      06-16-2023, 09:13 AM   #1
R44 Performance
R44 Performance's Avatar
United Kingdom
1791
Drives: Part of the process%E2%80%A6
Best daily stance for a g80?
So since the release of this front spring option from Eibach we have been selling them out non stop. This Eibach spring set up is designed to ride and feel just like OEM but will drop and delete the drastic arch gap you get from factory.
One of the biggest faux pas with the G80 specifically is the HUGE arch gap but with this spring and the R44 stance kit we have put together, you get the thickness and clean look that the car deserves.
We pair the front springs up with the 12mm (front) spacers and 15mm in the rear and I think if you are a daily driver and not really someone who wants to go for that "slammed" look, but wants to improve the stance this is the option for you.
Fitting these is super simple and all in with an experienced garage should only take around 1:30 to 2 hours to get fitted in.
Drop myself a message today and if you are a USA customer we have 1 set available for free shipping.
      06-16-2023, 09:49 AM   #2
FDfranklin
d[-_-]b
FDfranklin's Avatar
484
Drives: Ordered: 2023 G80 M3 6MT
How true is this though? Will you notice a difference? Does this have any effect on the suspension settings (sport/comfort).
      06-16-2023, 10:09 AM   #3
ChemLab
ChemLab's Avatar
128
Drives: Current - 2023 RAM TRX
Same question. Also, I'm assuming this kit works on the M4. Correct? What's the cost?
      06-16-2023, 11:42 AM   #4
chris s
chris s's Avatar
1250
Drives: 2022 Dravit G80 M3
I have a hard time believing mismatched front and rear springs is good for the suspension geometry. But hey, to each his own. I personally would opt for a matched set.
2022 Dravit/Fiona M3cx - Dinan midpipe w/VC, NW Carbonhaus CF, AST Springs, FC Spacers...more to come!
2016 Indi F80 M3 - SMB|Amaro | Mode Carbon | ESS | Akra EVO | KW HAS...SOLD
2012 MR e92 M3 DCT, ESS SC, Brembo BBK, BBS FI... GONE but not forgotten!
2008 AW e92 M3 6MT, ESS SC, BBS LM's...SOLD!
jmg18709.50
      06-17-2023, 08:36 PM   #5
geko29
Drives: 2023 M3 6MT
If they’re the same rate but just slightly shorter, the car should drive exactly the same.
      06-17-2023, 09:08 PM   #6
evoi19
evoi19's Avatar
Drives: 2022 G80C
I’ve had mine for a year now with no issues. It rides and handles like stock but with an OEM+ look. Definitely lessens the front gap and the stance is more even front to rear.
      06-18-2023, 08:33 PM   #7
chris s
chris s's Avatar
1250
Is that the case with the eibachs? Haven’t heard that to be true.
      06-18-2023, 10:05 PM   #8
jmg
jmg's Avatar
18710
Drives: G82 M4C X-Drive
2022 G82 M4C X-Drive  [9.85]
2018 F80 M3 CS  [9.87]
2019 i3 BEV  [0.00]
Technically the stance is uneven, but the gap is even. It's not the same thing.
Explanation below:
The front gap is bigger because the front suspension needs to travel more and have room to compress with the wheels turned, unlike the rears.
OEM heights with uneven gap is actually balanced, in fact BMW M cars are touted for it's near 50/50 weight distribution. Lowering the front more gives the car a forward rake, ruining that engineered advantage. Under hard braking conditions, that means more weight on the front than normal, which can lead to the rear end to be loose. Under accelerating conditions, you can actually lower potential traction with less weight over the rear wheels.
On the street, for "daily stance" as the thread is titled, this is fine. While this is not a "performance stance", if you are braking that hard and accelerating that fast to be competitive on a road coarse or drag strip, then you are not really looking for a "daily" setup. So, technically, it will NOT drive exactly the same, but you will likely not even notice it if you are just street driving.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing
Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3
IG: Raging_G82
Aalfred2619.00
LuckyBrand1321.50
BIGW0RM3157.50
      06-18-2023, 10:30 PM   #9
fanofbmwe46
Drives: M3
Well said. I’m never tracking my car, just spirited road driving and weekend car shows so the eibach front set up with spacers all around will be perfect for me.
      06-19-2023, 04:19 AM   #10
evoi19
evoi19's Avatar
Drives: 2022 G80C
Explanation below:
Agreed. I was speaking more towards the look. I assume those who do track at amateur or competitive level aren't going to just do the front springs.
Anyways, my set is going up for sale next week if anyone is interested!
      06-29-2023, 06:38 AM   #11
R44 Performance
United Kingdom
1791
Hey, its only for the G80 unfortunately but if you wanted another set i'd be happy to work out what we could get you sorted with.
      06-30-2023, 10:54 AM   #12
anthony412
Drives: '24 IOMG M3CX
Can you share what the ground clearence is at the lowest point (between the front and rear wheels)?
      07-14-2023, 10:31 PM   #13
fanofbmwe46
Drives: M3
Love it
Galandel193.00
Tags
eibach, eibach pro, eibach pro kit, eibach prokit, g80, g80 build, g80 m3, g80 springs, g81, stance
