09-28-2021, 01:01 PM | #57 | |
General
60144
Rep 19,586
09-28-2021, 03:25 PM | #58 | |
Rep 443
09-28-2021, 04:09 PM | #59 |
General
60144
Rep 19,586
This is where it gets interesting, the fire started when the ship was light displacement LWT,without passengers, cargo,supplies equipment etc so waterline was above water level heating up bad and already metal affected before full Deadweight tonnage DWT and under water setting sail for NYC.
09-28-2021, 05:08 PM | #60 | |
Rep 443
09-28-2021, 05:55 PM | #63 |
General
60144
Rep 19,586
Under White Star then it was ''sail or be crucified''. The storage was overloaded with coal (even taken from other steamships) that was burning and the thought was just to keep shovelling it into the boilers a lot of the time to eventually get some containment.
This had the effect of keeping the ship at full speed under Captains orders to make up for lost time. |
09-29-2021, 03:16 AM | #64 |
General
60144
Rep 19,586
The steel used on Titanic hull was the best plain carbon ship plate available at the time, though the sides of the ship were single plate the bottom of hull was actually double plate.
However an analysis done on a piece of plate taken from the ship showed that it had a high ductile/brittle transition temp making it not good for use in low temps. This, combined with the heat weakening, -2c temp of sea at time of collision and angle of strike,speed and position of it all sought to go against Titanic. |
