01-27-2022, 01:41 PM | #1 |
Rep 31
8HP76 -- Testing the Tq limit
Wanted to start a thread for those of you who are well into modding your G8x platform with the new 8HP76. Since there is no concrete proof of the tq rating, we are going off of the tq rating of previous models and determining it is 760 Nm or around 561 ft-lbs. It is not taking much at all in terms of modification to get to this number.
Who here is documented above this? Have you had any issues? Do you have the AWD or RWD varient? How many miles have you driven with tq above 561? How many times have you used launch control? |
01-27-2022, 02:12 PM | #2 | |
Rep 542
I wouldnt expect any issues with it below 1000Nm. Depends on the usecase though. For constant launch control starts, which is a lot of stress for the transmission, you might want to reduce the torque a smidge. Keep the oiltemps in check and that thing can handle quite a punch. |
01-27-2022, 03:14 PM | #3 | |
Rep 31
01-27-2022, 03:19 PM | #4 |
Rep 542
If you want to see what might be possible with that gearbox, check out what the M5 F90 comp is able to deliver with tunes. It uses basically the same transmission.
01-30-2022, 10:08 PM | #5 | |
IG @bmwF9xG80
3813
Rep 7,593
Drives: G80 M3, X4M, G07 X7m50
2019 Model Custom ECU & TCU by HCP https://www.instagram.com/p/CXjga-2K..._web_copy_link 2020 Model - Custom ECU by HCP
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
01-31-2022, 08:25 AM | #7 |
Rep 571
Drives: '19 GLA45AMG(his) / '21 X3M40i
I'm glad to hear these numbers.
My target is 650hp/650tq, which apparently this engine/trany is more than capable of generating/supporting. I was telling the boss just yesterday how we had to change fuel injectors, fuel pump, go catless, flex-fuel, and a tune just to brake into the low 600s with the GTR. And with the S58, all you practically need is a tune; e85 if you want to get in the 9s (from what I've heard, at least).
Currently: '19 GLA45AMG grey (his) & '21 X3M40i DGM (hers) w/ JB4@Map1
Previous cars: 2022 M4 xDrive in Mexico Blue with Silverstone/Black interior 2014 BE GTR FBO/e85 |
01-31-2022, 11:18 AM | #8 | |
IG @bmwF9xG80
3813
Rep 7,593
Heck the BM3 OTS Stg1 & Stg2 E30 make 600-640whp already
GixY2K517.00 |
02-06-2022, 08:26 AM | #9 | |
Rep 53
Our STG1 Tuning on the X3M with E50 goes 10.4x consistently full weight - and that thing is a heavy Another X3M we do has stock downpipes, goes 10.22 - that's the record. (Ricer Math) With Port Injection and better traction it's a 9second truck. Driveshafts, front diffs have been the weakest link on the X3Ms - when drag racing. The only time the transmission has a problem with slipping is when the tuner messes with the trq value going to the tcm. Some have done this in the past to bypass a trq limit - this isn't the correct way to tune. The G8X's do have wheel hop issues which has already caused a very expensive failure for someone. I know of 2 S58 failures in the G8X platform, 1 was a hydro lock from a meth kit gone bad, and another was pushing the platform - we weren't involved with either. Point is, the S58 is a beast, and so is the transmission. |
02-06-2022, 03:22 PM | #10 |
Rep 542
Well engine wise, since the S58 has taken over the connection rods from the S63 engine, i guess it's safe to assume that the engine itself wont push far beyond 900Nm, before the rods are starting to bend.
02-09-2022, 04:52 PM | #12 |
Rep 6,950
I saw this posted on FB, yesterday. People are definitely pushing the envelope. Id be down for this, safely. 911 Turbo S killer.
YT: G Dubyou |
FSociety3812.50 |
02-10-2022, 09:03 AM | #13 |
Rep 501
I wonder what it would take to make 650 HP and 650 TQ to the wheels max, and then run a map for 550 hp and 550 tq daily.
I know its obviously possible, just what the setup to achieve that would entail. |
02-10-2022, 02:29 PM | #14 |
Rep 571
I'm going to go on a limb here to say that this would most definitely require full access to your DME (unlocked), e85 flex-fuel capabilities, a tuner that has access to a dyno. CAI & pipe may just not be necessary with this extremely capable engine.
Froz3n_M399.50 |
02-10-2022, 02:34 PM | #15 |
Rep 6,950
I remember seeing a car on FB, probably a week ago, with the fully unlocked DME, with just an E50 blend, everything else, stock, running 9.90s. in the 1/4. Im sure that car has to be close.
YT: G Dubyou |
GixY2K517.00 floating.spirit1017.00 |
02-10-2022, 03:06 PM | #17 | |
Rep 571
I forgot to mentioned that on the fully unlocked DME, you'll require a fueling system that will support e85. Now this opens the question as to whether that's all you need to go full e85 with the JB4 and thus increasing hp output. But full disclosure, I'm also learning about the tunability of the S58. Not like my GTR which was pretty simple in comparison; point and shoot when it came to upgrades.
Previous cars: 2022 M4 xDrive in Mexico Blue with Silverstone/Black interior 2014 BE GTR FBO/e85 Last edited by GixY2K; 02-10-2022 at 04:36 PM.. |
Froz3n_M399.50 |
02-10-2022, 04:28 PM | #18 |
Rep 6,950
Im not sure anyone is in the 9s with a JB4, even with full boltons. I think Darrell Coleman is pretty close, if that's the case.
YT: G Dubyou |
Froz3n_M399.50 |
02-11-2022, 09:03 AM | #19 |
Rep 6,950
Read the bottom of the picture, then the HP figures, I posted in post #12.
YT: G Dubyou |
02-12-2022, 08:31 PM | #20 | |
IG @bmwF9xG80
3813
Rep 7,593
630-650whp i've seen on STG2 E30 OTS Custom Maps would prob be better to have it right where u want it on BM3 Custom Tune with either a HCP, Paul Johnson, or Cary Jordan to name a few great tuners on the platform.
Froz3n_M399.50 |
02-13-2022, 11:32 AM | #21 | |
Rep 571
On one hand, I'm happy to stand corrected. But on the other, I wonder how long this set up will last, or if said dyno is just a snapshot/milestone of a 'work in progress' of an S58 that will eventually get upgraded parts, and so we won't see the reliability of running those numbers w/out at least an upgraded fuel system. Has anyone posted the telemetry from the S58 stock fuel system? Are the pump(s) and/or injectors running within specs or are being maxed out?
Limegrntaln13440.50 |
02-13-2022, 12:04 PM | #22 | ||
Rep 6,950
YT: G Dubyou |
GixY2K517.00 |
