03-11-2024, 09:39 PM | #1 |
Rep 62
problerm with auto roll down windows
Hello friends, I greet you with pleasure and take this opportunity to ask the owners of M2 G87 or series 2 from 2022 onwards, (I assume the Edrive system is the same).
The problem is the following: there is a function to automatically lower the car's windows halfway by PRESSING THE UNLOCK BUTTON TWICE, and then opening the door. This function is activated from the car in the windows/key option. The problem is that it does NOT work in my car, has anyone had this same case? Any recommendation? thank you so much |
03-11-2024, 11:10 PM | #3 |
Professor
2404
Rep 1,909
Drives: '23 M2 & '22 X3 M Competition
Window functions are on pg 86 in the owners manual, and there is no mention of the window opening 1/2 way by pressing the unlock button twice.
03-12-2024, 12:19 AM | #5 |
Rep 300
Triple click and then pull the door handle.
But I suspect you need to disable the comfort access proximity setting. https://www.reddit.com/r/BMW/comment...t=share_button Has been discussed on here in another thread but I’m too lazy to search at the moment. |
03-12-2024, 06:26 AM | #6 |
Rep 1,216
Found this in my M2's digital owners manual:
When a window is frequently opened to the same position, this task can be performed by the BMW Intelligent Personal Assistant. This is useful if you frequently use the same parking garage, for example. Additional information: BMW Intelligent Personal Assistant, refer to page 51. Page 51 starts the section which details how to use voice commands to enable various operations. Apparently one of which is controlling windows. And for opening the windows with the key fob: With the vehicle key Opening windows Press and hold the [unlock] button on the vehicle key after unlocking. The windows open for as long as the button on the vehicle key is pressed. |
03-14-2024, 12:16 AM | #7 |
Rep 62
apreciate everybody for your reply.
so, if any M2 G87 owner have the opportunity to try, please let me know. remember: just press UNLOCK button twice, then open the door, and tell me what happens.. thanks |
03-14-2024, 05:05 AM | #8 | |
Rep 38
I have already checked the settings in the car. |
03-15-2024, 02:56 PM | #9 |
Rep 62
Thanks, then i believe this is a software configuración error in all M2 G87. This feature is Not available eventhough the car has the option to activate!!
03-15-2024, 03:00 PM | #10 |
Rep 3,062
Drives: A Family Sedan
03-15-2024, 03:24 PM | #11 |
Professor
2404
Rep 1,909
03-15-2024, 06:51 PM | #12 |
Rep 3,062
Me neither. That’s why I asked, since the message seemed so confident it was explicitly called out in the manual.
03-15-2024, 09:55 PM | #13 |
Rep 62
there is no mention in the manual, i have looked all of it. the option is actually in idrive in the car, key configurator
set it ON , the feature don't work. what a shame... Last edited by bmhewett; 03-17-2024 at 11:55 AM.. |
03-15-2024, 11:06 PM | #14 | |
Rep 3,062
Automatic windows is when you set a location for the windows to roll down, based on GPS. Say you arrive at a toll booth or pay station every day, you can set that location in the car and the window will roll down. |
03-16-2024, 06:15 AM | #15 |
Rep 38
I only have a German manual. The feature is mentioned on page 81.
It says: "Comfort entry, press the button on the vehicle key twice in quick succession to activate the comfort entry. Depending on the settings, the window is lowered further when a door is opened." |
03-16-2024, 08:58 AM | #16 | |
Rep 3,062
03-17-2024, 11:55 AM | #17 | |
Rep 62
did someone elese have the chance to try double click ?? |
03-17-2024, 11:57 AM | #18 | |
Rep 3,062
This is not a feature in our cars. It’s not in I drive, it’s not in the manual, it doesn’t work. |
03-17-2024, 12:31 PM | #19 | |
this is the way
18468
Rep 8,589
03-17-2024, 03:53 PM | #20 | |
Rep 38
The "standard" lowering for frameless windows which you mentioned shouldn't have the be activated in an additional step. |
M2siast6003.50 |
03-17-2024, 03:56 PM | #21 |
this is the way
18468
Rep 8,589
